ryknot Posted November 9, 2012 Report Share Posted November 9, 2012 Here ya go Spudly - metal head gasket for the beloved L series. http://www.kameariusa.com/L4_Headgasket.php Quote Link to comment
spudly13 Posted November 9, 2012 Author Report Share Posted November 9, 2012 Thanks for the link! damn those things are not cheap! Quote Link to comment
VintageRice Posted November 9, 2012 Report Share Posted November 9, 2012 So ive been doing a little research lately, to those that still look at this thread what do you think about this l20b block bored 2mm over to fit dished sr20det pistons with z22e rods giving roughly 3mm deck clearence (if i calculated it all right) Have the crank and rods machined for new bearings, and have the rotating assembly lightened and balanced. That just about wraps up the bottom end. I was thinking an open chamber u67 head, but as far as valves and cam etc im still reseaching that stuff. I had heard or read about at one point that someone makes metal headgaskets for the l series, i cant seem to find them, can anyone else confirm this? a link meybe? And of course if i got around to actually doing and affording all this work i would build a much nicer header and intake system, plumb an intercooler in find a different set of carbs, revamp the fueling system and hope to run 12lbs. Any input appreciated What and why? Quote Link to comment
spudly13 Posted November 9, 2012 Author Report Share Posted November 9, 2012 i figure if im going to put all that work into it, i mine as well pick up a set that doesnt have bent up linkage, a bent up choke that sticks and two broken float bowl screw tabs that are fixed with jb weld and leak a little! i ordered 160 mains lastnight, gunna drop from 175s, and one of these days in the upcoming week im gunna pull my intake and weld a nipple to each runner so i can properly balance them. The little things that i used to blow off are really starting to bug me for some reason. Quote Link to comment
Tristin Posted November 10, 2012 Report Share Posted November 10, 2012 I know where you can get a new intake... Quote Link to comment
spudly13 Posted November 16, 2012 Author Report Share Posted November 16, 2012 My dad went to town on the back of my car, its way straighter now, fix the rust in the rockers and its almost ready for primer and bondo. I tapped into my intake mani so i could finally balance them I changed up my timing a bit, now that all the runners are tapped i combined all 4 and am pulling constanct advance at idle and right off idle, this allowed me to retard it a bit more and still have it run decent down low. and having all 4 combined makes my bov work a little better There still not balanced perfectly but i dont have those random pops out the carbs anymore which is good ill post pics as soon as photobucket decides to start working again Quote Link to comment
aintnobiscuit Posted November 19, 2012 Report Share Posted November 19, 2012 We need a captcha for registration... damn this sucks Quote Link to comment
]2eDeYe Posted November 19, 2012 Report Share Posted November 19, 2012 Ya, the spam filters must have been messed with Quote Link to comment
aintnobiscuit Posted November 19, 2012 Report Share Posted November 19, 2012 Nice car btw spudly... :) Quote Link to comment
spudly13 Posted November 19, 2012 Author Report Share Posted November 19, 2012 We need a captcha for registration... damn this sucks Did i miss somethin? haha Nice car btw spudly... :) Thanks! Quote Link to comment
jalen Posted November 19, 2012 Report Share Posted November 19, 2012 No pics yet? Haha Quote Link to comment
spudly13 Posted November 19, 2012 Author Report Share Posted November 19, 2012 1 Quote Link to comment
jalen Posted November 20, 2012 Report Share Posted November 20, 2012 Looking good! That back is coming together nicely Quote Link to comment
]2eDeYe Posted November 20, 2012 Report Share Posted November 20, 2012 Wow, that's cleaning up pretty good :thumbup: Quote Link to comment
VintageRice Posted November 20, 2012 Report Share Posted November 20, 2012 Spuddy. Did you ever get anywhere with building camber plates? i remember you were going to try. Every time I see 510's with plates, although they are adjustable they are almost always adjusted all the way negative So I'm thinkin I might try to build some simple non adjustable plates. Just to get more neg camber. Set it and forget it kinda thing. Quote Link to comment
aintnobiscuit Posted November 21, 2012 Report Share Posted November 21, 2012 VintageRice... that's actually not a bad idea. If you have a track car or have to run a specific camber because of wheel offset/tire combo, why not just lock it..... forward thinking sir... kings to you Quote Link to comment
spudly13 Posted November 21, 2012 Author Report Share Posted November 21, 2012 I have the origanal set i made on my car, however because of how i have it setup with the bags and trying to get it low, the camber is "fixed" as negative as itll go. I still have a wood template you could photocopy and put into cad or something if you want, and if you really wanted i miigghhtt be able to get the file if he still has it and you could use it to cut out plates Quote Link to comment
jalen Posted November 21, 2012 Report Share Posted November 21, 2012 I might be interested in a template or a copy in month or 2 Quote Link to comment
VintageRice Posted November 21, 2012 Report Share Posted November 21, 2012 I have the origanal set i made on my car, however because of how i have it setup with the bags and trying to get it low, the camber is "fixed" as negative as itll go. I still have a wood template you could photocopy and put into cad or something if you want, and if you really wanted i miigghhtt be able to get the file if he still has it and you could use it to cut out plates OOOOOoooooorrrr you could cut two out for me and I'll give ya 20 bucks and two high fives. Quote Link to comment
spudly13 Posted November 21, 2012 Author Report Share Posted November 21, 2012 Haha if i can get ahold of the file i could probally get some cut out, all my friends that were cutting me stuff have since graduated though! Even if i can get you the plates youll still have to figure out a better to make the sliding portion. Quote Link to comment
jrock4224 Posted November 22, 2012 Report Share Posted November 22, 2012 I might be interested in a template or a copy in month or 2 awwww 1300 posts not a single car built and just full of broken promises...are u thinking two months from now u will be able to give that corona away? Quote Link to comment
VintageRice Posted November 22, 2012 Report Share Posted November 22, 2012 Haha if i can get ahold of the file i could probally get some cut out, all my friends that were cutting me stuff have since graduated though! Even if i can get you the plates youll still have to figure out a better to make the sliding portion. No dude, you not understandy! Static camber. NO adjustability. Just like stock but more neg camber. Stock the strut just bolts into a hole in the center. If I make a flat plate that bolts up, then move the mount hole a few degreese inward, I have neg camber set. No messing around and CHEAP P P!! See, lika dis! EZ Cheezy Quote Link to comment
spudly13 Posted November 22, 2012 Author Report Share Posted November 22, 2012 Haha well it sounds to me like you dont need me to cut em out for you then! get on it! Quote Link to comment
jalen Posted November 23, 2012 Report Share Posted November 23, 2012 Jrock the corona is in Illinois....better luck next next time haha Quote Link to comment
spudly13 Posted December 2, 2012 Author Report Share Posted December 2, 2012 All cleaned up for toys for tots tomorrow, first time ever waxing it, definately pretty pointless but oh well i won the wax kit in a raffle! Quote Link to comment
