fiveoneohray Posted February 17, 2007 Report Posted February 17, 2007 plans for the red car: building a sr22 with ITB's the wagon is back under the knife, took out the vg30 and building a vg34 for it. Quote
Icehouse Posted February 17, 2007 Author Report Posted February 17, 2007 plans for the red car: building a sr22 with ITB's the wagon is back under the knife, took out the vg30 and building a vg34 for it. Its a vg34? I thought it was going to be a 33, is it going to be EFI? Quote
Green Bastard Posted February 17, 2007 Report Posted February 17, 2007 One recent pic. Brake rotor is actually for the left side, no pads, line or anti-swaybar link installed. Quote
fiveoneohray Posted February 18, 2007 Report Posted February 18, 2007 nah its a vg33 bored out to use the vh45de pistons which makes it a 3.4L but when I talked to a machinist about the notches for the valves we both decided it wouldnt be reliable enough since the material left would be pretty thin. We then contacted JE and had custom pistins cut (retarded expensive :( ) and raised the compression to 10:1 (for putting it on the bottle). The bore size actually makes it more like a vg35 but I will just stick to the vg34 tag for now. Also I am going to use the Autronic that I just bought. I sold the old carb setup with my vg30 and that was the last distributor for carbs that Nissan Motorsports had. Quote
Green Bastard Posted February 19, 2007 Report Posted February 19, 2007 All fixed now, ready to roll!;) Quote
Icehouse Posted February 19, 2007 Author Report Posted February 19, 2007 All fixed now, ready to roll!;) Is that your green car? I remember you saying you wanted to upgrade the brakes but shit! I though you meant like zx or something, wow. Did you ever get a chance to dyno your car? Quote
Green Bastard Posted February 19, 2007 Report Posted February 19, 2007 Is that your green car? I remember you saying you wanted to upgrade the brakes but shit! I though you meant like zx or something, wow. Did you ever get a chance to dyno your car? That is the green car. My only Datsun:eek: I have been developing my "big brake kit" for a while and this is it. It is part 280ZX, but only the strut housing and hub. No dyno yet. Trying to stick to one project at a time. Once this is done, I will get a baseline pull, then start tuning. I have everything I need to build my own fuel and spark maps, then burn EPROM's. If I am successful at making more power, I will be able to duplicate it for others. Quote
Bleach Posted February 19, 2007 Report Posted February 19, 2007 what is this only Datsun thing you speak of? ...are you telling me that some people actually have only ONE Datsun at a time?!? wow... you're a better man than me Nice brakes though! They're more expensive than some 280ZX's! :) Quote
slodat Posted February 19, 2007 Report Posted February 19, 2007 They look great! How do the work? ie: do you like them? Any issues? I try to convince people that one project at a time is the way to go.. They no listen! Quote
Green Bastard Posted February 21, 2007 Report Posted February 21, 2007 They look great! How do the work? ie: do you like them? Any issues? You mean you drive these old ass cars?:eek: I thought once it looked good, you were done. Kidding of course, I will give you the report when the weather clears. :o Maybe in the "Brakes" section. Threadjacker. Quote
Jason Posted February 25, 2007 Report Posted February 25, 2007 Well, the 1969 wagon is now on the road, smogged and insured. She's keeping my brown 4 door company :) ! Quote
Icehouse Posted February 25, 2007 Author Report Posted February 25, 2007 Jason I need to talk to your wife, going to tell her to get you a torch for Christmas so you can heat those springs up :D A good 4 inches would do. :) Quote
Icehouse Posted February 25, 2007 Author Report Posted February 25, 2007 next time you are down Jason I got a set of 3" blocks you can have for the wagon :D Quote
Jason Posted February 25, 2007 Report Posted February 25, 2007 Guess ya'll don't like the ole' stock height wagon eh ;-)! Believe it or not, the 4 door is lowered, Quote
Jason Posted February 25, 2007 Report Posted February 25, 2007 On that same note, when you lower a wagon, do you have the same camber/toe problems as with the IRS in the sedans? Quote
Icehouse Posted February 26, 2007 Author Report Posted February 26, 2007 Guess ya'll don't like the ole' stock height wagon eh ;-)! Believe it or not, the 4 door is lowered, Quote
Jason Posted February 26, 2007 Report Posted February 26, 2007 Jeff, 2.5cm = an inch, that's a pain to remember so cm's work easier being math challenged. First things first, gotta replace the damn tires. Then I have to find some front springs, I want something in the 140-150lb range this time, maybe get the nose down a touch first? While I'm at it I have to do the ball joints, damn things are worn out and the bushings and bearings while I've got it apart as well as have the rotors turned and re oil the front dampers with 20w oil. Hmm... no camber/toe change huh, I think the way to go is to stack another leaf in there first to stiffen it up a bit (after I change the shocks of course)! You use blocks to lower the spring pack then Jeff? Does that stiffen the apparent rate any? Quote
Icehouse Posted February 26, 2007 Author Report Posted February 26, 2007 The blocks are not a really good idea, well in the performance department, they amplify axle wrap and wheel hop. I know how you drive, you don't need to increase performance. We are going to for style :) I put a 3" on top of a 1" block, its been like that for 3 years on a daily driver haha. I am working on a better fix. The biggest problem with the wagon is: To slam a wagon the rear seat and tranny tunnel need to be modified for the axle and driveline. We are going to get is leafs rearked and do a little mod on the floor and tranny tunnel, add disks and put in some new shocks. Since it is his daily driver it is hard to do a lot of mods. We are working on it though. Quote
Jason Posted February 26, 2007 Report Posted February 26, 2007 Heh, that's me stylin' in a 38 year old car ! Heck, the way I drive, doesn't matter much if it's lowered, you got me there, but, the suspension and steering is way worn out on this beast, so replace all that stuff first and then figure out the "Stylin'" part eh! If you're going to go through all that trouble rearched, why not just get new leaf springs made. I hear that it wasn't all that expensive and all you did was tell the guys what rate you wanted and at what height. If you have to modify the floor and tranny tunnel how low you guys going here? Quote
ramseys21 Posted March 30, 2007 Report Posted March 30, 2007 this is my 72 dato. need ideas for 1600 upgrades until i get my sr here and in the car. :D thinking dual carbs and a racing header so far. so let me know to your ideas. ill post a project thread later tonight. i gotta go to class. Quote
RB_Shaggs Posted March 31, 2007 Report Posted March 31, 2007 whats the orange one in the background Quote
freekwonder Posted March 31, 2007 Report Posted March 31, 2007 new guy. I'm on another 510 forum that some might recognize the name. Here is my dime, hopefully I'll be picking up my s14 KA24DE, tranny, ecu, wiring harness in a week or two. And yes I have pulled the front air dam off. Quote
ramseys21 Posted March 31, 2007 Report Posted March 31, 2007 whats the orange one in the background haha good eye. that was my 1970 2dr. we had title problems with that one. im looking for another 2 dr. heres a pic. hehe possibly a SSS. if i can find one. Quote
