Farmer Posted September 28, 2010 Report Share Posted September 28, 2010 Just a simple question. Can the hubs be milled with out taking the rotor off? Larry Quote Link to comment
sssr20det510 Posted September 28, 2010 Report Share Posted September 28, 2010 Just mill the wheel Quote Link to comment
Pacific coast Datsun Posted September 28, 2010 Report Share Posted September 28, 2010 Just mill the wheel Yeah Larry it's easier & safer in the long run to simply bore the rims. Youll want to bore the hole to 4 inches but only go 1/2 inch down. On Youtube theres a how to vid showing a guy using a router to bore them if youd like to do it yourself. Quote Link to comment
78kingcab Posted September 28, 2010 Report Share Posted September 28, 2010 id just mill the wheels then you can put them on something differnt too,and do all 4 so you can rotate.... then go rolln 1 Quote Link to comment
]2eDeYe Posted September 28, 2010 Report Share Posted September 28, 2010 Just a simple question. Can the hubs be milled with out taking the rotor off? Larry Yes you can, it's the same process as getting the rotors turned. The face of the hub gets turned intstead of the rotor. I did mine on a brake lathe. The only issue I see with doing the wheels...if you change wheels you have to do it again. ;) Quote Link to comment
hessianben Posted September 28, 2010 Report Share Posted September 28, 2010 Hee hee... you can always do what i did! purchase a router from home depot, bore all the wheels you need, clean it, and return it for 100% cash back! :) i also did the same with the rabbet bit! (although, i said it was broken in order to get my $ back) Quote Link to comment
Guest DatsuNoob Posted October 17, 2010 Report Share Posted October 17, 2010 I have a pair of milled HB hubs I bought at Canby (have titans too). Not sure I wanna run 18's now. I'd sell em if you're interested Quote Link to comment
thisismatt Posted October 17, 2010 Report Share Posted October 17, 2010 Hee hee... you can always do what i did! purchase a router from home depot, bore all the wheels you need, clean it, and return it for 100% cash back! :) i also did the same with the rabbet bit! (although, i said it was broken in order to get my $ back) Nice one, douchebag. Quote Link to comment
