78 K/C with a KA24DE
Eric Garside
  • Replies 141
I dont know of the exact capacity but it appears to have almost double of my 12 gallon fuel cell. The stock tank is 11.9 gallons so I would think this is almost double, maybe 20 gallons or so... I can get some measurements and do the math if you want, I tried searching google and couldnt come up with an answer.
Z-Train had one a few years ago that I think he sold and I'll bet my Barbie doll collection that Mike knows the answer ;)
Never thought about using my engine hoist to remove the bed, Thanks.
Be careful as the side of my bed got scratched up a little bit. I wasnt too worried about it because its pretty rusted out.
Mine is a 78, not a big deal as it has a tank already :D
True!
It seems like a lot but I come up with ~22 gallons. The tank measures 33x12.5x13 and that comes out to 23.21 gallons and then take out a little for the small angled portion...
I will hopefully get some work done on her when I get home tonight. My coilover brackets should be in any day now and I cant wait to get the front end buttoned up! UPS man dropped off new ball joints from RockAuto yesterday, wish I would have remembered to order my wheel bearings at the same time!! :facepalm:
It shouldn't be too difficult to make it fit. I will be putting a '79 tank in my '78 truck that had a bed mounted tank. I will keep you posted on the needed modifications.
Yesterday I pressure washed the frame, bed, and under the hood. Today I will hopefully get some work done on my power steering setup.
I have an update...
Got the steering column all mocked up but I think my steering box is about 3/4" too high...
It looks like to be level with the idler arm it needs to drop 3/4" but I am not sure how to do that just yet... Any ideas?
My steering column is a combination of a 620, Z car, and Hardbody steering components
This is the Z car firewall plate tacked to the 620 plate. With the double u-joint setup I was concerned with the column getting "shoved" around while trying to turn so this will fix it to the firewall.
RockAuto sent me the wrong idler arm... Its tuff to see from the picture but its about a half inch longer. Anyone know the torque specs of the top nut so I can transfer the inerds?
Nothing is permanently fixed yet as I want to get the center link flipped and set the motor in to check for clearance issues. Any advice or constructive critisism welcome :D
  • 1 month later...
Can you slot the mounting holes in the box? MAybe slot the idler and drop it down to match? That would give you more clearance at the pan for the centerlink.
  • 2 months later...
Not really a progress update but I did find the end of the rainbow when I was at Pull and Save last night!!
 F7BF2145-0FA0-42BE-98F0-C8592C236407-173
Found that weber just chilling behind the drivers seat of the truck. Whats that sitting next to it in the picture?
Could it be??....
Oh yes, yes it is!! Its a factory tach!!
1D7FED20-76A9-4AE8-A2D1-738DE2AA4F89-173
Dont mind the dust on it, this thing is pretty cherry and it was in a truck that had been at the yard for awhile. I litterally had to do a double take because I didnt believe it.
But wait, theres more!
Also scored some A/C components, unfortunately there wasnt a lot of that system left in the truck :/
ABE330D1-9322-42C1-86FC-F0265EADF478-173
 48D8F0A8-961A-4512-94DF-BFB4A080A9D0-173
Found a bunch of Datsun baggies in the glove box of another truck, dont really need them just thought they were cool. The group of baggies with the 3x5 card stapled to it contains a bunch of needles, jets, and random carb parts.
8ECEB0D2-2E2A-4874-8DEF-22B997E34A56-173
Didnt want to hack up my harness to install the tach so I took the whole wiring harness too!
FD566C74-20F7-40A9-B8AF-E836BB60EFBA-173
Now I am on the hunt for the rest of the A/C system! If anyone has the parts, I might be willing to trade a nice little tach for them ;)
  • 2 months later...
  • 3 weeks later...
Progress to come in the near future!
Adam you have motivated me to get back to work on this thing.
Last night I picked up a running DE swap. With roughly 6 months to Canby '14, fingers crossed, I will actually make it!!
  • 8 months later...
Been a long time since the last update. I feel like I was one of the first to attempt the DE swap and now it feels like I will be one of the last to complete it. One of these days it will be on the road.
Last fall I picked up another DE swap from a friend, this is an S14 engine that came out of an S13 car. I will be using my S13 wiring harness because I already stripped it down and labeled everything.
1C3E5D2E-FB14-444D-8699-F05ADDDE9357_zps
Engine bolted in place.
67C45890-5BFD-4BE1-8B8B-7D6663EBD3C9_zps
I feel like my S13 DE had more clearance at the firewall but I never bolted it in with the tranny attached.
Trans crossmember, didnt take a before picture but you get the idea. Looks like the previous owner ran it into something.
9E7EEA4C-332D-4E2C-966D-D195BA45FAE9_zps
Up close picture of the elongated mounting holes
FE866B12-7939-4BE4-86AA-5F387504CA3E_zps
Passenger side coil over mocked up. Those are Bee's brackets and upper control arms using RockAuto bushings, ball joints, and wheel bearings on 2WD hardbody spindles.
72AD9B7A-9715-4FB7-9C7A-2893CB71A89D_zps
942F5AB0-1902-45F3-BCEC-26B448F683A3_zps
It will be interesting to see how they look and ride with a load on them.
Next up is wiring.... To be continued
  • Like 4
Always always always check the glove box. Owners often buy new parts and never get around to replacing the. Got a brand new $30 U joint this way.
Always good to have a spare harness BUT. Your '78 will have the plug for the factory tach already there right above there the tach goes. It will be tied up and tapped to the harness. The ultimate plug 'n play.l
No response so I went with it, almost seems too easy to work... Here is the progress so far
78C1F1AF-6D07-4BFD-9B96-92732AC443E7_zps
$10 worth of plugs and relays from Pull and Save, I had my skinny jeans on today so I couldnt fit them in my pockets...
E215D653-AA27-4DFB-8BB3-16EA1584C036_zps
B5561E9D-C33E-487F-9B78-5AAFF2CC2328_zps
CAF7B835-14E4-46EF-A470-D66D16ADBA61_zps
Because I cut these plugs off of a 94 Maxima (behind passenger headlight) the colors dont match and I had to trim this one a little
EBD57EF9-1151-459E-8AA0-D715ACEF4F4C_zps
134833DF-5E56-4B1C-B556-86DB73711E6D_zps
Labeling the new plugs/wires
2587B36B-6983-49C4-8F70-6E90C316BB3F_zps
884FD56C-70D0-4CD5-B49A-C589034A7DBD_zps
Depinned the wires that werent going to be used
19F176EE-53E1-4C88-ABED-D1F6FA19E7BE_zps
On this one I also moved the thicker gauged wire to match up with the thick gauge from the engine harness
88627BFF-24E2-4E10-BC20-FA862A325E4A_zps
Used Jeff's wiring diagram, factory Nissan relays, and a fuse block from Auto Zone... and a little bit of beer
46676F1C-F22B-4725-904E-E1AE6F10EF3B_zps
All this is temporary to make sure everything works, end of day one
B94530FB-674C-4F5C-BDF0-7698C1FFD528_zps
Let me know what you guys think
  • Like 3
