fcwankel Posted January 14, 2008 Report Share Posted January 14, 2008 So i have a 76 RHD Silvia or 77 200sx in the U.S but whatever. so I hadent started her up for around a couple of months, Just 2 days ago i tried turnin it on but it wouldnt it would idle bt thats about it. I tohught maybe its the carburetors ! I buy car. spray but still nothin..... its an L20B with dual car. webers..... I jjust need to no whats wrong !!!??? please ....... thanks ! Quote Link to comment
fcwankel Posted January 14, 2008 Author Report Share Posted January 14, 2008 :mad:my car wont strat no more Quote Link to comment
Duke Posted January 14, 2008 Report Share Posted January 14, 2008 sell it to me, it will make it all better... Quote Link to comment
fcwankel Posted January 14, 2008 Author Report Share Posted January 14, 2008 lol no . So ..... my car wont stsrt anyone knows why lol ? Quote Link to comment
LeDevil Posted January 14, 2008 Report Share Posted January 14, 2008 Check your fuel lines and filter something might have settled and clogged them. Also check for fuel and spark, will it run if you hold your foot on the pedal we need more info. Quote Link to comment
Guest DatsuNoob Posted January 14, 2008 Report Share Posted January 14, 2008 Nothing a little (or alot) ether couldn't fix. Quote Link to comment
fcwankel Posted January 14, 2008 Author Report Share Posted January 14, 2008 Check your fuel lines and filter something might have settled and clogged them. Also check for fuel and spark, will it run if you hold your foot on the pedal we need more info. Well it has half a tank of fuel . Ill check the fuel liness. filter 1st thing after school tmmorow. maybe this will help . Quote Link to comment
LenRobertson Posted January 14, 2008 Report Share Posted January 14, 2008 If the car was running just a couple of months ago, I can't imagine much could have gone wrong with the carbs.Can you hear your electric fuel pump running? I don't know if your pump turns on with the key, or if it has a separate toggle switch to turn the pump off and on. If there is a separate switch, the switch may have gone bad. Plugged filter is possible. I had that happen with my '79 200SX this summer. Take the fuel line loose at the carbs, hold it into a coffee can, have someone turn on the key or pump switch and you should get a good stream of gas coming out of the hose. With an electric pump, you shouldn't have to actually crank the engine over to get fuel. Be very careful of fire if you should crank the engine. I don't know exactly what electronic ignition you have. Could be an ignition problem, but since the engine runs somewhat at idle, I would check for fuel first. Len Quote Link to comment
DanielC Posted January 14, 2008 Report Share Posted January 14, 2008 Three things an engine needs to run. Compression, fuel, and ignition. The engine's compression is the most difficult to check, you need a compression gauge. Auto zone sells an ignition tester, you can use it to check for a good spark. There is a chance the timing is way off, but if the engine ran last time you started it, and not now your timing would not change just from sitting. The spark output might. Check it. One quick check you can do it to try to start the car, and then go and smell the exhaust. Smell gas, and the ignition is might be bad. Do not smell gas, and the carb, or fuel system might be bad. I do not know if you can see where the accelerator pump squirts gas into the carb, if you can see if the carb squirts gas, that might give you a clue if the engine is getting gas. Quote Link to comment
kiznook Posted January 14, 2008 Report Share Posted January 14, 2008 Three things an engine needs to run. Compression, fuel, and ignition. and timing! my vote on this one is fuel Quote Link to comment
fcwankel Posted January 14, 2008 Author Report Share Posted January 14, 2008 Three things an engine needs to run. Compression, fuel, and ignition. The engine's compression is the most difficult to check, you need a compression gauge. Auto zone sells an ignition tester, you can use it to check for a good spark. There is a chance the timing is way off, but if the engine ran last time you started it, and not now your timing would not change just from sitting. The spark output might. Check it.One quick check you can do it to try to start the car, and then go and smell the exhaust. Smell gas, and the ignition is might be bad. Do not smell gas, and the carb, or fuel system might be bad. I do not know if you can see where the accelerator pump squirts gas into the carb, if you can see if the carb squirts gas, that might give you a clue if the engine is getting gas. Yeah i tried the smell trick. I tried starting her up again but still nothin. SO i went to the exhaust and it smelled like pure gas was comin out. Quote Link to comment
fcwankel Posted January 15, 2008 Author Report Share Posted January 15, 2008 If the car was running just a couple of months ago, I can't imagine much could have gone wrong with the carbs.Can you hear your electric fuel pump running? I don't know if your pump turns on with the key, or if it has a separate toggle switch to turn the pump off and on. If there is a separate switch, the switch may have gone bad. Plugged filter is possible. I had that happen with my '79 200SX this summer. Take the fuel line loose at the carbs, hold it into a coffee can, have someone turn on the key or pump switch and you should get a good stream of gas coming out of the hose. With an electric pump, you shouldn't have to actually crank the engine over to get fuel. Be very careful of fire if you should crank the engine. I don't know exactly what electronic ignition you have. Could be an ignition problem, but since the engine runs somewhat at idle, I would check for fuel first. Len No i had a switch but it gave m that problem so i got an electric fuel pump,when i turn the key i can hear it, also it idles but i know its not the fuel. Quote Link to comment
fcwankel Posted January 15, 2008 Author Report Share Posted January 15, 2008 :D Quote Link to comment
DanielC Posted January 15, 2008 Report Share Posted January 15, 2008 A strong gas smell could be two things. First, no spark, the gas does not burn and passes straight throught the engine, and you smell it. It is also possible that the engine is flooded with gas, and the gas is drowning out the spark. Pull out a spark plug, and if it is very wet, the engine is flooded with gas. Two common causes of flooding, the float could be stuck open, and the fuel level is too high in the carb, and liquid gas is running into the engine. Another cause of flooding, the fuel pressure is too high, and the high fuel pressure is just pushing gas past the needle valve that the float is trying to close. Quote Link to comment
fcwankel Posted January 15, 2008 Author Report Share Posted January 15, 2008 A strong gas smell could be two things. First, no spark, the gas does not burn and passes straight throught the engine, and you smell it. It is also possible that the engine is flooded with gas, and the gas is drowning out the spark. Pull out a spark plug, and if it is very wet, the engine is flooded with gas.Two common causes of flooding, the float could be stuck open, and the fuel level is too high in the carb, and liquid gas is running into the engine. Another cause of flooding, the fuel pressure is too high, and the high fuel pressure is just pushing gas past the needle valve that the float is trying to close. It wasnt that but ill check my plugs anyway. I checked the fuel line to see if there was fuel flowin and yeah it was alright. I started it up and its sounded even weaker. the lights in my gauges started to dim so i threw in a jumper and started it up once more and BAM ! It turned on :cool: Quote Link to comment
fcwankel Posted January 15, 2008 Author Report Share Posted January 15, 2008 Thanks but im sure theres sumthin else wrong than just the battery Oh yeah heres where i placed the battery Quote Link to comment
Icehouse Posted January 15, 2008 Report Share Posted January 15, 2008 Maybe you have a bad altornator, check the voltage when its running it should be above 13 volts. Quote Link to comment
fcwankel Posted January 15, 2008 Author Report Share Posted January 15, 2008 yeah ill check that too... thanks. what u guys think of these on my S10 !? http://www.aprperformance.com/index.php?option=com_content&task=view&id=92&Itemid=44 I cant find the original mirrors ..... Quote Link to comment
fcwankel Posted January 15, 2008 Author Report Share Posted January 15, 2008 I beleive cuss it had low voltage, it wasnt really powering the fuel pump . Quote Link to comment
