Elkie Posted June 28, 2011 Report Share Posted June 28, 2011 If your not using the entire system, you can leave it plugged. At that point your just giving the possible pressure in the crankcase somewhere to go. Which would be through valve cover vent. Quote Link to comment
DanielC Posted June 28, 2011 Report Share Posted June 28, 2011 A good working PCV system does not rob horsepower. It recycles unburnt gases back into the combustion chamber, and helps suck water vapor out of the engine's oil. Water in oil is not good. The carburetor is set up to run with it in place. Another good advantage of a PCV system is the engine crankcase operates at a slight vacuum, and this does a lot to prevent oil leaks. I have a 1948 Willy's jeep it has a PCV system. Every modern car has a PCV system. Your Datsun engine will be a run better with the PCV system, and it will stink less. Put it back on. L-16 PCV valve number 11810-A3501 L-16 PCV hose number 11828-23002 Quote Link to comment
albyneau Posted June 28, 2011 Report Share Posted June 28, 2011 L-16 PCV hose number 11828-23002 Hey DanielC~ since I caught ya lookin, is that ^^^ number for the hose still good at the Ratsun dealers? Quote Link to comment
banzai510(hainz) Posted June 28, 2011 Report Share Posted June 28, 2011 I would run it open or at least put a 1/4 hole in there and see how it runs. for the valve cover I would route a hose down by the trans or if possible route the hose to the carb. Stock the routed to the side of aircleaner. on weber DGvs there is a elbow that hooks to the underside of the bottom aircleaner plate. Quote Link to comment
jon521 Posted June 28, 2011 Author Report Share Posted June 28, 2011 hainz, i have a straight hose going to my air filter, but i think im going to put one of those small, cone air filters on the vent. as for the case breather, i would look into get a valve, but for now i will open it up and see how it runs. Quote Link to comment
jon521 Posted June 28, 2011 Author Report Share Posted June 28, 2011 If your not using the entire system, you can leave it plugged. At that point your just giving the possible pressure in the crankcase somewhere to go. Which would be through valve cover vent. Yes it is better to vent the block. Even though the rocker cover is vented, it is still good to vent the block so the engine don't have to push air from bottom to top. ? Quote Link to comment
banzai510(hainz) Posted June 28, 2011 Report Share Posted June 28, 2011 Be honest if your motor is burning oil its still going to. To me routing hoses and using a PVC is to keep the sticnk and oil from splashing it way out . best to unplugg that vent or give a small hole to vent it. You could still leave the cap but just put a 1/4 hole in there or route a hose dont so it dont mist oil out of it. Quote Link to comment
DanielC Posted June 28, 2011 Report Share Posted June 28, 2011 I do not know about Ratsun dealers. I got the two parts at Tonkin Nissan, In wilsonville oregon, in April. Quote Link to comment
jon521 Posted June 28, 2011 Author Report Share Posted June 28, 2011 I do not know about Ratsun dealers. I got the two parts at Tonkin Nissan, In wilsonville oregon, in April. wow, thats awesome, not too far from me. how much was it total? so the valve goes on the intake, and the hose goes to the valve and then the vent? Quote Link to comment
DanielC Posted June 28, 2011 Report Share Posted June 28, 2011 The valve was 16.82, I think the hose was a little less. I cannot find the receipt for the hose. The hose is two different sizes on the ends. The valve uses BSP threads, so it may now be a easy find at any parts store. Quote Link to comment
banzai510(hainz) Posted June 28, 2011 Report Share Posted June 28, 2011 Fram makes those commone PCV valves. The Hose is for a 510/521 intake. so make sure you have that as that what the hose routes to then the crankcase vent tube. PCV hole on intake faces towards the firewall. Quote Link to comment
king bee66 Posted June 28, 2011 Report Share Posted June 28, 2011 definetly vent it and see if it runs better, but i dont think the blow by caused by the pressurized crankcase would account for that much smoke. im now on board with it being the valve seals Quote Link to comment
datzenmike Posted June 29, 2011 Report Share Posted June 29, 2011 Almost 40 posts on this. Be honest if your motor is burning oil its still going to. PCV valve isn't going to fix this. Change your oil/filter, drive the shit out of it. (also take note where 4 qts of oil fill to on your dipstick, you may be over full) If the oil rings are stuck or sticking this may free them up. If the oil gets black within a couple of weeks you're burning it, not much you can do about it. End of story. Quote Link to comment
Drahzzel Posted June 29, 2011 Report Share Posted June 29, 2011 Although running a PCV system is generally a good idea, if yours is currently capped, the PCV isn't the problem. Blue smoke due to the PCV is usually when you have the check valve and it either gets stuck open or breaks internally. I'm guessing you got some oil slipping past the rings, but you should hope it is only the valve seals as that's easier to deal with. Quote Link to comment
jon521 Posted June 29, 2011 Author Report Share Posted June 29, 2011 I will plan on doing valve seals. I changed the oil when I bought the truck (less than 3000 miles ago) and it was a little over full. The oil is not black, still a good carmel color. Tomorrow I will will check what the smoke looks like again. I have an idea....I will update when I'm confirm a few things. Quote Link to comment
jon521 Posted June 29, 2011 Author Report Share Posted June 29, 2011 so i checked to make sure that it was blue smoke, not white. my idea was that it may be smoking because of a fuel problem, because the mpg on my last tank of gas was 14 :( and my plugs are all black as night so im running rich. but the smoke was definetly blue, not white. i fixed my oil leak though, so now i can keep an eye on the oil level and get an idea of how much it is burning. Quote Link to comment
sick620 Posted June 30, 2011 Report Share Posted June 30, 2011 heres an idea! read these instructions very carefully. 1. buy a head gasket $12.99 2. buy rings $30.00 3. buy valve stem seals $15.00 4. buy a weber 32/36 dgav $40 used 5. install... 6. thank Sick620 for making your life easier,,,, :D Quote Link to comment
jon521 Posted June 30, 2011 Author Report Share Posted June 30, 2011 haha i have a weber, planning on doing valve seals, then going to see where im at. thanks sick :) Quote Link to comment
sick620 Posted June 30, 2011 Report Share Posted June 30, 2011 ok edited it ;) ... keep those directions handy :) Quote Link to comment
jon521 Posted June 30, 2011 Author Report Share Posted June 30, 2011 haha will do Quote Link to comment
jon521 Posted June 30, 2011 Author Report Share Posted June 30, 2011 fuckin got a warning from KPD today for "visible emmisions." Quote Link to comment
