Dats''nuts'' project
  • Replies 201
as soon as I will find some calipers I will weld them in place :)
I can't wait to see the rest of your work. If you end up not being able to find those calipers locally, let me know. I can definitely get you a set. It's just the shipping that sucks!
I can get a set of jdm one around here for about 80$ just dont have the time to go pick em up lol. but for sure you will see those bracket welded soon :) I need to test fit everything before the primer ... this car is much more work than I expected but I enjoy working on it :)
reported the appointment for the roll cage too lol I want to do it right so when I will take the car there it's gonna be ready :)
steering column is my big concern for now , still dont know what I will do ...:(
I will wait for my pedals to arrive , then see how much space I have to work with .
A good cheap steering column solution is a S13 column. That's what I'm running next. It comes with the tilt function and enough flex joints to make it work. PLUS, it has modern headlight and turn signal switches. Give it a try.
It also allows you to use the S13 steering wheel hub adapters a few other upgrades not available for the 510 column.
little more progress..
now I have 2 tail lights... :)
temporary installed the other flare just to be sure it's in the same place than the other side
  • 1 month later...
piston ring ordered :)
I also applied some kind of POR15 on the floor pans
I still have to finish the passenger side rear quarter and a bit of trunk floor for the rear of the shell . On the front the only thing I have to finish is the 2 frames under the fenders and then I will get in some real bodywork :)
more work done to the front today as im waiting to see if I could find a better shape rear quarter ...
removed the rain tray cowl ,
then removed the fender frame
and made a paper model to have the part made this week for both side
I will also patch the rust wich I have access now that the cowl is removed
while I have access to this unseen place ... more por15
did most of the sealer but one quart wasn't enough...
frames ready to get installed but no more wire in the welder :(
in place :)
to get those installed right I need to make parts for under them
made more but no pictures
to be continued
  • 1 month later...
installed the right side rear flare :
glued with 3m 08115 and riveted ...should hold ...
and I made myself a little early birthday gift :D
miller diversion 165 :)
I dont have a lot of skills but I have a friend who is a professional welder who will teach me how to use it right :)
for now I good with steel ... but I suck with aluminium ...
anyway .. I've been told that tig welding is like playing guitar... you get better with practice :)
made a bit more yesterday
installed the left fender frame
tie rods plus camber plates
the car was actually very low lol but with the camber plate installed its much too low
and here is the cart I made for the welder :)
There is more pride than determination ahahhaa everybody keep telling me it will never be a roller again..
Cant wait to shut them up!!!! Ahah
Thx man :)
did my steering box brace :)
and stitch welded the shock towers
now I'm about to fit the wilwood pedal assembly but the steering column is right where it would set because there is no curve in the pedal arms ... So im thinking about modifying the steering column but I wonder how...
Can I put more than 2 joints in a steering column ?
did some of you already get into this ? I would like to see how yo install those
solved the pedal problem , thx to Byron510 on the realm for the advice!
cut and weld
this gave me the .5'' needed to fit right
worked on the rollcage a bit also
repaired the rain gutter too
and patched the final section I had to do on the rear end panel
back glass (just for fun ...)
and we close the shop for now
  • 3 months later...
project is still going ... just had to get it out of the garage for a while ...
a little update
still a lot to do ... that will be done :)
did the other door
test fit of the driver
fit pretty well :)  ... a bit too low I think tho ...
