Photo's of our Datuns pre-made engine harnesses (SR20 and RB25)
Hey everyone. A few members on here have asked us for long overdue photo's of our pre-made Datuns engine swap harnesses. We finally got them shot and up on our site. You can see them below as well.
Here is a little quick description of each harness:
This Wiring Specialties Engine Harness is designed for a direct drop-in installation into any year DATSUN with an S14 SR20DET engine. Each Pre Made Harness is built to order and will save you time, improve engine performance, give your engine bay a factory look and comes equipped with our Turn Key Start-Up Guarantee!
Suitable for the following Datsun's: 1200, 1500, 1600, 2000, 510, 240Z, 260Z, 280Z, 280ZX
If you have any questions or comments, don't hesitate to post!
S13 SR20:
http://wiringspecial...srtoanyda1.html
S14 SR20:
RB25:
http://wiringspecial...3rbtoanyda.html
Other:
http://wiringspecial...m/da51stap.html
  • Replies 15
On the description it says "S13 SR20DET to ANY DATSUN Stand Alone Pre-Made"
So does that mean you have to be running stand alone engine management? As apposed to running a stock ECU?
Nope
That just stands for the fact that is a stand alone harness from us. You can run this with stock ecu.
We will consider changing the wording as it is a bit confusing.
If this a popular swap for the Datsun guys then we can surely look into it or look into modifying our existing DET harness.
It is. And you should. :cool:
I'll buy at least one. Maybe more. :P
There have been lots of them done, almost as many as the SR20DET. Very common Roadster swap, and getting to be a common 510 swap. And I'd bet with a few minor modifications the SR20DET harness could be made to work.
If anyone here can help point out the difference in the DE and DET harnesses, we can put something together. Never had the opportunity to work on a DE or seen the wiring set up. I can;t image it is a far stretch though from the DET.
  • 3 months later...
  • 9 months later...
