Hermistonkilla Posted November 28, 2012 Author Report Share Posted November 28, 2012 Ya I have another harness to put in it. Just kinda upset because I had to breakthrough my dash to put it out!! Thought about the bigger picture and panicked to save the truck. Quote Link to comment
Hermistonkilla Posted November 29, 2012 Author Report Share Posted November 29, 2012 Got the dash out and cleaned up the wiring got dark so ill wait till tomorrow and throw my broke down dash back in. Quote Link to comment
w_datsun_a Posted November 29, 2012 Report Share Posted November 29, 2012 Quick favor. While its out, can you take a few detailed shots of where/how the cigarette lighter is attached? Quote Link to comment
Hermistonkilla Posted November 29, 2012 Author Report Share Posted November 29, 2012 My lighter is not put together currently. I put the dash back in and plugged everything back up now my drive lights stay on all the time and the turns don't work at all..... Time to pull it back out and see what's up Quote Link to comment
w_datsun_a Posted November 30, 2012 Report Share Posted November 30, 2012 Oh, I don't really care if its put together correctly. I just want an idea of the structure behind it. Quote Link to comment
]2eDeYe Posted November 30, 2012 Report Share Posted November 30, 2012 The housing around the cigarette lighter unscrews from the piece that goes through the dash. It's behind the dash Quote Link to comment
w_datsun_a Posted November 30, 2012 Report Share Posted November 30, 2012 What does the housing that the lighter screw into look like? I am wondering if it will be able to be a mounting point. Sorry. I can take this to a new thread...not trying to threadjack. Quote Link to comment
Aibast Posted November 30, 2012 Report Share Posted November 30, 2012 I just removed my cars lighter and but in a starter button to its place. Its just about 6mm thick plastic with a hole where the lighter goes trough. That is all. The housing itself is just a sheatmetal tube with pressed end that screws on the lighters thread. Keep us posted on the wiring repair. As I just restored mine to original state and haven't realy tested it out. I have a new modern fuse box what I'll be butting in. If you have any good tips how to make it better and safer let us know. What I did was remove the incoming + cable (thick black one) that comes from the batteri from rest of the harnes and kept it separeate as much as possible. So it doesn't have any change to connect with anything without passing trough a fuse . Still thinking about adding an aditional 20-30A main fuse and a safety swich to cut of power from the whole car fast. Quote Link to comment
]2eDeYe Posted November 30, 2012 Report Share Posted November 30, 2012 What does the housing that the lighter screw into look like? I am wondering if it will be able to be a mounting point. Sorry. I can take this to a new thread...not trying to threadjack. The housing is screwed on in the pic, it has the ribs on it. Should be able to fit a large spark plug socket on it. You can see the threads for the outer housing and the inner housing threads sticking out on the right where the wire comes out. Quote Link to comment
Janksun Posted December 1, 2012 Report Share Posted December 1, 2012 I love this truck. I myself am about to purchase one with I think a Chevy V6! Quote Link to comment
Hermistonkilla Posted December 4, 2012 Author Report Share Posted December 4, 2012 so i took the dash back out and discovered that the headlights relay is some vatozone one and the headlight wiring is way jacked up! i am now looking for a whole new dash with hopefully (fingers crossed) wiring harness as unmolested as possible! going to check out some local yards out here in my area Quote Link to comment
]2eDeYe Posted December 4, 2012 Report Share Posted December 4, 2012 Good luck in your endeavour! :thumbup: Quote Link to comment
Hermistonkilla Posted December 5, 2012 Author Report Share Posted December 5, 2012 Pulled the dash off and took a couple of pictures of my mess. I think it can be saved.... I just don't know how. thats the back side of my head light toggle switch. this wire was plugged into the fuse panel as well. Believe it to be turn signal? The plug that had the headlight swotch wires going into it was melted where the blue and green wire went into it. I didn't take note if what was going into what (dumb) and now I'm lost Quote Link to comment
Hermistonkilla Posted December 5, 2012 Author Report Share Posted December 5, 2012 still looking for a dash with matching harness if someone has one!!! lol Quote Link to comment
Hermistonkilla Posted December 5, 2012 Author Report Share Posted December 5, 2012 does anyone have a picture of the headlight switch plug??? i found an old switch but am not quite sure where each wire goes to match up with the other. Quote Link to comment
Hermistonkilla Posted January 16, 2013 Author Report Share Posted January 16, 2013 Found a dash and have a plug that I'm not sure where it goes. this one is super long so it can just about reach anywhere in the cab Quote Link to comment
Hermistonkilla Posted January 17, 2013 Author Report Share Posted January 17, 2013 Got the dash in and the dash lights don't work or the headlights. But turn signals do? This thing is making me crazy!!! Quote Link to comment
Hermistonkilla Posted January 17, 2013 Author Report Share Posted January 17, 2013 Haha did some messing around and now I have head lights but no turn signals?? Quote Link to comment
Hermistonkilla Posted January 17, 2013 Author Report Share Posted January 17, 2013 Found an old thread that says the dash grounds after being bolted in.... Can anyone confirm this? Going to try it out when I get back home Quote Link to comment
Hermistonkilla Posted January 28, 2013 Author Report Share Posted January 28, 2013 Truck is sold. Goodbye first datsun love Quote Link to comment
