atkinson40 Posted June 23, 2011 Report Share Posted June 23, 2011 I'm just getting this pony back on the road and have noticed she shudders when I hit the brakes firmly. I've replaced the shoes and rear cylinders. I think I adjusted them OK. What could cause this?? Thanks kevin Quote Link to comment
elmerfudpucker Posted June 23, 2011 Report Share Posted June 23, 2011 The back is shudering or the steering wheel? tires out of balance or have a knot in them? lug nuts all tight? Quote Link to comment
gcmustang Posted June 23, 2011 Report Share Posted June 23, 2011 My first thoughts are drums or rotors warped Quote Link to comment
Wide14u Posted June 23, 2011 Report Share Posted June 23, 2011 My first thoughts are drums or rotors warped x2 Quote Link to comment
MikeRL411 Posted June 23, 2011 Report Share Posted June 23, 2011 Assuming this is your 72 pickup, check to be sure that the backing plate bolts on the rear brakes are tight. They can loosen up over time and oscillate CW / CCW as the brakes attempt to grab. Shudders for sure. Quote Link to comment
mklotz70 Posted June 23, 2011 Report Share Posted June 23, 2011 I agree with all of the above. Another possibility might be that there was grease or something on the surfaces. If you put on new shoes and did not have the drums turned....I'd probably start with having them turned. :) ......actually.....I'd start with disc brakes! LOL! :) Quote Link to comment
atkinson40 Posted June 24, 2011 Author Report Share Posted June 24, 2011 I agree with all of the above. Another possibility might be that there was grease or something on the surfaces. If you put on new shoes and did not have the drums turned....I'd probably start with having them turned. :) ......actually.....I'd start with disc brakes! LOL! :) OK, I drove it again and the shudder is worse the last few feet of stopping. I don't feel it in the wheel, only in the brake peddle and my butt/thighs. I'll start with the rears and check again. -K Quote Link to comment
Spades Posted June 24, 2011 Report Share Posted June 24, 2011 OK, I drove it again and the shudder is worse the last few feet of stopping. I don't feel it in the wheel, only in the brake peddle and my butt/thighs. I'll start with the rears and check again. -K you will often only get a wheel pulling if one side is hanging up and the other is fine(as in, the drivers side rotor is warped or there are caliper issues, but no problems on the passenger side). Brake pulsation is most often caused by warped rotors...drums can cause this symptom, but is much more unusual. Check for rotor warp first... Quote Link to comment
ggzilla Posted June 25, 2011 Report Share Posted June 25, 2011 72 Dat PU doesn't have disk brakes ... I haven't run into this problem except with disk brakes. Quote Link to comment
Spades Posted June 25, 2011 Report Share Posted June 25, 2011 72 Dat PU doesn't have disk brakes ... I haven't run into this problem except with disk brakes. MMMM....4 wheel drum...nice. I haven't worked on anything with them before...I do know I have seen another tech in the shop get stuck with a gremlin once that had them, and had brake shudder issues...turned out to be a nightmare getting all the shoes adjusted just right so that there was no shudder or pulse and so that the thing would stop straight. I guess check the adjustment on the shoes and look for warped drums...most likely the reason I see warped rotors causing brake shudder the most is because the newer cars we work on rely on front brakes to do the bulk of the stopping, and the people that heat their brakes up enough to warp the rotors tend to stop abruptly and do a nosedive...so the trucks and SUV's I see normally have 50% or more shoe left when the front pads are to the rivets. Quote Link to comment
atkinson40 Posted July 6, 2011 Author Report Share Posted July 6, 2011 Turned the rear drums. Still shudders. Going for fronts next. What is the adjustment method? -K Quote Link to comment
banzai510(hainz) Posted July 6, 2011 Report Share Posted July 6, 2011 should have done the fronts first. adjustment???? there is a thumbler sat set up behind the plate where the brake line goes in youll see it. I think you turn it down screwdriver or a offset bent type ones work the best,to take up the slack.Most times if half way worn I would just get new pads also as they are cheap. If new pads then youll loosen the starwheel. If drum is off youll see it and loosen it then. I usually loosen it enough to get the drum in just enough so when i do the last adjustment Im not spending too much time tighten up the star wheel. Quote Link to comment
atkinson40 Posted July 6, 2011 Author Report Share Posted July 6, 2011 just enough so when i do the last adjustment Im not spending too much time tighten up the star wheel. Thanks B. The "last adjustment" was what I was asking about. How far out do you adjust shoes. The book says something about until the wheel won't turn and then back off some number of turns. Its kinda vague. -K Quote Link to comment
ggzilla Posted July 7, 2011 Report Share Posted July 7, 2011 Tighten it until the tire won't turn, then back off until it turns freely. Exactly that. Quote Link to comment
atkinson40 Posted July 7, 2011 Author Report Share Posted July 7, 2011 Tighten it until the tire won't turn, then back off until it turns freely. Exactly that. "turns freely" Does this mean without any scraping of the pads. I can turn the wheel freely, but hear the pads scraping. -K Quote Link to comment
banzai510(hainz) Posted July 7, 2011 Report Share Posted July 7, 2011 That would be a judgment call on your part. if you hear it slightly drag I dont think it would be nothing to worry about as the shoes will center themselves also after driving. when tight the parking break also works good. Quote Link to comment
atkinson40 Posted July 9, 2011 Author Report Share Posted July 9, 2011 Turned front drums. Replaced front shoes while drums were off. No more shudders. Still need to: 1. Go through lights. 2. Add oil to differential. 3. Fix rear license plate holder. 4. Take to Evens for a free flat repair(rear tire has slow leak). 5. Get alignment. 5. Register and insure. Quote Link to comment
Steve - AF1 Racing Posted August 16, 2011 Report Share Posted August 16, 2011 This was a helpful thread. I have a brake shudder from the front right drum. Plenty of ideas here to work with. Thanks in advance! (For whatever its worth, I've noticed that there is a difference between drums that have been adjusted cold vs drums that have been adjusted after driving for a little while. Of course, this could be a symptom of something else entirely, but I wanted to note it). Quote Link to comment
