Horrible Tire Bite!!!
this bite is getting worse as it is SLICING my tire some new tread designs!!! Its sliced it almost all the way through the tread depth!! so much that i do not think it is safe to drive anymore, so it sits until its fixed! I need to figure out something to stop this from happening ASAP and ACAP!! (as cheap as possible), i was thinking of pushing the flare out more with some kind of brace bar welded in the trunk??
Pics of damage -- as you can see i need the flare to come out about an inch.
  • Replies 17
Im pretty sure he likes the wheels too, and so do many others. A very cheap fix until you have more money would be to make a bump stop that wont let the fender and tire to touch. That will make the car drivable. With more money you can move the fender location and flare it out more, or change the flares. ZG flares I believe cut out more on the body? but would also mean more travel distance.
This is what happens when you disobey the rule that form follows function. Form, (tires and rims in this case) were selected for their looks, availability or cost without considering their ultimate function. (clearance on a flexing suspension in this case). Form should always be secondary to function lest function be compromised.
I did actually follow the rule of functionality. my drivers side flare clears perfectly Hellaflush!, its the passenger side flare that was put on after getting the wheels that doesnt stick out as much i dont know why..
LINK for ZG flares??????????????????? edit: the cheapest lol
Just out of curiosity what offset are those rims ? it looks like you already have some sort of flaring done and its not even close to fitting.
rear has 2" backspacing. which is a -51mm offset. yes i have the BRE style flaring, which clears those wheel on the drivers side perfectly, but not the passenger side.
