Laecaon Posted December 3, 2012 Author Report Share Posted December 3, 2012 Oh and Vacuum advance... I cant really hook it up... Quote Link to comment
Skib Posted December 3, 2012 Report Share Posted December 3, 2012 theres 2 ports on the fuel bowl. one is fuel feed and one is overflow encase the float is off or bad Quote Link to comment
Laecaon Posted December 3, 2012 Author Report Share Posted December 3, 2012 Yea, that is a third port. Hence why I don't know what it is. Quote Link to comment
DRIVEN Posted December 3, 2012 Report Share Posted December 3, 2012 +2 sexy points. The SUs on my Z were some of the most drama free carbs I ever had on any car. Once you get them dialed in you'll love them. Quote Link to comment
jrock4224 Posted December 3, 2012 Report Share Posted December 3, 2012 fyi one of those is a vent and needs to remain open i know when we put the flat tops on my buddys truck theres a line that connects the two float bowls and it never worked right till we vented those(it was capped....then it purred and didnt stay at high idol...the ones we did looked a little different but i know when it was hooked up fuel poured out the front of the carbs like a stuck float.... nice air cleaner too bad it didnt work it looked cool.....we also used a 26 dollar sync tool .. then they start ed to run even better Quote Link to comment
Laecaon Posted December 3, 2012 Author Report Share Posted December 3, 2012 I did use a tool to sync the carbs. I have the vents open to atmosphere. I have the fuel feed hooked up to my fuel pump. Carbs are running super well. Its just the rear carb that has the extra port. I definitely need to tweak my thottle linkage a little more. And the carb linkage is bindind a bit sometimes not allowing it return to idle. I fix this for now buly tapping the gas pedal and it drops. Now that I have had a chance to start it cold and drive to work, I am happy. Engine started right up without choke, and idled at 400 smoothly. As it warmed up idle picked up to 650-700. The engine idles so much smoother now, hot or cold. I no longer have a off idle dead spot. The sound, well its less throaty than the 32/36 but its a lot more aggressive sounding. Quote Link to comment
jrock4224 Posted December 3, 2012 Report Share Posted December 3, 2012 not being a dick but how can it idle smoothly at 400....lol.....my idles all sit at 900 and about 1300 with choke....... my mazda every now and again will drop to about 600 but it sounds like its got a huge duration cam or is dropping every other hole......which sounds cool but is way to low...and is hard to get to rev up...takes some cleaning out......that air cleaner looks sick too bad about the crack .... u might try thicker acrylic ..... if it cracked, most likely that is harmonic ....heat would maybe crack but more likely striate...that wierd little syncing tool works good.....there like 20 bux on ebay too... Quote Link to comment
Laecaon Posted December 4, 2012 Author Report Share Posted December 4, 2012 Im not joking. Its super quiet, car barely shakes. And the motor is still responsive. Although I much prefer the 650-700 range, that is reserved for once warm. 3 times today I started it and it idled at 400. My 32/36 was all over the board on idle. If you let it warm up, Idle would be 900. Go for a drive and stop, it would be 650, and then slowly rise as the under hood temp raised. Choke would usually be 1100, any lower and the car had no power at idle. The motor also vibrated like crazy when idling and was quite annoying. But I just couldnt get the idle mixture or timing to make it any smoother. I have not touched my Dizzy since the changeover. I still dont have the Vac Advance hooked up, as I need some vinyl tube to make some of the bends that are required. Came home from work, and fixed the throttle linkage, just a little more twisting. No more dead spot on the pedal. As far as the filter, I think the acrylic cracked from the vibration. Im not too worried yet. Quote Link to comment
jrock4224 Posted December 4, 2012 Report Share Posted December 4, 2012 yeah my 32/36 will high idle if i been driivng it highway and slowly drop.....thats crazy i know hans 521 idled super smooth on his su's ....his is about 800....thats cool though ....i know my 32/336 i re adjust about every four monthes ........and if i ever tried to get it to idle at 450 it would shake so bad the bumpers would rattle....lol.......wheres the vid of it runnig Quote Link to comment
H5WAGON Posted December 7, 2012 Report Share Posted December 7, 2012 yeah my 32/36 will high idle if i been driivng it highway and slowly drop.....thats crazy i know hans 521 idled super smooth on his su's ....his is about 800....thats cool though ....i know my 32/336 i re adjust about every four monthes ........and if i ever tried to get it to idle at 450 it would shake so bad the bumpers would rattle....lol.. >>>>>>.....wheres the vid of it runnig And yes thicker Acrlic...I like the look. Quote Link to comment
I'm BLUE Posted December 7, 2012 Report Share Posted December 7, 2012 Call TAP Plastics. They might have a solution. Quote Link to comment
Laecaon Posted December 8, 2012 Author Report Share Posted December 8, 2012 Oh hot damn I love these carbs. Finally got on the freeway tonight, it pulls so much harder in 4th and 5th now. And they are still nice and quiet at cruise. And I now think 3rd is my favorite gear, has enough torque at 25mph to get going pretty well, but lasts to 70 if I push it. Quote Link to comment
I'm BLUE Posted December 8, 2012 Report Share Posted December 8, 2012 Night and day difference huh ? :thumbup: Bummer on the cables. Quote Link to comment
DRIVEN Posted December 8, 2012 Report Share Posted December 8, 2012 It's nice when a 40yo daily driver is actually fun to drive. Quote Link to comment
Laecaon Posted December 11, 2012 Author Report Share Posted December 11, 2012 So I got a package today! Mirrors! These are BMW flag mirrors, often associated with the 2002, but on many others as well. Almost perfect condition, and I got them for a decent deal. I think I might try to mount them tomorrow, but So far I am making tomorrow a busy day... Quote Link to comment
Draker Posted December 11, 2012 Report Share Posted December 11, 2012 Awesome! They look pretty nice. Can't wait to see the mock up!! Quote Link to comment
jrock4224 Posted December 11, 2012 Report Share Posted December 11, 2012 i want those mirrors.....good choice....trade u a swapped ka crossmember and a set of shortend coil struts....u pick the color.,....lol Quote Link to comment
Draker Posted December 11, 2012 Report Share Posted December 11, 2012 i want those mirrors.....good choice....trade u a swapped ka crossmember and a set of shortend coil struts....u pick the color.,....lol :sneaky: lol Quote Link to comment
jrock4224 Posted December 11, 2012 Report Share Posted December 11, 2012 :poke: ....lol....i thought about including the bump spacers but i can use both sets of those....and laecon already has a set get them on there i wanna see them.... Quote Link to comment
Laecaon Posted December 12, 2012 Author Report Share Posted December 12, 2012 Ok pictures. I taped it to my door. It could probably raise a degree... And I will be mounting them more forward, this was simply a quick fitment test. Inside view, seems to be 95% useable to me, good enough. Outside views. Quote Link to comment
DRIVEN Posted December 12, 2012 Report Share Posted December 12, 2012 And the brakes? Quote Link to comment
Laecaon Posted December 12, 2012 Author Report Share Posted December 12, 2012 Yes. I have decided that I hate rain. And I should clean my garage, again. Cleaning my garage seems to be a never ending chore... Im not really having much problem with the brakes, the car is stopping just fine right now... knock on wood... I have also convinced myself to buy a new floor jack. I found one I like ($180, but out of stock right now...) which only has positive reviews anywhere I search. My current one is slow, and doesnt really fit under my car super well. Quote Link to comment
converted_to_datsun Posted December 12, 2012 Report Share Posted December 12, 2012 Dang I like those mirrors... I was thinking mustang mirrors but now you made that coice soo much harder darn it. Quote Link to comment
Laecaon Posted December 12, 2012 Author Report Share Posted December 12, 2012 Mustang mirrors are probably quite a bit cheaper. Quote Link to comment
Draker Posted December 12, 2012 Report Share Posted December 12, 2012 Yeah.. If you can't find these in a yard they are going to be pretty spendy. These have always been my favorite mirrors through, so there wasn't another option. Quote Link to comment
