DatDoug Posted August 23, 2010 Report Share Posted August 23, 2010 Has anyone seen this ad? Has anyone ever seen or heard of a turbo-Diesel L motor? :blink: Very cool indeed :cool: http://losangeles.craigslist.org/sfv/cto/1906298162.html Link to comment
INDY510 Posted August 23, 2010 Report Share Posted August 23, 2010 That almost looks like a inline six L20 Nissan beat the Land speed record in the late sixties with a gas powered inline 6 L20 ....... 2 liter...... it looks alot smaller than a L28 Link to comment
ohpyramids Posted August 23, 2010 Report Share Posted August 23, 2010 it has been on CL for a few months. ive had an eye on it, but the price hasnt dropped. that motor is rare, so goodluck with parts. fucking awesome though. Link to comment
MAG58 Posted August 23, 2010 Report Share Posted August 23, 2010 That almost looks like a inline six L20 Nissan beat the Land speed record in the late sixties with a gas powered inline 6 L20 ....... 2 liter...... it looks alot smaller than a L28 wut? The L20A is the exact same size demensionally as any other L-6 it's just got thick ol' walls.And I'm not sure how you'd feed 6cyl with 4 injectors... :unsure: Anywho, Nissan made an LD20 From the Great Wiki: There is also a diesel version of the 4-cylinder L-series, used in amongst others the Bluebird 910 and the Vanette. (but strangely enough was not in the 720 pickup, which had the SD22/25 when diesel powered, while the gas version most often has the L-series engine. However, in case of a conversion of a gas powered 720 to diesel, it will be much easier to use a LD20 because it fits on the original gearbox and engine mounts.) The N/A version produced 65 hp @4600rpm and 12,5 kgm @2400rpm, later 67 hp/13 kgm. The turbo version has 79 hp@4400rpm and 17 kgm @2400 rpm. The LD engine must not be confused with the Nissan SD engine which is a totally different engine. LD20-1 1,952 cc diesel engine pre-combustion chamber 65 PS (47.8 kW; 64.1 bhp) @ 4600 RPM 12.5 kg·m (123 N·m; 90 lb·ft) @ 2400 RPM LD20-2 67 PS (49.3 kW; 66.1 bhp) @ 4600 RPM 13.0 kg·m (127 N·m; 94 lb·ft) @ 2400 RPM Models Bluebird (910 & U11) Vanette(C120 & C22) Largo (C120 & GC22) LD20T 79 PS (58.1 kW; 77.9 bhp) @ 4400 RPM 17.0 kg·m (167 N·m; 123 lb·ft) @ 2400 RPM Models Homy / Caravan (E23 & E24) Link to comment
motavated Posted August 23, 2010 Report Share Posted August 23, 2010 You guys are way behind. He was on here asking for advice... http://community.ratsun.net/topic/13245-help-to-id-an-engine/ Link to comment
motavated Posted August 23, 2010 Report Share Posted August 23, 2010 67 PS (49.3 kW; 66.1 bhp) @ 4600 RPM 13.0 kg·m (127 N·m; 94 lb·ft) @ 2400 RPM Models Bluebird (910 & U11) Vanette(C120 & C22) Largo (C120 & GC22) LD20T 79 PS (58.1 kW; 77.9 bhp) @ 4400 RPM 17.0 kg·m (167 N·m; 123 lb·ft) @ 2400 RPM Models Homy / Caravan (E23 & E24) Stock l20b produces 100 hp (75 kW) in 1981 form with 112 lb·ft (152 N·m) Sooooo... The l20b has more Hp and about the same torque..... Plus the gas engine you can rev it higher. I would just like it for the intake and exhaust manifold... Link to comment
dat521gatherer Posted August 23, 2010 Report Share Posted August 23, 2010 bead blast that valve cover for crying out loud. fuck it never mind i hate diesel. almost had to choke a guy recently just cause the smell was rewiring my brain cells to kill. Link to comment
Master-O-Turbonics Posted August 23, 2010 Report Share Posted August 23, 2010 wut? The L20A is the exact same size demensionally as any other L-6 it's just got thick ol' walls.And I'm not sure how you'd feed 6cyl with 4 injectors... :unsure: Anywho, Nissan made an LD20 To be technically correct, the deck height is lower on an L20A, so it is "smaller" in one dimension. Link to comment
Z-train Posted August 23, 2010 Report Share Posted August 23, 2010 bead blast that valve cover for crying out loud. fuck it never mind i hate diesel. almost had to choke a guy recently just cause the smell was rewiring my brain cells to kill. Diesel is superior. Link to comment
MicroMachinery Posted August 25, 2010 Report Share Posted August 25, 2010 That thing is baaaayaaaaad Link to comment
motavated Posted August 25, 2010 Report Share Posted August 25, 2010 I dont know... 620's are slow to begin with. Imagine with a lower reving engine? Link to comment
Yakuza Posted August 25, 2010 Report Share Posted August 25, 2010 Stock l20b produces 100 hp (75 kW) in 1981 form with 112 lb·ft (152 N·m) Sooooo... The l20b has more Hp and about the same torque..... Plus the gas engine you can rev it higher. I would just like it for the intake and exhaust manifold... not sure that the turbo stuff would work on the regular L20...but dont quote me... :D Link to comment
motavated Posted August 25, 2010 Report Share Posted August 25, 2010 Some one here bought that turbo manifold it and it pretty much uses the same gasket... I dont know though... Its been a while. I seen it on here... The engine was never completed. Link to comment
MicroMachinery Posted August 25, 2010 Report Share Posted August 25, 2010 I'd rock the turbo diesel. Link to comment
RacnJsn95 Posted August 25, 2010 Report Share Posted August 25, 2010 The turbo manifold would in theory bolt up. I actually bought one, and took pictures of it on my 620... They might be in my project thead... The only problem I saw with it is that the firewall would have to be notched, or beat in to clear the down pipe out of the turbo... That is a sweet truck! I would totally buy that if I had money to blow. Link to comment
DatsunMotorSports Posted August 26, 2010 Report Share Posted August 26, 2010 bead blast that valve cover for crying out loud. fuck it never mind i hate diesel. almost had to choke a guy recently just cause the smell was rewiring my brain cells to kill. You'd hate my Datsun Maxima Diesel Wagon. If you tail gate I will intentionally black you out of my vision until you slow down or drive off the road cause you cant see it.... MAWHAhahahah! No but seriously you will have to wash soot off your car and you might think my wagon was a-blaze or something. These diesels could do good with a bit o forced induction. Its on the list for mine if I end up keeping. Link to comment
HRH Posted August 26, 2010 Report Share Posted August 26, 2010 That is bitchin', I'd defintely drive it! Link to comment
