spottedog Posted September 28, 2010 Report Share Posted September 28, 2010 The rings are shot on my beloved little B210 hatchback, it is using oil and smoking, and a Highway patrol officer issued me a warning! Before I pull the engine for a rebuild I really would like to find a supplier of rings and maybe pistons if required. My online searches have yielded nothing and the idiot at Napa told me to “take it to the junkyard” This is not a good looking car, but it’s fun to drive and the gas mileage is great! It is a 1974 HLB 210, with a 1397 cc A-14 engine 76 mm bore The original A-13 was replaced with the A-14 that is in it now (A-14 is stamped into the block Near the #4 cylinder) I remember from when I had the head done the cylinders are already at the first oversize. Even the part numbers for pistons and rings would help a lot. Quote Link to comment
datzenmike Posted September 28, 2010 Report Share Posted September 28, 2010 How do you know they were oversize? For A14 motor up to '77. Do you know the year of your motor? Stock pistons for A14................ 12010 H7211 0.5mm over............................... 12010 H7214 1.0mm over................................12010 H7216 $60 ea all Stock A14 ring set...................... 12033 H7200 $100 0.5mm over................................ 12035 H7200 $120 1.0mm over................................ 12037 H7200 $90 Prices are approximate. Quote Link to comment
ggzilla Posted September 28, 2010 Report Share Posted September 28, 2010 Get them just about anywhere except your local NAPA. Kragen/Grand Auto/Oreilly's. Or Nissan. Quote Link to comment
Dguy210 Posted September 28, 2010 Report Share Posted September 28, 2010 Before you go rebuilding the engine are you sure the rings are bad? Other things can cause it to smoke, bad pcv valve, bad head gasket, bad valve seals (although you said the head was redone). Secondly, if the car runs and you are using it, you might want to look for a shortblock and just rebuild that, or just use it and rebuild yours. This will take all the time pressure off getting it done, and I still see A engines in the junkyards on a regular basis. Quote Link to comment
HRH Posted September 28, 2010 Report Share Posted September 28, 2010 Get them just about anywhere except your local NAPA. Kragen/Grand Auto/Oreilly's. Or Nissan. Why you gotta break balls? ;) Yeah, I saw this thread at work and checked, no piston or ring info available for that Datto. Boo on us. Can't win them all. I'll bet ITM sells a set of pistons and rings for that motor. Those can usually be gotten through the above mentioned parts houses, and at Motion/Five Mile Auto and possibly Bert Shields if you're in Spokane. Quote Link to comment
ggzilla Posted September 28, 2010 Report Share Posted September 28, 2010 Do you work at O'Reilly's Auto Parts? RockAuto.com has them orderable. The A14 engine is one of the most common, sold millions in USA. Rockauto.com Piston Rings I would guess the later A14 rings are interchangeable. Nissan specified a different ring-edge but otherwise the same. Quote Link to comment
Cuts metal like mad Posted September 28, 2010 Report Share Posted September 28, 2010 havent checked myself, but rockauto.com usually has tons of parts that the local counter stores dont carry. Quote Link to comment
king bee66 Posted September 28, 2010 Report Share Posted September 28, 2010 whats your compression? my b210 was bombing smoking from a bad valve Quote Link to comment
I'm BLUE Posted September 28, 2010 Report Share Posted September 28, 2010 my b210 was bombing smoking from a bad valve clarify that :huh: k thx :D Quote Link to comment
king bee66 Posted September 28, 2010 Report Share Posted September 28, 2010 bombing "smoke", smoking like a freight train out the tail pipe. everyone told me it was the rings despite my compressing testing fine. took the head in it had broken guide. its running fine now. Quote Link to comment
I'm BLUE Posted September 28, 2010 Report Share Posted September 28, 2010 bombing "smoke", smoking like a freight train out the tail pipe. everyone told me it was the rings despite my compressing testing fine. took the head in it had broken guide. its running fine now. ohhhhhh ok broken guide ,,, spewing oil ,,, gotcha :D I just found 1# exhaust valve guide is split on my spare head :rolleyes: ( while inspecting )... damn it !!! :lol: Quote Link to comment
king bee66 Posted September 29, 2010 Report Share Posted September 29, 2010 ive got a couple backups like that one needs the surface leveled and the other has a broken guide. pretty shitty backups when theyre messed up too. lol Quote Link to comment
ggzilla Posted September 30, 2010 Report Share Posted September 30, 2010 Why so many broken guides? I never seen one go bad. Worn yes, but not broken. Quote Link to comment
HRH Posted September 30, 2010 Report Share Posted September 30, 2010 Do you work at O'Reilly's Auto Parts? RockAuto.com has them orderable. The A14 engine is one of the most common, sold millions in USA. Rockauto.com Piston Rings I would guess the later A14 rings are interchangeable. Nissan specified a different ring-edge but otherwise the same. Oh c'mon ggzilla, you should know by now I'm a NAPA whore for life! :D Quote Link to comment
spottedog Posted September 30, 2010 Author Report Share Posted September 30, 2010 How do you know they were oversize? For A14 motor up to '77. Do you know the year of your motor? Stock pistons for A14................ 12010 H7211 0.5mm over............................... 12010 H7214 1.0mm over................................12010 H7216 $60 ea all Stock A14 ring set...................... 12033 H7200 $100 0.5mm over................................ 12035 H7200 $120 1.0mm over................................ 12037 H7200 $90 Prices are approximate. The piston crowns are stamped .50 I always thought it was a 1974 A13 until a few days ago when I found the A14 stamp on the block Quote Link to comment
spottedog Posted September 30, 2010 Author Report Share Posted September 30, 2010 Before you go rebuilding the engine are you sure the rings are bad? Other things can cause it to smoke, bad pcv valve, bad head gasket, bad valve seals (although you said the head was redone). Secondly, if the car runs and you are using it, you might want to look for a shortblock and just rebuild that, or just use it and rebuild yours. This will take all the time pressure off getting it done, and I still see A engines in the junkyards on a regular basis. I had a full top end done awhile back, some smoke was visible after that, but it just got worse. Quote Link to comment
Nicholas7620 Posted October 4, 2010 Report Share Posted October 4, 2010 Do you have water in your oil? :o Can you post results from a compression test? :blink: Let us know. There are plenty of piston rings, pistons available in Cali, and ebay. :P :D I see them frequently. There is Sold on Line in Petaluma, CA and Jordan's in Santa Rosa and many others. Try not to buy parts you won't use or need. ;) Quote Link to comment
