Guest Captainredbeard Posted November 20, 2012 Report Share Posted November 20, 2012 That paint stripper worked great! What did you use? I want to try that on my wheels as well :thumbup: Quote Link to comment
mcmlxxxv Posted November 20, 2012 Author Report Share Posted November 20, 2012 Mar-hyde tal strip in spraycan for aircraft ,wich is safe for alloys. Quote Link to comment
mcmlxxxv Posted November 20, 2012 Author Report Share Posted November 20, 2012 Looking good - nice progress. I am currently doing floor repair also.... Hell of a job... Lol Just keep your motivation :) 1 Quote Link to comment
mcmlxxxv Posted November 30, 2012 Author Report Share Posted November 30, 2012 small update more to come soon :) Quote Link to comment
mcmlxxxv Posted January 17, 2013 Author Report Share Posted January 17, 2013 well it hasn't been as soon as I planned but here is what I,ve done so far :) patched the huge shifter hole that the previous owner did to fit the dogbox then more floor job... from under the car the box to hold the subframe was like 1 inche too low... I needed to cut the welds and raise it to the floor .. then I installed one weight jack , still have the other side to do and still need to ''box'' it .. motivation ... :P then took a couple of picture of the heads I have laying in the garage , might mix them up to get the best performance possible with that engine I have here. there is one more ported head with a regrind in it too more this weekend ... I hope ... :) Quote Link to comment
mcmlxxxv Posted January 19, 2013 Author Report Share Posted January 19, 2013 one weight jack installed :P and the driver side floor is finished ! I should be able to do the right side today :) also finished the rear wheel well for the flares to fit more tonight maybe :) Quote Link to comment
mcmlxxxv Posted January 20, 2013 Author Report Share Posted January 20, 2013 a bit more... did the other side weight jack and here's the overall view was a bit smokey in the garage .... no more gaz in the welder ... I hoped I'll be able yo prime the whole thing this week end (the lower part ..) but I still have the passenger rocker panel to spotweld and the right wheel arch to finish . But anyway im happy with what I did so far :) the car is much more stiff than it was... well it wasnt at all... Quote Link to comment
mcmlxxxv Posted February 3, 2013 Author Report Share Posted February 3, 2013 another update . my car has floor !!!!! finished the front wheel house and floor section : spot-welded the rockers : didnt took much pictures this time ... next update will have primer hehe so it will look much better :) Quote Link to comment
mcmlxxxv Posted February 4, 2013 Author Report Share Posted February 4, 2013 ordered my fuel cell to be able to complete the trunk floor today and got a place to have my roll cage made by a professional , the same guy who embossed my floorboards. Quote Link to comment
mcmlxxxv Posted February 11, 2013 Author Report Share Posted February 11, 2013 more progress.. cutted this out : and made this: test fitted the flare mounted the front suspension temporarily to be able to put the car back on its wheels tested the front wheel offset witch is perfect IMO got my rear patch panels got the lower valence too and more sheet metal to finish the body . more done than left :) Quote Link to comment
Spoona_Jay21 Posted February 11, 2013 Report Share Posted February 11, 2013 the progress is lookin great! out of curiosity, are you goin with the old paint scheme on it, or somethin different? Quote Link to comment
mcmlxxxv Posted February 11, 2013 Author Report Share Posted February 11, 2013 the car will be white , so that wat if I want the scheme done , I'll be able to do them in vynil ... but it will probably stay white :) Quote Link to comment
denis.drc Posted February 14, 2013 Report Share Posted February 14, 2013 AWESOME WORK! This build is progressing quickly. Very entertaining! Subscribed! 1 Quote Link to comment
mcmlxxxv Posted February 18, 2013 Author Report Share Posted February 18, 2013 here is a bit of a update finished the under-bodywork and removed the car from the rotisserie also I recieved my dashframe , thx to Dirttrack510 :) Now that the body is strong the real project start's :) Quote Link to comment
mcmlxxxv Posted February 19, 2013 Author Report Share Posted February 19, 2013 test fitted some parts :) only the trunk have a gap like the grand canyon .... easy to repair tho.. Quote Link to comment
mcmlxxxv Posted February 21, 2013 Author Report Share Posted February 21, 2013 measure remove spring plate and cut install on a metal corner to be sure to weld straight weld , buff put shock insert in strut / compare coilover ready ! still have to weld the support for the adjusting sleeves worked on the rear control arm witch were good for nothing ... now they will be stronger . still have a couple plates to weld on them still have to buf and paint finished the front apparatus : and one side on the rear , and im very happy of the results :) finally I tried the rear wheels again , and the offset is perfect :) will show picture this weekend Quote Link to comment
denis.drc Posted February 21, 2013 Report Share Posted February 21, 2013 Nice work! Quote Link to comment
mcmlxxxv Posted February 21, 2013 Author Report Share Posted February 21, 2013 thx:) I will get the tires rimmed this afternoon the fuel cell will be installed this weekend , then I will be able to put the etching primer on it (inside the car) ... at least it will be all the same color... Quote Link to comment
Eagle_Adam Posted February 21, 2013 Report Share Posted February 21, 2013 look good man!!! Quote Link to comment
EricJB Posted February 21, 2013 Report Share Posted February 21, 2013 Very curious about this trans. Straight cut gears in a stock housing? Do you want to sell it? Quote Link to comment
mcmlxxxv Posted February 21, 2013 Author Report Share Posted February 21, 2013 well that wasnt the stock housing ... I ve been told by the previous owner that it came off a fiat . But I didnt found any numbers on it or whatever could help ... I know it was not a stock housing because the bell housing was cut from another transmission and there was a HUGE hole in the tunel for the shifter ... I would have sold it but its already gone to the trash ... :( sorry Quote Link to comment
SR20DETdatsun510 Posted February 21, 2013 Report Share Posted February 21, 2013 Damn, Nice job man!! Followed! Quote Link to comment
Eagle_Adam Posted February 21, 2013 Report Share Posted February 21, 2013 datto compatible parts in the trash before a FS thread!!!!!!! :sneaky: Quote Link to comment
mcmlxxxv Posted February 21, 2013 Author Report Share Posted February 21, 2013 lol sorry man , I can go back to the scrapyard if you want ahah it should still be there. :geek: Quote Link to comment
EricJB Posted February 22, 2013 Report Share Posted February 22, 2013 I dont know that it would have worked for me, but straight cut gears are not a stock or street thing. They are typically very noisy, but strong. Possibly close ratio as well. You probably had something there. Quote Link to comment
