Hurley Posted March 20, 2010 Report Share Posted March 20, 2010 Been a long time since bled a clutch . Can anyone give me the proceedure? Thanks! Quote Link to comment
INDY510 Posted March 20, 2010 Report Share Posted March 20, 2010 Crawl under the car......... and see if you can reach the clutch slave cylinder without jacking up the car (safer that way) Usually there is a 10mm bleeder nipple on the slave clyinder.......... you need two people Have a friend pump the clutch pedal a few times and then hold it to the ground,,,,, , , then loosen the bleeder nipple Don't let your friend release the clutch pedal until AFTER you tighten the bleeder nipple..... Repeat this process 5-8 times,,,,,, and check the fluid in the clucth master cylinder every two times,,,,, don't let it run dry... After you are done:check for leaks...... while your friend pumps the clutch pedal Quote Link to comment
datzenmike Posted March 20, 2010 Report Share Posted March 20, 2010 I moved this to General Technical. How To is for wright ups on how to do something. Loosen the bleed screw on the slave and pump clutch until the reservoir is empty. This empties it of any old 'juice'. Fill with new from the bottle brake fluid. Depress clutch and hold while someone closes the bleeder screw. Let up the clutch pedal. Open bleeder, depress clutch pedal. DO NOT LET THE RESERVOIR RUN DRY! Repeat until only new clean fluid comes out free of any air bubbles. Tighten bleeder screw. Quote Link to comment
Creepy Cruiser Posted March 21, 2010 Report Share Posted March 21, 2010 I use one of these. (super cheap $5, and works great) Works perfect when you're working on your dime at 2am, and all your friends are asleep, lol. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=37201 Quote Link to comment
Pacific coast Datsun Posted March 21, 2010 Report Share Posted March 21, 2010 I "gravity" bled mine by myself. Filled res..pumped pedal a few times & held down w/ steering wheel club, opened bleeder..closed right before the res. emptied. Been fine for years :cool: Quote Link to comment
mike Posted March 22, 2010 Report Share Posted March 22, 2010 Top off the master cylinder reservoir. Put a piece of hose over the bleeder and put the other end of the hose in a container with a couple inches of brake fluid (about 3-4") crack the bleeder open and pump the pedal VERY SLOWLY. Make sure that the reservoir doesnt go dry and that the hose doesnt pop off the bleeder. It should come up to pressure quick. Close the bleeder valve being careful not to knock the hose loose. If you pump too fast the hose will come off, youll have fluid everywhere and youll have to start over. Theres probably better ways but this works in a pinch. I did this on my goon when I first got it and its still doing fine. If youve got a buddy around use him/her, it goes a bit quicker and its easier to keep an eye on things. Quote Link to comment
banzai510(hainz) Posted March 22, 2010 Report Share Posted March 22, 2010 I do it Mikes ways Bymyself. I use a clear hose into a bottole when I see no airbubbles then close valve DONE Just put a new slave on this weekend. had a slow leak and was sucking in air. work soemtimes and othertimes I could barely get it in gear. Said Fuck it .I cahnged it out Lucky I have a spare otherwise most parts stores dont have them in stock so order a spare. Master Cylinders also. Quote Link to comment
bonvo Posted April 23, 2010 Report Share Posted April 23, 2010 Lucky I have a spare otherwise most parts stores dont have them in stock so order a spare. Master Cylinders also. really my local napa has the ones for my 610 on the shelf Quote Link to comment
