Fat510`s 79 A10 warthog
  • Replies 336
Update: Nissan Hardbody/pathfinder alternator put in today
old one, works fine just covered in oil
and the new one :thumbup:
i can run my hi beams, heater at full blast without any change in voltage.
  • 2 months later...
so yesterday the starter was being wierd for awhile. like i would turn the key and nothing would happen, i'd turn it back of, turn the key, clicking, i would do this like 4-5 times and it finally start. so i switched out my starter for the gear reduction o'matic ZX starter
After it did the same thing after i changed it.
so i thought it was the ignition switch
It was actually this worn out piece of crap
back together
it works perfect now, it got me like
dude, you need a better starter in general.
Haha it's actually a pretty good starter... It's just not lined up properly. Going to pull it next week and see what's up with it. Hoping it's too far back so I can just space it with washers. Then I can start my car properly.
there's a wagon like mine with a motor still in it in tacoma, it might have one. the car is listed as a 79 but its a square headlight 80-81 one
This was also done.
Lower pcv pipe hit rear carb so i cut end off ,, went through box of old pre-bent hoses,, a toyota emissions part , and a hollowed out old PCV valve . It goes around carb and up to valve like it's supposed too.
Used this set-up to catch shavings from cutting pipe
Never throw anything away that can be repurposed
Cut the pipe offa this
Welded
Pre-formed VW jetta heater hose looks like i was made for this.
Next was power brakes ,, the intake wasn't drilled out so i took this fitting i had laying around so it would easily center perfectly,, after drilling i drilled fitting bigger in the drill press and in turn inlarged the hole in manifold also.
  • Like 3
  • 4 weeks later...
  • 5 months later...
nothing really has been done since the last post. I took the SUs off September 2k13, eventhough they gave the car more power, the hitachi works soooo much better.
and i got "new" front tires. and by "new" meaning they from the 80s..
and i polished my superlites yesterday
before
after
  • 3 months later...
4/16/15 alternator had a had a loud whine so i changed it. This one is the 70 amp pathfinder alternator
old one, super covered in oil
new
And last night i changed out both driveline ujoints the night before tedslocos cruise
