195sRFast Posted July 9, 2011 Report Share Posted July 9, 2011 We are redoing on a 521. All the coating on the bottom, underneath,of the bed is missing. Is there anything which can be sprayed on to replace this? Quote Link to comment
burrito213 Posted July 9, 2011 Report Share Posted July 9, 2011 dura-last truckbed undercoating? Quote Link to comment
Spades Posted July 11, 2011 Report Share Posted July 11, 2011 There are tons of products for this, most of the aerosol products I have used have been below expectations. Be sure to tape off the rocker panels because most undercoat products do have serious overspray issues, and most of them are nasty and take some strong cleaners to remove once they hit paint, even before they dry. Quote Link to comment
DanielC Posted July 11, 2011 Report Share Posted July 11, 2011 After working on a few 521 trucks, and seeing the rust that happened under the undercoat, I would suggest undercoating does not really add as much protection as a sales man at a dealer selling you "rust prevention package" when you buy a new car. I believe the most common reason the floors rust out on the cab of a 521 is the vinyl floor mat does not allow water to evaporate, dirt gets under it, grinds off the paint, and then the rust starts. I would paint the bottom of the cab with a good quality epoxy primer, after removing the rust first. Then paint with a suitable top coat. Quote Link to comment
d510addict Posted July 11, 2011 Report Share Posted July 11, 2011 Maybe try bed liner as a top coat? IDK shit seems durable and makes a good bond with paint. Quote Link to comment
Z chopper Posted July 11, 2011 Report Share Posted July 11, 2011 remove the rust from the floors use some rust nutralizer then rhino liner the floors inside the cab and under the cab, rhino liner also helps and a noise deadner Quote Link to comment
Shagy Posted July 15, 2011 Report Share Posted July 15, 2011 Strip it....kill/trat the rust then lay down por15 Quote Link to comment
wildmaninid Posted July 15, 2011 Report Share Posted July 15, 2011 Check out my build thread.........did the bedliner on the floors, inner fenders and backs of the fenders............i believe it will work well as an undercoat and even a frame paint, however do not use an aerosol coating, as they just cant hold up to the abuse of mother nature. http://community.ratsun.net/topic/33613-77-longbox-build-thread/ Quote Link to comment
195sRFast Posted July 17, 2011 Author Report Share Posted July 17, 2011 Thanks for all the info. One question, what the deuce is por15? Quote Link to comment
Shagy Posted July 17, 2011 Report Share Posted July 17, 2011 Google it. Its great Quote Link to comment
FoxyRoadster Posted July 17, 2011 Report Share Posted July 17, 2011 far warning with por15, follow the directions to a T and paint over it as even the slightest chance of uv light hitting it will cause it to degrade rapidly. I don't have a datto truck but my roadster does have a frame so its kinda like a truck. What I did was remove rust as much as I could.. welded up any holes created by this and then por15'ed the underbody along with beliner. Quote Link to comment
