SHAMUS'WAGON Posted January 14, 2011 Report Share Posted January 14, 2011 This engine is finally disassembled. $10.00 + shipping for the main bearing end caps. $15.00 local pick up for the crankshaft. Block has been $crapped. All part are located in Vancouver, WA I'll consider delivery if it's close, and you wanna pay for the gas. If your interested in any of these parts. Send me a PM with your phone number. So, I bought this motor from some guy in Oregon City. When I went to pick it up he told me, "It ran when we pulled it. Should be fine to just drop it in" Well I went with my gut, and just used the A87 head that was on it. I put this L16 on the back burner until I tore into it for timing parts in a pinch. This is what I found out. Oversized timing cover bolt that I had to shear off to remove the cover. Sheared off Timing chain oiler I don't really have the time or money to put in to this project. So it's going away too. I noticed that it has different pistons than my L16 too. I figure they're probably good for building compression. I have no desire to build a high compression motor. Location Vancouver, WA 98683. Link to comment
pharouh Posted January 14, 2011 Report Share Posted January 14, 2011 "It ran fine when we pulled it" Where have I heard that before? Oh yeah,from the guy I bought my L16 from. The one with the combustion chamber filled with sand and the broken exhaust valve! :rofl: i know how you feel man! GLWS! Link to comment
datzenmike Posted January 14, 2011 Report Share Posted January 14, 2011 This is what I found out. Oversized timing cover bolt that I had to shear off to remove the cover. Sheared off Timing chain oiler That's the 12 mm timing cover bolt and they can easily rust and seize into the block. It's not unheard of to snap them. The oil peg can snap off because they are hollow. A noob dropping the tensioner and trying to fix could cause this. Turn a small bolt in and pry out a new one just taps into place. Some L motors don't even run them as enough oil comes down from the valve cover and the tensioner. Measure the bore. Those pistons aren't stock I think. Could be forged? Link to comment
SHAMUS'WAGON Posted January 14, 2011 Author Report Share Posted January 14, 2011 I was wondering if Hainz had anything to say about the pistons. Link to comment
banzai510(hainz) Posted January 14, 2011 Report Share Posted January 14, 2011 they almost look like a L18 pistons. like a 4cc dish. Ok Im going to guess that its a stock L18 piston since it dont have a oversize on it. So it should measure 85mm across.So the block was bored 2mm over since stock L16s are 83mm I think its a nissan part as the motorsport book shows pistons with valve reliefs. Since its used I wouldnt think it was a winning jack pot$$$$But I would keep them if you have 94 octane I might run them in a L20 L16s were 7cc dished. Link to comment
pharouh Posted January 15, 2011 Report Share Posted January 15, 2011 Sorry man, Not meaning to threadjack(again) but is that what these are in my L16? My other on has dished ones. 1 Link to comment
datzenmike Posted January 15, 2011 Report Share Posted January 15, 2011 Measure the bore. Those pistons aren't stock I think. Could be forged? Link to comment
SHAMUS'WAGON Posted February 28, 2011 Author Report Share Posted February 28, 2011 BUMP! Still for sale. Disassembling in a couple of days. I've been putting it off too long. Link to comment
datzenmike Posted February 28, 2011 Report Share Posted February 28, 2011 or just the pistons for $20.00. Location Vancouver, WA 98683. If I see no interested buyers within a week. The block will be dismantled for scrap. Link to comment
SHAMUS'WAGON Posted June 16, 2011 Author Report Share Posted June 16, 2011 BUMP! price reduced.... moving Link to comment
flatcat19 Posted June 16, 2011 Report Share Posted June 16, 2011 BUMP! price reduced.... moving Dude, I tried to get these from you back in March when i was on a vacation down there in March. Link to comment
banzai510(hainz) Posted June 16, 2011 Report Share Posted June 16, 2011 thats a good block. Thats minor what needs to be done. pistons are fine but most likely cast which is FINE also. soembody pick it up and get the bolt and oiler out and they will be fine. Im sure it ran when pulled.be honest the l16/18s ast longer than the taller blocks as they are now cracking Link to comment
datzenmike Posted June 16, 2011 Report Share Posted June 16, 2011 BIMP Peter Sellers quote?????? Link to comment
SHAMUS'WAGON Posted June 16, 2011 Author Report Share Posted June 16, 2011 thats a good block. Thats minor what needs to be done. pistons are fine but most likely cast which is FINE also. soembody pick it up and get the bolt and oiler out and they will be fine. Im sure it ran when pulled.be honest the l16/18s ast longer than the taller blocks as they are now cracking I'm sure it's a good motor. I just dont have time to mess with it. I also have two other builders sitting in my garage, and I have no interest in those pistons. I hope someone comes to get it so I don't have to scrap it. Link to comment
sdrawdy521 Posted July 23, 2011 Report Share Posted July 23, 2011 Do you still have the engine? 1 Link to comment
SHAMUS'WAGON Posted August 26, 2011 Author Report Share Posted August 26, 2011 bump Updated Link to comment
hang_510 Posted August 27, 2011 Report Share Posted August 27, 2011 It's not unheard of to snap them. The oil peg can snap off because they are hollow. timing chains with broken/missing tensioners will break them off too... :rolleyes: easy to replace, last year were still avail from nissan. Link to comment
SHAMUS'WAGON Posted September 1, 2011 Author Report Share Posted September 1, 2011 Somebody please come get this stuff so I don't have to scrap it. Link to comment
Z chopper Posted September 1, 2011 Report Share Posted September 1, 2011 Somebody please come get this stuff so I don't have to scrap it. I would but you are in the wrong Vancouver for me Link to comment
