oldschool90 Posted January 28, 2011 Report Share Posted January 28, 2011 So I change the tranny fluid in my truck today and this stuff was on the drain plug: Most of it I'm not worried about, just that large chunk. The circle is a penny for size reference. What do you guys think that is? Quote Link to comment
INDY510 Posted January 28, 2011 Report Share Posted January 28, 2011 . I wasn't shure what to expect when I clicked on this thread........ :lol: Quote Link to comment
oldschool90 Posted January 28, 2011 Author Report Share Posted January 28, 2011 . I wasn't shure what to expect when I clicked on this thread........ :lol: In hindsight, not the best name for a topic ollz Quote Link to comment
Jayden71 Posted January 28, 2011 Report Share Posted January 28, 2011 . I wasn't shure what to expect when I clicked on this thread........ :lol: X2!! :rofl: I dunno what that would be, I have never had that happen Quote Link to comment
datzenmike Posted January 28, 2011 Report Share Posted January 28, 2011 Does PARK work on your automatic? Does it lock the tranny and hold it on an incline? Quote Link to comment
oldschool90 Posted January 29, 2011 Author Report Share Posted January 29, 2011 Didnt mention it sorry, its a manual tranny Quote Link to comment
datzenmike Posted January 29, 2011 Report Share Posted January 29, 2011 That is the weirdest thing. I assumed it was an automatic, I was sure it was.Looks like it might be a piece of bearing cage. Does it growl or make any noise? Quote Link to comment
oldschool90 Posted January 29, 2011 Author Report Share Posted January 29, 2011 That is the weirdest thing. I assumed it was an automatic, I was sure it was. Guess you learn something new every day :) Does it growl or make any noise? Nope. the only thing I can think of is when its in 5th gear, when you give it gas the shifter will push back bout 1/4-1/2" with quite a bit of force, and when you let off it goes back. Quote Link to comment
Farmer Joe Posted January 31, 2011 Report Share Posted January 31, 2011 lol i love extra parts from places unknown... looks like a needle from a bearing, and then i have no clue what that flat piece is... weeeiiiirrd... Quote Link to comment
datzenmike Posted January 31, 2011 Report Share Posted January 31, 2011 Looks like a ball bearing cage. It supports the balls inside the two races and keeps them spaced. There's one on each side and they wrap around each ball with rivets between. I have a picture of one stuck to the drain bung. If it has holes in it, thats likely what it is. Quote Link to comment
blue72 Posted January 31, 2011 Report Share Posted January 31, 2011 Yep, that's my hypothesis too. I just looked through pictures from when I tore my 5 speed apart, and everything else inside the transmission is large gears and shafts, no other pieces of thin metal aside from the bearing cages that I could see. Quote Link to comment
oldschool90 Posted January 31, 2011 Author Report Share Posted January 31, 2011 Makes sense. Good thing I didnt find any bearings then. Dont feel like rebuilding the tranny. Quote Link to comment
datsunaholic Posted January 31, 2011 Report Share Posted January 31, 2011 Well, if that IS a piece of the bearing cage (and that's what it looks like) the bearings themselves are not far behind. You likely have far less than 10,000 miles before that transmission bites the dust. It's not a matter of if. It's going to go- soon. Then you will have LOTS of parts to replace. By replacing the whole gearbox, most likely. Right now, all that has to be replaced is the bearing (and seals). Quote Link to comment
oldschool90 Posted February 1, 2011 Author Report Share Posted February 1, 2011 Great. Well thanks for the info guys and I guess Ill be looking into transmission bearings soon. Quote Link to comment
oldschool90 Posted March 3, 2011 Author Report Share Posted March 3, 2011 Well, if that IS a piece of the bearing cage (and that's what it looks like) the bearings themselves are not far behind. You likely have far less than 10,000 miles before that transmission bites the dust. It's not a matter of if. It's going to go- soon. Guess what? My 5th gear is now popping out under acceleration. Any ideas on what it could be? All the other gears are fine. Quote Link to comment
wayno Posted March 3, 2011 Report Share Posted March 3, 2011 I would quit driving it unless you were planning on replacing it rather than rebuilding it, it seems it is getting looser with every revolution, I wouldn't be suprised if your recently replaced transmission fluid wasn't silver/gray now. Find another tranny soon. wayno Quote Link to comment
datsunaholic Posted March 3, 2011 Report Share Posted March 3, 2011 The popping out of gear is probably because one of the shafts has now lost the bearing cage in its entirety and it's moving radially. The whole shaft is moving up and down. That's causing the shift rod to be pushed out. Shortly, the bearing will fail, taking out most of the gearbox. If you're lucky it'll just lose that gear, but I wouldn't bet on it. More likely it will send debris through at least one gear set chipping teeth and chewing up the shafts. Worst case it will jam and lock up the transmission, even at highway speeds that makes for an abrupt halt. I knew at least one person who had that happen, though that one was a 63-series trans not a 71B. I bet the gearbox is making all sorts of noise but you can't hear it over the engine (this is a diesel, right?) Those transmission are fairly hard to come by. Yes, you can use the gears and rear case from a gas one, but if you destroy the front case (which houses the front bearings) you will need an entire gearbox. Stop driving it unless you don't mind being stranded at any time. It's going out. Quickly. Like, hundreds of miles quickly. I've blown one of these 71B transmissions up. It still moved under power, but there wasn't a usable part left inside. And that one went with no warning whatsoever. Quote Link to comment
inline4 Posted March 3, 2011 Report Share Posted March 3, 2011 a little off topic, but how much should bearings and seals cost if a shop was to replace those on a KA24 tranny? Quote Link to comment
datzenmike Posted March 3, 2011 Report Share Posted March 3, 2011 If highway driving stay in 4th. as this reduces side load. Power flows in a straight line through the tranny. Do not use 5th. But as Doug says only a matter of time. I've had this problem too, jumping out of 5th. That will be one of the counter or main bearings bearings in the adapter plate right next to the 5th gear. Within two weeks it started jumping out of 2nd. I had to hold it through 2nd to get to 3rd. ASAP I replaced with a 280z 5 speed I had. Quote Link to comment
oldschool90 Posted March 3, 2011 Author Report Share Posted March 3, 2011 (this is a diesel, right?) Nope. Its gas. So basically my transmission is shot, as in I cant just replace parts? Quote Link to comment
datzenmike Posted March 3, 2011 Report Share Posted March 3, 2011 Probably easier to replace it with a used one. A four speed will fit exactly if you can't find a 5. They are fixable but you will have to dismantle it. If it's the rear counter shaft bearing it's easier to get at. Bearing is probably $20. Best to replace a few of them while out. Quote Link to comment
datsunaholic Posted March 3, 2011 Report Share Posted March 3, 2011 Sorry, though I saw SD22 in the profile. Z22, the trans is common. Therefore easier to simply replace. Quote Link to comment
