gwb Posted June 1, 2011 Report Share Posted June 1, 2011 My current radiator is shot and I need to find a replacement. Anyone had any experience with the eBay aluminum ones? The one I am thinking about getting is here. I am using the l16 and would like little no fabrication Quote Link to comment
kelowg Posted June 1, 2011 Report Share Posted June 1, 2011 if tanks r still good, have new core made. companies make cores to size for rad shops Quote Link to comment
gwb Posted June 1, 2011 Author Report Share Posted June 1, 2011 I got quoted for $365 which is beyond what I'm willing to spend to refurb it Quote Link to comment
tlap Posted June 1, 2011 Report Share Posted June 1, 2011 I have had one of these in my wagon for about a year now. The price is right and It works great, keeps my 2.0L running cool. There are no mounts so I built my own rubber isolated lower mounts and upper support. Quote Link to comment
nismo dr Posted June 1, 2011 Report Share Posted June 1, 2011 Well, it does say it will cool to 450hp. Quote Link to comment
D52E Posted June 1, 2011 Report Share Posted June 1, 2011 Does anyone have pictures of the radiator installed? I was just curious to see how it fits comapred to the stock unit. Is the core wider or thicker? Does it clear the core support height ok? Any mounting brackets, holes or threaded boss provided for attachment? Thanks in advance Quote Link to comment
flatcat19 Posted June 1, 2011 Report Share Posted June 1, 2011 High performance appearance. Win. Quote Link to comment
nismo dr Posted June 1, 2011 Report Share Posted June 1, 2011 "You get "BIG BLOCK COOLING" Quote Link to comment
dennis Posted June 1, 2011 Report Share Posted June 1, 2011 out of the auction: Core Dimensions: 19 3/4" wide x 14 1/4" tall (2 row core) <li> Overall Dimensions: 24" wide x 16 1/2" tall (including tanks) Quote Link to comment
hang_510 Posted June 2, 2011 Report Share Posted June 2, 2011 dont know anyone who has used that one. i have a very good used 3-core, w/ AT connections avail. (wont fit in the same box though) Quote Link to comment
68Datsun510 Posted June 2, 2011 Report Share Posted June 2, 2011 I guess the skyrocketing price of yellow metals has hit the radiator service industry as well.... Quote Link to comment
gwb Posted June 2, 2011 Author Report Share Posted June 2, 2011 Anyone have any suggestions for a decent drop in radiator that doesn't require much fabrication? Quote Link to comment
yellowdatsun Posted June 3, 2011 Report Share Posted June 3, 2011 Aren't there already like 20 threads on this subject? It comes up at least once a month. Us Phoenix guys run the Fiero rads. Quote Link to comment
CorAce Posted June 4, 2011 Report Share Posted June 4, 2011 I have the very same one in my dime and it works great. but if your looking for a "bolt in" unit this is not for you. You will have to fab some shock mounts and hold down straps. Not a big deal if your handy but it is some work. And if you do get one get to 2 row for sure, the 3 row is way too close to the fan. I can up load some pics tomarrow if you want to see how I did it. Quote Link to comment
hang_510 Posted June 4, 2011 Report Share Posted June 4, 2011 Anyone have any suggestions for a decent drop in radiator that doesn't require much fabrication? stock 3-core not good enough? Quote Link to comment
gwb Posted June 4, 2011 Author Report Share Posted June 4, 2011 I have the very same one in my dime and it works great. but if your looking for a "bolt in" unit this is not for you. You will have to fab some shock mounts and hold down straps. Not a big deal if your handy but it is some work. And if you do get one get to 2 row for sure, the 3 row is way too close to the fan. I can up load some pics tomarrow if you want to see how I did it. Thanks for the input, I would appreciate some pics too! I am sure I can come up with some mounts Quote Link to comment
gwb Posted June 4, 2011 Author Report Share Posted June 4, 2011 stock 3-core not good enough? Mine was rusted out and they wanted $365 to fix it. I ended up pulling a Fiero radiator, we'll see how that goes Quote Link to comment
hang_510 Posted June 5, 2011 Report Share Posted June 5, 2011 ill have the pix tomorrow... i send em of the rad too. i relied i have a 3-core, w/ AT connections avail. Quote Link to comment
gwb Posted June 5, 2011 Author Report Share Posted June 5, 2011 Thanks for the pics, I'm interested in the rad Quote Link to comment
D52E Posted April 16, 2012 Report Share Posted April 16, 2012 I recently purchased one of these eBay radiators and i have to admit that I am a bit dissapointed with the fit. The radiator core depth placess it up against the fan clutch. I'm not sure i want to run an electric fan or move the engine rearward to make it fit. Does anyone have any ideas on a water pump/clutch that might be thinner? Quote Link to comment
CorAce Posted April 17, 2012 Report Share Posted April 17, 2012 Did you get the 2 or 3 row? I used the 2 and it just fit past the fan. I don't have a clutch on mine, so I might recommend removing that before you try to move the motor back. I ended up putting a electric fan on the front and doing away with the stock fan all together, Really pretty easy. Quote Link to comment
D52E Posted April 18, 2012 Report Share Posted April 18, 2012 I purchased the 2 row unit instead of 3 because I was worried about clearence. I figured that the swap was pretty common and other members would have mentioned difficulties with installation. Oddly enough, I serched the forum and didnt find any issues noted with clearence. I suspect most people run a stock plastc tank Fiero radiator and the core may be thinner so they might not encounter this problem. I havent decided yet what course of action to take. I dont think it would be too complicated to wire a fuse, relay, thermo switch and fan but would like to avoid it if at all possible. Ideally - I prefer the simplicity of running a stock fan clutch due to reliability and low complexity (keep it simple - less stuff to go wrong). CorAce - What fan did you use? Did you have to cut any metal to get it to fit behind the grille? How is the cooling performance at low speed and stop lights? Did you use a thermo fan switch? Where is the thermo switch located? Quote Link to comment
banzai510(hainz) Posted April 18, 2012 Report Share Posted April 18, 2012 datsunpartsllc has some chinese made ones that supposed to fit perfect Rods Discount Datsun has stock 3 core type also( Perfect fit drop in as I have one) works almost too good as I pulled it back out in winter Quote Link to comment
CorAce Posted April 20, 2012 Report Share Posted April 20, 2012 I purchased the 2 row unit instead of 3 because I was worried about clearence. I figured that the swap was pretty common and other members would have mentioned difficulties with installation. Oddly enough, I serched the forum and didnt find any issues noted with clearence. I suspect most people run a stock plastc tank Fiero radiator and the core may be thinner so they might not encounter this problem. I havent decided yet what course of action to take. I dont think it would be too complicated to wire a fuse, relay, thermo switch and fan but would like to avoid it if at all possible. Ideally - I prefer the simplicity of running a stock fan clutch due to reliability and low complexity (keep it simple - less stuff to go wrong). CorAce - What fan did you use? Did you have to cut any metal to get it to fit behind the grille? How is the cooling performance at low speed and stop lights? Did you use a thermo fan switch? Where is the thermo switch located? I just picked up a 10" slimline fan kit from Knecks, it came with fan, fan zip mounts, relay, wiring and stab in switch 185 (on) - 175 (off). make sure you get a pusher fan as it will need to go in front of rad. No cutting needed (unless that's what your into). just offset the fan to one side to clear the center strut. I put the switch on the inlet side without giving it much thought, and it seems to work fine, but you may want to research that further. All in all it works great, on a 75 degree day the fan wont kick on at all until I have been sitting at idle for over 5 min. and then it drops temp fast. Install was not to hard. I used some rubber fuel line split down one side to line the bottom of the rad and buffer the top brackets. A couple 1/4 X 20 bolts with over sized washers hold the bottom to the core support (some drilling) and the hand fabed top brackets to hold it down. I have had no problems with it in two years. Cool tip, if you take the stock lower hose and turn it around (end to end) you will see where to trim it for a perfect fit. and it leaves lots of room for alt upgrades. Quote Link to comment
