Rusty panda 620 DD
  • Replies 351
Well the black hood is staying but that's about all i can cay for sure haha might not be a panda anymore haha
noooo!!!!! lol
as long as you choose somethin you like thats all that matters, eh?
Star Blue Metallic would be a nice color, not common, but not too flashy.
this is the color. it only came on Wolfsburg Edition Vw Jetta's in 89-90
Well today I did some work on the pickup bed. I drilled out what was left of the bed hooks. Then I filled the 20 holes that were drilled in the rails, I welded bolts in the holes then grinder them off flush. I also welded some nuts under the rails for my tool box mounts. Then I shaved the drivers side marker light. The marker light needs more work and the metal warped a bit. It's darn now tho so tomorrow lol
Hooks
5A914EF2-05D5-4AA6-93EE-E15AF01B5659-100
Welding up the holes
DF0D42C4-9C7B-4B81-B217-21E7A1A4FE6B-100
Ground flush
07C367AF-4660-4ABB-A1AC-61B1378A3EC3-100
The mounts for my tool box!
1BB0A93A-CFB3-4185-82A9-020F8E231C17-100
Shaved marker light
BB96F786-CC00-401D-BF6E-7519DCAEA474-100
Well the previous owner cut most of the hooks off with a sawzall but left part of it still on there. So I finished the job lol
ahhhh. that sounds familiar. previous owner did the same on mine. but i'm keepin it. i like the ratty look =P
I'm painting soon soo it came down to what would look good lol
I had a fun drive to work today haha my front carb had the choke assembly pop off whick means absolutely no fuel.... I was not sure at the time but it felt like I was 2 cylinders down but it didn't seem possible. Well it was 2 cylinders down caust the front carb was unhooked. And now I know it's possible to drive on 2 cylinders. I messed around with it after work and got it back to normal haha
The botom popped off... It just snaps on there
0473E201-9520-4209-A8F4-3D33F915521C-165
Well today was a story of failure... I went to weld up some pin holes left from shaving the side marker and well fail. I just kept making bigger holes and chasing them all over... So I cut it out so I can try again cause it was to far gone. It's dark now so I'll have to hit it again after work tomorrow. Dang I knew this sheet metal sucks to weld on but that was ridiculous...
Clean slate
336C92BE-E7C3-4B96-9688-A09229DDD068-340
Got a few pointers from the welder at work and went to town welding in a new patch. It all went great till I ground down the welds and attempted to weld the remaining pin holes. The metal was thinner after grinding and was hard to do well. I've got it decent for now but more work on it tomorrow befor canby
32A39135-BFE1-4780-800A-77A3762F3EAF-416
Canby was completely awesome! Got to meet allot of members for the first time and just hang out and do my favorite thing... talk about cars! I also loved digging through the parts at the vendors, i loved it soo much i loaded up on a few parts for my build haha. i got an early grille badge and some fender badges that I'm not sure what they came off but now they're mine. I also got h4 conversion buckets for my lights... prolly gonna do some projectors in them but gotta research more. I picked up some 280zx flat top pistons for a future motor build. Then the best part of all!! I got a L series su filter housing! I have no clue how I got that lucky but i did lol
Badges
lights
pistons
filter awesomeness
i picked up some hardware to mount the sss air cleaner i scored... basically I found out that even if i removed the break booster completely there would be modification needed to fit the housing which i don't wanna see this thing cut up at all. Then after that let down i rigged together a line to connect my pcv the the crank case breather. I coupled a piece of pcv line to the stock line and ran it. My motor was surprisingly quieter and it got rid of my low rpm stumble. Then i went to work on my motorcycle so operation paint job can happen lol and i know have both of my vehicles running!! Gonna ride my motorcycle to work monday lol
Soo close!
Pcv hooked up
soo purdy
14035AB7-D085-4B10-926E-47C187E72B48-406
  • 4 months later...
Well I never update my thread here anymore cause I'm on nw datsuns now but I figures I'd throw up some current pics of the progress. I swapped cabs, did some painting and body work and am working on it bit by bit
My dad, draynor, and the dat side helping me swap cabs
4C675CAB-D565-43CA-8C37-9BDB8AEA35A6-836
Cabs swapped
AF79D01F-F56E-4458-99B0-2087889343DF-594
Rolled like this for a few weeks
3039B251-6CFB-4DD8-AA7F-F7C9E26E7B9C-594
A5133BD5-6136-4946-B952-1A6832CFE8E8-138
0183F8C4-83B6-4E62-9825-6F4C11016F4E-182
And finished more paint and body work
ABFF8F2F-EF7F-4908-BA6E-01FB5D7AF31F-499
E7E1EACA-7DEE-40FA-81C5-30E8946939A2-499
FB4A1E2E-AED0-4B5A-870C-4A5A55C192A1-499
A96DD691-45E1-48DE-8E1B-F2B5277EF73D-499
