svo521 Posted August 10, 2014 Author Report Share Posted August 10, 2014 Painting places the sun don't really shine.... Yet...... might not be running the hood for a bit if the f150 intake is too tall..... I have read that they have greater flow potential than any other efi 5.0 stock intake but we will have to wait and see :-) 1 Quote Link to comment
svo521 Posted August 14, 2014 Author Report Share Posted August 14, 2014 forgot my starter was lifetime warranty so it was free yay! it was almost in 2 pieces when i removed it. way easier to get at with the fender and intercooler removed now i just need to throw my new wheels on the front and get some gas money for the 16th!!!! Quote Link to comment
svo521 Posted August 19, 2014 Author Report Share Posted August 19, 2014 rotors and calipers are now visible... guess i should get off my ass an paint the left side caliper and bracket now huh?........ Quote Link to comment
svo521 Posted August 19, 2014 Author Report Share Posted August 19, 2014 Update..... Selling the van instead of parting it out. keeping the 2.3 for now. I have to admit that i'm a boost addict. Quote Link to comment
svo521 Posted September 11, 2014 Author Report Share Posted September 11, 2014 ok... current rear track width 64 inches.....front is about 62 inches.... thunderbird IRS with stock wheels is 66.5 inches. these are all outside to outside measurements. The ford trucks that these are often swapped into have frames that measure 34 inches wide. Mine measures 40 inches. this will put the front mounts closer to frame and back mounts inside of frame with coil hats centered on frame. just brainstorming. Quote Link to comment
svo521 Posted September 14, 2014 Author Report Share Posted September 14, 2014 They almost let me run it! door glass going back in for next week!!! Quote Link to comment
svo521 Posted September 19, 2014 Author Report Share Posted September 19, 2014 little junk in the trunk....... Quote Link to comment
svo521 Posted October 1, 2014 Author Report Share Posted October 1, 2014 If an ITB manifold for a 302 uses 8 50mm throttle bodies and is supposed to be good for idle-7000 rpm. than I see no problem cutting the upper truck plenum like 2 or three inches above the flange and having a plate welded on top to mount a pair of truck throttle bodies in line. it would be 4 50mm throttle bodies..... imagine two of those in line with pod filters...polished to a shine of course.... it will be a tight fit, but only having to run one of the TPS and raisng them up should give us enough room. probably run it with stock intake for now and buy a second upper plenum just in case it fails in an epic way... Quote Link to comment
svo521 Posted October 1, 2014 Author Report Share Posted October 1, 2014 c6 tail housing with new seal and gasket for $30. just gotta remove the tcase adapter and swap it out. than I just need a pre 70 water pump so i can use the same radiator (bottom hose exits wrong side currently) looks like things will be ready for this weekend!!! Quote Link to comment
svo521 Posted October 8, 2014 Author Report Share Posted October 8, 2014 less than 4 hours of work done so far..... flatbed makes a great place to store the cab :-) bunch of welding tomorrow! yay! :hyper: 1 Quote Link to comment
svo521 Posted October 11, 2014 Author Report Share Posted October 11, 2014 well I need a new column/steering gear box. shaft bearings have completely lost their cages and I haven't been able to find a source for replacements. Time to go find a smogger 620 in the wrecking yards. funny thing is... they look alot like the bearings used in cheap bicycle hubs. Anyone know of an idustrial bearing retailer in california? other than that and having to completely reroute my wiring this swap is going well. Quote Link to comment
svo521 Posted October 13, 2014 Author Report Share Posted October 13, 2014 cab back on. need to finish up motor mounts and wire up the MS. Gonna have to rewire the whole truck again so just gonna focus on wiring the engine up first and than wire the lights and stuff. moving all the relays, hei module, map sensor etc into the cab to keep out of sight. should be more presentable with the hood off than with the 2.3t Quote Link to comment
svo521 Posted October 14, 2014 Author Report Share Posted October 14, 2014 always good to write things down........ 1 Quote Link to comment
svo521 Posted October 15, 2014 Author Report Share Posted October 15, 2014 special thanks to my friend Kevin at KGI4x4 for helping me tackle this project. passenger side and middle are tacked in place tomorrow we are finishing passenger side of fire wall...... there is talk of building the cage before I wire it up...... hmmmmmmmm Quote Link to comment
svo521 Posted October 15, 2014 Author Report Share Posted October 15, 2014 hehehe 2.3t ford and t5 for sale $500 :thumbup: Quote Link to comment
svo521 Posted October 16, 2014 Author Report Share Posted October 16, 2014 got parts to mount alternator on drivers side, and a NHRA approved shifter for a little slap shifting.. firewall almost done... truck has been down for 8 days now, driveline should be done by friday. if all goes well I will be able to start wiring on monday. Quote Link to comment
svo521 Posted October 17, 2014 Author Report Share Posted October 17, 2014 Yup................. 4 Quote Link to comment
hobospyder Posted October 19, 2014 Report Share Posted October 19, 2014 All I understand out of all that is flux capacitor. You really should install one Quote Link to comment
svo521 Posted October 19, 2014 Author Report Share Posted October 19, 2014 don't forget the time circuits...... Quote Link to comment
hobospyder Posted October 19, 2014 Report Share Posted October 19, 2014 Oh, yeah, those too. Quote Link to comment
wayno Posted October 19, 2014 Report Share Posted October 19, 2014 :rofl: :rofl: :rofl: Quote Link to comment
Z chopper Posted October 19, 2014 Report Share Posted October 19, 2014 and the fusion device that uses biodegradable and non biodegradable stuff to create energy. Quote Link to comment
svo521 Posted October 19, 2014 Author Report Share Posted October 19, 2014 but the Mr fusion wasn't until the second movie.. for now I'll just use some corner store plutonium lmao Quote Link to comment
EastBay521 Posted October 19, 2014 Report Share Posted October 19, 2014 you are a mad man!! I cant wate to see what this thing can do. whats your gearing in the rear? 1 Quote Link to comment
