Fat510 Posted March 23, 2014 Report Share Posted March 23, 2014 night oics update cuz i forgot 1 Quote Link to comment
Fat510 Posted March 29, 2014 Report Share Posted March 29, 2014 Update: Nissan Hardbody/pathfinder alternator put in today old one, works fine just covered in oil and the new one :thumbup: i can run my hi beams, heater at full blast without any change in voltage. Quote Link to comment
bananahamuck Posted March 29, 2014 Author Report Share Posted March 29, 2014 You forgot to add 40-50 amps (generous) stock ,,, 93 pathfinder 70 amp ... yo Get your amps up!! Now you know it works ,, you have to take it back out and hit it with the wire wheel.. 1 Quote Link to comment
Fat510 Posted May 31, 2014 Report Share Posted May 31, 2014 so yesterday the starter was being wierd for awhile. like i would turn the key and nothing would happen, i'd turn it back of, turn the key, clicking, i would do this like 4-5 times and it finally start. so i switched out my starter for the gear reduction o'matic ZX starter After it did the same thing after i changed it. so i thought it was the ignition switch It was actually this worn out piece of crap back together it works perfect now, it got me like Quote Link to comment
Tristin Posted June 1, 2014 Report Share Posted June 1, 2014 I need a gear reduction starter... Keep meaning to pick one up. Quote Link to comment
Fat510 Posted June 1, 2014 Report Share Posted June 1, 2014 I need a gear reduction starter... Keep meaning to pick one up. dude, you need a better starter in general. Quote Link to comment
Tristin Posted June 1, 2014 Report Share Posted June 1, 2014 dude, you need a better starter in general. Haha it's actually a pretty good starter... It's just not lined up properly. Going to pull it next week and see what's up with it. Hoping it's too far back so I can just space it with washers. Then I can start my car properly. Quote Link to comment
Fat510 Posted June 1, 2014 Report Share Posted June 1, 2014 Haha it's actually a pretty good starter... It's just not lined up properly. Going to pull it next week and see what's up with it. Hoping it's too far back so I can just space it with washers. Then I can start my car properly. there's a wagon like mine with a motor still in it in tacoma, it might have one. the car is listed as a 79 but its a square headlight 80-81 one 1 Quote Link to comment
Tristin Posted June 1, 2014 Report Share Posted June 1, 2014 I'll be in the area on the 7th. Maybe I'll go check it out, thanks. Quote Link to comment
bananahamuck Posted June 1, 2014 Author Report Share Posted June 1, 2014 I don't think it had gear reduction starter though,, as it was a Naperaction engine. There were a shit ton of pick-ups there but those run the standard starter also. Quote Link to comment
Tristin Posted June 1, 2014 Report Share Posted June 1, 2014 Without searching, I think the 720 diesels had a GR starter. I mostly just need to get mine aligned properly so it catches the flexplate. Then I can worry about fancy-smancy starters. Quote Link to comment
bananahamuck Posted June 1, 2014 Author Report Share Posted June 1, 2014 No diesels were there. Quote Link to comment
q-tip Posted June 1, 2014 Report Share Posted June 1, 2014 You need more than just an alignment Tristin.... Good is coming along pretty well captain spinout! 1 Quote Link to comment
Fat510 Posted June 2, 2014 Report Share Posted June 2, 2014 You need more than just an alignment Tristin.... Good is coming along pretty well captain spinout! woot! Quote Link to comment
q-tip Posted June 2, 2014 Report Share Posted June 2, 2014 Just realized I hot auto corrected, I meant goon not good. :lol: Quote Link to comment
Fat510 Posted June 10, 2014 Report Share Posted June 10, 2014 SUs are on [lIMG]http://i1093.photobucket.com/albums/i436/paymentincluded/cow%20catcher%202000/DonovanPlane1017_zpsa7caae3c.jpg 3 Quote Link to comment
bananahamuck Posted June 11, 2014 Author Report Share Posted June 11, 2014 This was also done. Lower pcv pipe hit rear carb so i cut end off ,, went through box of old pre-bent hoses,, a toyota emissions part , and a hollowed out old PCV valve . It goes around carb and up to valve like it's supposed too. Used this set-up to catch shavings from cutting pipe Never throw anything away that can be repurposed Cut the pipe offa this Welded Pre-formed VW jetta heater hose looks like i was made for this. Next was power brakes ,, the intake wasn't drilled out so i took this fitting i had laying around so it would easily center perfectly,, after drilling i drilled fitting bigger in the drill press and in turn inlarged the hole in manifold also. 3 Quote Link to comment
]2eDeYe Posted June 11, 2014 Report Share Posted June 11, 2014 Repurposing with a purpose :D 1 Quote Link to comment
bananahamuck Posted June 11, 2014 Author Report Share Posted June 11, 2014 Or maybe i just have a problem. Trays of used and new pipe type fittings and hoses i buy whenever i see them at yard sales. 1 Quote Link to comment
]2eDeYe Posted June 11, 2014 Report Share Posted June 11, 2014 Better not let any of the local tweakers see that treasure :lol: 2 Quote Link to comment
q-tip Posted June 11, 2014 Report Share Posted June 11, 2014 Its too late, they can sniff that shit out 1 Quote Link to comment
Fat510 Posted July 10, 2014 Report Share Posted July 10, 2014 hey i got new suspension parts and alignment as of a week ago, just too lazy to post haha 1 Quote Link to comment
bananahamuck Posted July 10, 2014 Author Report Share Posted July 10, 2014 And then the front float sank making it undrivable ,.............................. :sneaky: Quote Link to comment
Fat510 Posted January 2, 2015 Report Share Posted January 2, 2015 nothing really has been done since the last post. I took the SUs off September 2k13, eventhough they gave the car more power, the hitachi works soooo much better. and i got "new" front tires. and by "new" meaning they from the 80s.. and i polished my superlites yesterday before after 1 Quote Link to comment
Fat510 Posted April 20, 2015 Report Share Posted April 20, 2015 4/16/15 alternator had a had a loud whine so i changed it. This one is the 70 amp pathfinder alternator old one, super covered in oil new And last night i changed out both driveline ujoints the night before tedslocos cruise 1 Quote Link to comment
