DREWSDIME Posted February 26, 2011 Report Share Posted February 26, 2011 I have a 1968 510 and I need to replace the ball joints. I have brand new ball joints already for a 1970-73 510 but they are bigger than the 68 ball joints. Can I just swap control arms? I have a extra set of 70-73 control arms that I can use. Quote Link to comment
Icehouse Posted February 26, 2011 Report Share Posted February 26, 2011 I just swapped later control arms onto my 68, the ball joint taper is different. you will need to find later steering knuckles but the later LCA's have better bushings. Quote Link to comment
INDY510 Posted February 26, 2011 Report Share Posted February 26, 2011 . I think 68-69 are 11mm and 70-73 are 14mm .... .. . the steering arms will need to be changed also ...... ... .. it'd be cheaper to just get new ball-joints Quote Link to comment
DREWSDIME Posted February 26, 2011 Author Report Share Posted February 26, 2011 Where can I get the 11mm ball joints? Quote Link to comment
datzenmike Posted February 26, 2011 Report Share Posted February 26, 2011 . I think 68-69 are 11mm and 70-73 are 14mm .... .. . the steering arms will need to be changed also ...... ... .. it'd be cheaper to just get new ball-joints Ahhhh, then the early 510s won't fit the early 610/710s. Sorry INDY. Quote Link to comment
thisismatt Posted February 26, 2011 Report Share Posted February 26, 2011 . I think 68-69 are 11mm and 70-73 are 14mm .... .. . the steering arms will need to be changed also ...... ... .. it'd be cheaper to just get new ball-joints How are new ball joints cheaper than swapping steering knuckles? Quote Link to comment
hang_510 Posted February 26, 2011 Report Share Posted February 26, 2011 How are new ball joints cheaper than swapping steering knuckles? if ya have to buy the knuckles first after having spent hours not finding 11mm BJ's Quote Link to comment
benzo Posted February 26, 2011 Report Share Posted February 26, 2011 check parts houses to get the 11mm ones, I got 11mm ones for my car from my parts house. they were beck arnley units. Quote Link to comment
