laotsu Posted July 16, 2010 Report Share Posted July 16, 2010 :unsure:it almost looks like a bracket to hold a extinguisher.its under the dash alongside my steering column any ideas? :blink: Quote Link to comment
Jayden71 Posted July 16, 2010 Report Share Posted July 16, 2010 :blink: :blink: :blink: :blink: Mine don't have that. After market bolt-on?? Quote Link to comment
metalmonkey47 Posted July 16, 2010 Report Share Posted July 16, 2010 Holds a tach maybe? Quote Link to comment
dat521gatherer Posted July 16, 2010 Report Share Posted July 16, 2010 my guess is a old school registration holder. i've seen other styles that wrap around the steering column. Quote Link to comment
datto510 Posted July 16, 2010 Report Share Posted July 16, 2010 Looks like a tetnus shot waiting to happen. :blink: Quote Link to comment
DISLEXICDIME Posted July 16, 2010 Report Share Posted July 16, 2010 that's where you stash your emergency beer Quote Link to comment
Pumpkn210 Posted July 16, 2010 Report Share Posted July 16, 2010 Im thinkin it may be for the turn signal/flasher relay? Quote Link to comment
laotsu Posted July 16, 2010 Author Report Share Posted July 16, 2010 YEAH! my turn signals are all shitty and slow at different speeds... I'll bet I have the wrong relay. Quote Link to comment
Pumpkn210 Posted July 16, 2010 Report Share Posted July 16, 2010 Yep, if it isnt in the Holder the body of the flasher unit will ground out on any metal its touchin, thats why its got its own special holder! Quote Link to comment
kaoss Posted July 16, 2010 Report Share Posted July 16, 2010 Put your balls in it. Quote Link to comment
Budget Monty Posted July 16, 2010 Report Share Posted July 16, 2010 wang holder That would be nice, I could keep that sucker from gettin' tangled uo in the pedels! Quote Link to comment
foxarelly Posted July 17, 2010 Report Share Posted July 17, 2010 Im thinkin it may be for the turn signal/flasher relay? my flasher can bolts to the column its not in a holder!! Quote Link to comment
Pumpkn210 Posted July 17, 2010 Report Share Posted July 17, 2010 my flasher can bolts to the column its not in a holder!! Mine are in a plastic holder that is screwed to the column!! Quote Link to comment
datzenmike Posted July 17, 2010 Report Share Posted July 17, 2010 Yup, they don't have to be insulated from ground. YEAH! my turn signals are all shitty and slow at different speeds... I'll bet I have the wrong relay. The aren't really called a relay, they are a flasher unit and the best ones are electronic and do not rely on load to work. The old ones will flash faster with more lights in the system. The electronic ones flash at the same rate. Much better. Quote Link to comment
Pumpkn210 Posted July 17, 2010 Report Share Posted July 17, 2010 Are they supposed to be grounded in the 521? That would explain why that holder isnt completely insulated, and maby fix the wierd acting turn signals! Quote Link to comment
Gensaiken Posted July 18, 2010 Report Share Posted July 18, 2010 Xtreme Cup holder :P Quote Link to comment
