71 2 door - box flares - coilovers - 4wheel discs
I have a 71 2 door box flared car that I have purchased fairly recently and done a TON of work to, but I might have to make it go away pretty quick. I'm looking to see what you all think it's worth and or if anyone is interested in it.
 My car still needs a few things tho. I have alot of money and time into it, but it still needs a couple things before it's considered finished.
It needs:
-a lil body work on the rear quarters and tail light panel
-a new exhaust (had 3 quotes around $175-250)
-and a good tune on the carb
But it has all of the hard work done!
Engine & trans:
-L20B swap
-header
-weber 32-36 carb
-k&N air cleaner setup
-sirocco alum radiator (common 510 swap)
-new cap, rotor, plugs, wires, points, condenser, coil, and ballast resistor all in the last month
-4 speed close ratio tranny
-newer clutch with 2,000 miles on it
Suspension & brakes:
-280ZX ST conversion
-full coilovers
-completely custom rear controll arms w/ inboard coilover system
-ZX front brakes
-DTT rear disc conversion
-calipers, rotors, wheel bearings, lines, pads, and hardware is new last month
-R200 3.91 ratio bulletproof diff swap
-slotted crossmember
-brand new ARP race wheel studs
-comes with power booster and master conversion but I haven't installed it
Other:
-New $500 black headliner
-custom door cards
-custom seat uphostery in black/dark brown
-evetything works; heater, lights, wipers, fan, flashers, etc..
-16x9 custom deeeep dish wheels
-brand new glass front valance
-brand new BRE spook front lip kit
-newer very nice black carpet
It is all in all a very nice little car. this is by far one of the cleanest ones I've seen recently. It's ALMOST done! I was planning on keeping it and daily driving it and next winter doing an SR20DET swap in it, but I have a chance to buy a C5 Z06 at a steal so I have to liquidate toys rapidly to do so.
Personally I was thinking somewhere in the $3200-3400 range for it??
Tell me if I'm crazy. It's a runner and driver!
  • Replies 37
Guest kamakazi620
It needs:
Engine & trans:
-L20B swap
-header
-weber 32-36 carb
-full coilovers
-ZX front brakes
Other:
-custom door cards
Uhhhhh...................Yer Crazy
Grats Dislexic! At first I was like 'wah?" on the hood and then saw the mudflap girls and was like :thumbup: !
Nice one! One thing on those box flares I'd like to see is a better integrated gas door!
