my 40mm mikuni score !!!!!
  • Replies 18
you can buy rebuild kits from wolf creek racing and a linkage kit (Center pull kit) from Troy Ermish get rid of that old linkage kit comes with cable and all the parts, I have it on my wagon and have only had to tune them once and the are way easier to syncronise*
Clayton
Troy may also have a rebuild kit for 40s too
Clayton
Do you know offhand about how much the linkage kits are?
about 100$ -7 years ago from Troy its just a Toyota 18RG enter pull kit. Kinda cheezy really
also make sure your mikunis the linkage can be changed to the center.
I have a set where it will not work(i think) If I remeber right the ends are wedged on and cant unsrew the nut.
photo on left
This manifold(Cannon) has to be cut to get full movement otherwise it will hit the center
I just left the bar on there
I've been to Overseas Auto... they're pretty cool, seem to know what they're talking about.
Just because I happen to have a card: 1.604.879.6288 or http://www.overseas-auto.com
Or... Specialty Engineering, also up here... they seem to be a little bit more on top of the Datsun scene... 1.604.521.9232
photo on left
the old kit was a take off on the toyota stuff I think, he has them punched now but the rest is the same and I think they are around $125 with the cable and everything else
