RadioRedline Posted April 6, 2011 Author Report Share Posted April 6, 2011 I will check Condensor. The Porcelain resistor is still there and no cracks. Coil Is Stock. It ran very well. The parts I swapped were: Plugs Wires Rotor Cap I have tried the Original Plugs just in case, same result. Thanks for all the Help Banzai. Radio Quote Link to comment
banzai510(hainz) Posted April 6, 2011 Report Share Posted April 6, 2011 I some times had proplem when I would put new points/condensor in it wouldnt run. Then I put the old one back in then it would run. Then I put the new one I just had back in then it would run. Fuck if I knew what the proplem was the first time. this has happen twice to me. Once I got rid of points I never had proplems like this, Point dizzys has 3 main things to look at. 1 dizzy wear. shaft is so loose it opens up the points when you dont want to thuse firing before or after it is needed. 2 Points wear/dwell. also if wrong ohm coil will cause to ARC inside cap.Its used just as a trigger so low current is all that is needed. 3 Condensor. Passes AC current but blocks DC current. Used to help keep the points from arching Worn dizzy bushing. Bad condensor makes it back fire ,poping where one thinks its it could be a carb Quote Link to comment
RadioRedline Posted April 6, 2011 Author Report Share Posted April 6, 2011 I have what I believe is an electronic Dizzy from a 1980 720 that my L20B came out of. So Maybe try that? Radio Quote Link to comment
banzai510(hainz) Posted April 6, 2011 Report Share Posted April 6, 2011 Put motor to TDC 11.28 on spindal timming mark on crank, Zero Put the new dizzy on with the mount it came with. you can mount it 2 ways on the front cover.So up to you where you want it o 180 deg where the vac adv is in a good position or the matchbox in a good position then when rorot rlocks down that should be your #1 and go 1 3 4 2 CCW If you have a MSD Blaster 2 coils oe a 720 coil then you dont use the ballast resisitor. if you dont have the EI coil , you would hook it up like a Pertronix and still use your stock coil with the ballast resisitor.(pull the wire from the -side that came from points) B goes to the plus side ballast C to minus side coil. Quote Link to comment
RadioRedline Posted April 8, 2011 Author Report Share Posted April 8, 2011 Condensors will be here Monday. Points Changed, and it was set for 6 Degrees instead of 4 in the Timing... Radio Quote Link to comment
banzai510(hainz) Posted April 8, 2011 Report Share Posted April 8, 2011 6 Degrees instead of 4 in the Timing...?????????????? never heard of 4 degress of dizzy timming? Quote Link to comment
RadioRedline Posted April 8, 2011 Author Report Share Posted April 8, 2011 Lol The Haynes Calls for 4? But I would never go Haynes vs. Banzai (L Motor God) Radio Quote Link to comment
RadioRedline Posted April 12, 2011 Author Report Share Posted April 12, 2011 Timing is fucked... http://www.youtube.com/watch?v=qU0uWd9wxjY L16 still no-start. After changing Plugs Cap Rotor Points Condensors Gapping everything checking the timing and its out, so It has to be a loose timing chain. Radio Quote Link to comment
banzai510(hainz) Posted April 13, 2011 Report Share Posted April 13, 2011 watch my vid again and ck it again. doesnt even sound like it want to fire. timming of mechanical ,oil pump /dizzy timming of eleltrical/points ck valve lash gas to carb should fire Your sure its getting gas?????? Quote Link to comment
Z chopper Posted April 23, 2011 Report Share Posted April 23, 2011 ya from the vid you posted it does sound like timing to me. I am sure you have gone over all this but...... are the valves opening and closing properly? are the plugs properly gapped? Quote Link to comment
Z chopper Posted April 25, 2011 Report Share Posted April 25, 2011 hmmm maybe try twisting the dizzy a bit while trying to start, I did this with a honda civic and it worked so I figure it might work with the truck hows the coil? Quote Link to comment
RadioRedline Posted April 25, 2011 Author Report Share Posted April 25, 2011 Coil Dwell was tested, and again Spark is Great. I can try the Turn trick? Radio Quote Link to comment
wayno Posted April 25, 2011 Report Share Posted April 25, 2011 Hi there Radio, try this. While the key is on and you have spark, jump the starter with a screw driver, or better yet, use a remote starter switch. If it starts let me know and I will tell you what the problem probably is. Don't use the key to start it. I just thought of this, another route you can use is to hotwire the coil from the battery buy connecting a wire from the positive side of the battery to the positive side of the coil, then you can use the key to start it. What you are trying to do is make sure that the coil has power while you are turning it over, sometimes a wire(black with red line i think) gets disconnected from the coil somehow, this wire supplys power to the coil while the engine is being turned over with the key. Quote Link to comment
banzai510(hainz) Posted April 25, 2011 Report Share Posted April 25, 2011 something is hooked up/lined up wrong. this is a simple fix Quote Link to comment
DanielC Posted April 25, 2011 Report Share Posted April 25, 2011 Compression, ignition, fuel. Supply all three in the proper amount and time, and the engine will run. Millions of engines prove that every day. I just listened to your video. Your battery sounds weak. The engine cranks fairly fast at the beginning, and then slows down, pretty early. It should crank strong for a while. Check your compression. The minimum recommended by the factory service manual I have is 159 PSI, and no more than a 20% variance. A L-16 will run with lower compression, but not much lower, and it will use oil, more gas, and run poorly The spark should easily jump a 1/4 to 3/8 gap. It should happen about 10 degrees BTDC. If you have the above two conditions met, a teaspoon to a tablespoon of gas dumped down the carburetor should make the engine run briefly. Quote Link to comment
banzai510(hainz) Posted April 25, 2011 Report Share Posted April 25, 2011 I had a car once where the HOT start wire was wire to the + side of the ballastin stead to the + side coil. meaning it would never see a Full voltage during START. Quote Link to comment
Z chopper Posted April 25, 2011 Report Share Posted April 25, 2011 try advancing the dizzy? though I'd love to know if the truck starts and runs, for purely selfish reasons I kinda hope it don't atleast till I can figure out how to come buy it from you and get it home. Quote Link to comment
wayno Posted April 26, 2011 Report Share Posted April 26, 2011 Funny thing about that wire coming off my coil was, it would start no problem when it was warmed up, but when it was cold I had to hotwire the coil to get it to start, a full 12 volts. Then one day I was fiddling around and found the disconnected wire, looked it up in the wiring diagram, connected it up, and have never had to hotwire the truck again. But the real problem was that it would hit sometimes when I let off the key at the right time, so I never put it together, I just thought that the starter was taking/hogging all the juice. Quote Link to comment
RadioRedline Posted November 1, 2011 Author Report Share Posted November 1, 2011 Pulling this THREAD back from the Dead! SAME ISSUE: http://www.youtube.com/watch?v=qU0uWd9wxjY You all know what I've done to try and get my Green Pickup running again. (If not read this thread) Recap! I checked the Points Gap I checked the Spark Plug Gap I checked the firing order I checked the Wire connections I took off and examined the porcelain resistor I cleaned the battery cables up I checked for spark 10 times & its getting spark. There IS Fuel in the Bowl There IS Fuel in the Filter We checked dwell and it's a-ok.... ***NEW PART*** If I change the Distributor to a brand new unit that works 100% (http://www.ebay.com/itm/Distributor-Nissan-Pickup-Truck-510-521-4Cyl-1-6L-L16-/190588040169?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2c5feeb3e9#ht_2721wt_1413) WHAT will be left to change if this doesn't work? Thanks! :) Radio Quote Link to comment
banzai510(hainz) Posted November 1, 2011 Report Share Posted November 1, 2011 WHAT will be left to change if this doesn't work? The Owner. laying on the starter like you did in the vedio isnt going to do any thing. if it dont even sound like sparking off your just overheating/draning the system. take the coil wire and show us(vedio) the spark when starting. Or show us the HOT wire is getting 12volts with key in START(disconnect STARTER wire) show the blk white wire with key ON 12volts). IF you have spark then show us the distrbutor spindal in the 11.28 position then install the dizzy and show us how you put the wires on. next is valve lash. intake tight Carb tight. accel pump work on carb(should light off if enough gas is dumpoed in there, the fumes should ignite) set all this up and video tape this. This is a simple15min job unless theres all holes in the pistons or soemthing. sparkplugs? Quote Link to comment
H5WAGON Posted November 1, 2011 Report Share Posted November 1, 2011 Small wire from Dist. body to points may be toast....not letting the points do there job....test with ohm meter. Could also have a bad connection at that spot.....check clean (Take plastic block out of Dist....inspect bolt, clean if dirty) The bolt holding the wire onto the plastic little block on my Dist. was dirty..(Power coming in)..dropping voltage down to 6-7 volts at the points, not enough to fire off the coil. Quote Link to comment
banzai510(hainz) Posted November 1, 2011 Report Share Posted November 1, 2011 H5wagon he said he has spark(hopefully at the coil end) so that means everything in the dizzy in theory is working. Quote Link to comment
RadioRedline Posted November 1, 2011 Author Report Share Posted November 1, 2011 I have spark at the coil end. Quote Link to comment
banzai510(hainz) Posted November 2, 2011 Report Share Posted November 2, 2011 I say se the motor up to TDC so we can see the dizzy spindal. Get vid camera ready. Intsll dizzy put the wires on and show us the fire order then take the center wire place to ground so we can see the spark. This is a EZ fix your missing something. Fire order correct? get the vid camera out Quote Link to comment
banzai510(hainz) Posted November 4, 2011 Report Share Posted November 4, 2011 UPDATE ON THIS????????????? lets get a vid of whats going on I wonder if the cam snapped in half Quote Link to comment
