DATSMO license plate frame!
Hey fellow RATSUNers!
I just wanted to let everyone know that I have DATSMO license plate frames available!
They look like this:
$8
$15 for two
I just wanted to see what you guys think.
I also can make it custom to whatever you'd like.
I was thinking I can make "Official Ratsun license plate frames" if RATSUN is interested (of course with permission from the almighty moderators and whoever would be involved).
So...please, I'd like to hear your opinions.
ーゴキ
  • Replies 39
Biggest problem I see is that they block the month/year tabs on Oregon plates. The tabs are on the bottom.
For states with registration tags on the bottom, holes can be drilled and DATSMO or whatever can be mounted on the opposite side.
In other words, it's pretty customizable not just orientation, but with whatever you want it to say.
In the works with a custom design to show you guys, so stay tuned!
-goki
is it possible to make them on white plastic frames?
Blue painter's tape well rubbed down, white epoxy spray primer, white refrigerator epoxy spray [gloss or semi gloss] and you are done [after peeling off the tape]. Available in Home Depot or Orchard Supply Hardware.
Edited by MikeRL411
hey all!
I'm double checking with ratsun for permission to use the logo to put it on the frames. As soon as i get the ok, I'll start taking the requests and knocking them out.
I'll start a new thread for RATSUN frames as well.
-goki
hehehe
I'll let you know in due time. Want to get the ok from RATSUN first.
what about the datsumo plate still ok on those will send you pay pal tomorrow dont worry i saved the address had a feeling i should for some reason lmao
