67 411 Posted October 20, 2010 Author Report Share Posted October 20, 2010 I would run a 9" if I was you Quote Link to comment
nis720 Posted October 20, 2010 Report Share Posted October 20, 2010 What vehicle is the 8.8 out of? I've read about the explorer rear ends being offset and the internals will not swap over from a mustang 8.8 rear end. My stock 720 axle is about 56-1/4". But I'm looking to get a rear end with 54" or less and narrow the frame to allow a wider wheel. Quote Link to comment
67 411 Posted October 20, 2010 Author Report Share Posted October 20, 2010 It is of set my 8.8 is 3" shorter on the driver side. So I have been trying to find another shortside axle shaft, baxters wants 188 and I found a used one for 100 at lkq. But I'm thinking about just selling my shafts for 100 for the pair and then have dutchman make me a nice set for 240 for the pair.if I get a pair made they will be stronger and I can get it down to the exact size of the origonal. As for the caddy steering wheel and column the wheel it the same size as the datsun one, but the column is longer by 3" so I will have to shorten that. I think it will be worth it to have tilt and telescoping though. Nis720 if you have the cash I think the 8.8 is the way to go cuz you get the disc brake with it. Quote Link to comment
mklotz70 Posted October 21, 2010 Report Share Posted October 21, 2010 I didn't realize the wheel had tilt.....def go for it!! :) Quote Link to comment
67 411 Posted October 21, 2010 Author Report Share Posted October 21, 2010 Awsome mike I'm glad you approve of it. I will clean it up and paint it like the truck. But I am worried about hooking up the blinkers and brights. Quote Link to comment
Charlie69 Posted October 24, 2010 Report Share Posted October 24, 2010 This build is progressing nicely. Can't wait to see what comes next. :cool: Quote Link to comment
67 411 Posted October 31, 2010 Author Report Share Posted October 31, 2010 i have been looking at the fornt suspension and i dont like the torshon bars, i was wondering if anyone has ever gotten rid of them. Or maby it would be easyier to just put the suspension from somthing else on. Anyone have any advice? Quote Link to comment
wayno Posted October 31, 2010 Report Share Posted October 31, 2010 sycloned916 put a pair of these on his 520 project, I do not know if his is lowered like you are planning, you'd have to ask him. I have also seen some projects with air bags, but they are made to put the rockers on the ground. wayno . Quote Link to comment
67 411 Posted October 31, 2010 Author Report Share Posted October 31, 2010 I have been thinking about a airbag setup. This is my first project were I wana redo the front suspension, so I might be asking a dumb question but if I run airbags can I lose those torshon bars? Quote Link to comment
wayno Posted October 31, 2010 Report Share Posted October 31, 2010 I do beleave that is one of the reasons for the airbags, to remove the torsion bars, then you can lower it all the way to the ground. I also beleave you loose all your handling, I run airbags in the rear of my dually 521 as overloads, when I load it up the back end becomes a rubber ball, like a car with no shocks, bouncy, uncontrolable, maybe you can run shocks on a airbag suspension, that I don't know. I have never been in that type(4 airbags) of car to know how they ride. How about it guys, would you drive a 100 miles over a mountain pass with an airbag suspension vehicle, without dipping under the speed limit? Could you drive it like I drive my 1967 datsun 2000 roadster over that pass? wayno Quote Link to comment
mklotz70 Posted October 31, 2010 Report Share Posted October 31, 2010 Yes, airbags will replace the torsion bars. The bars simply support the weight of the vehicle, the shocks keep the bouncing in control. The airbags would take over the support, but as wayno said, it will most likely bounce if you do not put shocks on. There have been a couple of guys on here that have done bags with no shocks and swear that the ride isn't bad....but I doubt it would meet wayno's criteria. The challenge with bags is that they take up ALL of the room for shocks. You'd have to figure out a mount for the shock that was on the outside of the A-arms, without being in the way of the tire at full steering lock. The coil over suspension in the pic is an awesome way to go, but more expensive and not easily adjustable....meaning you can't adjust it on the fly like you can with airbags. Quote Link to comment
wayno Posted November 2, 2010 Report Share Posted November 2, 2010 Hi there 67 411, this is the only way to get a hold of you as your email is "private", would you please PM me. wayno Quote Link to comment
fo0manchu Posted November 2, 2010 Report Share Posted November 2, 2010 just read through this thread and saw my name! ahah.. sweet. Cool build so far. when i used two short side axles off a ranger, it measures 53.5" axle to axle. Add some disk brake and add approx .5 on each side bringing the total width to about 54.5". Quote Link to comment
67 411 Posted November 2, 2010 Author Report Share Posted November 2, 2010 Cool I had a couple questions for you, first off were did you get your ranger axles? And secound what is the spline count on the ranger axles. I think mine was 30 or 31. Quote Link to comment
fo0manchu Posted November 2, 2010 Report Share Posted November 2, 2010 most explorers are 31, ranger and older mustangs are 28. I got a mustang rear end with lsd, and then just shortened the housings. Got the axles at the junkyard. If you are going to be running high hp, like 400up i would recommend 9" ford ends. Quote Link to comment
67 411 Posted November 2, 2010 Author Report Share Posted November 2, 2010 The junkyards around here don't want to sell just the axle shafts lol so that kinda screws that for me. If I got 2 shortside axles I would still be to wide I think I'm gonna have some made instead. Quote Link to comment
67 411 Posted November 3, 2010 Author Report Share Posted November 3, 2010 So I took a bunch of final measurements on the back of the frame today and then cut the frame rails pretty close to the back of the cab. So now I'm going to start makeing templets for my new rear frame. Ill try and post a pic of the cranage soon Quote Link to comment
sycloned916 Posted November 4, 2010 Report Share Posted November 4, 2010 Nice project,Can't wait to see it Finished! Quote Link to comment
67 411 Posted November 4, 2010 Author Report Share Posted November 4, 2010 sycloned916 put a pair of these on his 520 project, I do not know if his is lowered like you are planning, you'd have to ask him. I have also seen some projects with air bags, but they are made to put the rockers on the ground. wayno . I think i like this setup the most, and i figure i might modify the crossmember anyways so the torsion bars have to go. Quote Link to comment
sycloned916 Posted November 5, 2010 Report Share Posted November 5, 2010 There's plenty of room for the coilovers,I was going to notch the upper arms to clear them but did not have to. One thing I noticed the sway bar is in the way abit but just depends on how and were you mount the brackets,I could go another 1in out on the top and bottom mounts just depends on were you want your ride set. Quote Link to comment
67 411 Posted November 5, 2010 Author Report Share Posted November 5, 2010 Were did you get the coilovers? And I was wondering if you are happy with them, like does it ride good did it effect the handleing? I think they look cool Quote Link to comment
67 411 Posted November 13, 2010 Author Report Share Posted November 13, 2010 Fo0manchu are you talking about replaceing the whole ends of the axle houseing with 9" ends. I had heard that the 8.8 would take as much abuse as a 9". I am hopeing to have 500-600 whp so if a 8.8 can't take that I have a problem. Quote Link to comment
fo0manchu Posted November 13, 2010 Report Share Posted November 13, 2010 Fo0manchu are you talking about replaceing the whole ends of the axle houseing with 9" ends. I had heard that the 8.8 would take as much abuse as a 9". I am hopeing to have 500-600 whp so if a 8.8 can't take that I have a problem. 8.8 can take the power, however you would need c-clip eliminators. But those are only good on the straights. I am talking about using the whole ends of the 9" axles. Ford 8.8 with that much power will break the c-clips and send the axles flying. However people have argued the point that if you have disk break's with the 8.8 then you have nothing to worry about. Quote Link to comment
67 411 Posted November 13, 2010 Author Report Share Posted November 13, 2010 Ok I guess I might be ok then cuz I Do have the disc breaks. O well I'm not gonna go easy on it either way so I guess I will know if the 8.8 is as tough as they say. Quote Link to comment
fo0manchu Posted November 13, 2010 Report Share Posted November 13, 2010 Ok I guess I might be ok then cuz I Do have the disc breaks. O well I'm not gonna go easy on it either way so I guess I will know if the 8.8 is as tough as they say. I like that attitude! :thumbup: Quote Link to comment
