jonesy510 Posted April 8, 2010 Report Share Posted April 8, 2010 ................ :confused: :blink: :blink: i kinda understood that.. the only thing in the diagram that kinda confuses me is hooking it up to the battery.. its not really confusing but yea... am i not quite sure how im suppose to do that Quote Link to comment
arkitekz Posted April 8, 2010 Report Share Posted April 8, 2010 ................ :confused: :blink: :blink: i kinda understood that.. the only thing in the diagram that kinda confuses me is hooking it up to the battery.. its not really confusing but yea... am i not quite sure how im suppose to do that Did you buy the set from JDM510? Im thinking about upgrading my lighting Quote Link to comment
JDM510 Posted April 8, 2010 Report Share Posted April 8, 2010 yeah im the guy to see when it comes to BMW lights.. :lol: Quote Link to comment
DatsunMotorSports Posted April 27, 2010 Author Report Share Posted April 27, 2010 Im running a set of Xenon HIDs like this. They are supposedly(but unconfirmed by me) less amperes than a conventional bulb. IT directly plugs into the stock harness. I should say that I will be switching over to a relay setup in the future before the car is finished and drivable. Its always nice to run low voltage through your switches. Ray Quote Link to comment
mswit209 Posted May 6, 2010 Report Share Posted May 6, 2010 hey jonesy check your fuses when i put my e class projectors in with the mercedez yellow centers i didnt have it wired in right and a fuse blew which made one side really dim. i found it odd and it took me forever to track down. and you read it right i somehow managed to get mercedez e class projectors and hids into my 510. those are expensive bulbs though damn d2s they are a bill a piece. but bright as shit. Quote Link to comment
skunk Posted May 28, 2010 Report Share Posted May 28, 2010 (edited) looks like ill be doing this on my 510. I hate Electrical work <_< should i do a alt swap befor doing this? Edited May 28, 2010 by skunk Quote Link to comment
zerow Posted May 28, 2010 Report Share Posted May 28, 2010 should i do a alt swap befor doing this? Yes. Brighter lights is reason enough for the alt swap. ;) Quote Link to comment
BoostinBen Posted May 28, 2010 Report Share Posted May 28, 2010 I just happened across a cherry set of these Bmw ellipsoid lights at Pick n pull .. Not sure if im going to use them but they were super cheap (1/2 price sale going on now!) so got em for 16 bucks!... I was thinking if I run them I would like to figure out a way to use a dual filliment bulb in them so I can retain the hi/low and keep the mercedes fogs .. anyone know of a bulb that would work? Also, once you mod the bucket does that affect being able to go back to a standard light? im not completely sold on the look of them but am interested in mounting them up to see what they look like. Quote Link to comment
zerow Posted May 29, 2010 Report Share Posted May 29, 2010 ...I was thinking if I run them I would like to figure out a way to use a dual filliment bulb in them so I can retain the hi/low and keep the mercedes fogs .. anyone know of a bulb that would work? IIRC, you want the 9004 bulb. It has Low, Hi and Ground for the three prong connector. Quote Link to comment
gokiburix Posted June 15, 2011 Report Share Posted June 15, 2011 This is the rest of my mini-writeup (I had this on the wagon thread but it applies to others) This is where I cut on the stock headlight mounting bracket Depending which side you decide to put it on (headlight/highbeams) the cut is pretty much the same This is where I cut on the headlight bucket (I think I posted it before like a year ago...I left about 1"-1.5" on the bucket) This is what it looks like installed You can clearly see my ugly cut (the headlight finishers cover that s#!+ up anyways) Backside You can see how much the fatass ellipsoid sticks out compared to the headlights(excuse the mess) RESULT HID's are in! ...and bright as fawk! "light splash" isn't so bad ellipsoid fogs everyone knows the nice cut-off they have Hope this helps anyone else that's thinking of tackling this task. I know there's "sorta" writeups on this, but never seems like a complete one. -goki Quote Link to comment
Shagy Posted June 15, 2011 Report Share Posted June 15, 2011 see I knew you had to cut the "cup" that they mount to, but I didnt know you needed to cut the backing part to...or is that just 'cause you put them in the "high" beam spot? I still want to see them mouned in the LOW beam spot and how people massaged their fenders. Quote Link to comment
gokiburix Posted June 15, 2011 Report Share Posted June 15, 2011 you have to cut the "cup" regardless of the position. and you cut the bracket depending on what side you want it on. so instead of cutting here: you cut the opposite from what I did (since I put them on the high beam position) Quote Link to comment
NiMB Posted June 15, 2011 Report Share Posted June 15, 2011 see I knew you had to cut the "cup" that they mount to, but I didnt know you needed to cut the backing part to...or is that just 'cause you put them in the "high" beam spot? I still want to see them mouned in the LOW beam spot and how people massaged their fenders. I'm going to mount them in the LOW beam spot on my 620. I'll post pics when I do it... Goki, Free Draft Beer for the assistance? Quote Link to comment
Shagy Posted June 15, 2011 Report Share Posted June 15, 2011 interesting. I'll have to re read the DIY threads. quad projectors when I'm done =) Quote Link to comment
Laecaon Posted June 16, 2011 Report Share Posted June 16, 2011 I did my write up today without seeing this... I actually did the install Sunday night through monday. Quote Link to comment
skyknight789990 Posted November 15, 2011 Report Share Posted November 15, 2011 kinda new to the hid set ups been checking stuff out for months an i would like to do a projector hid set up on my 79 620 will it work about the same as the 510 set up an what bmw head lights should i look for to put the projectors in Quote Link to comment
Shagy Posted November 15, 2011 Report Share Posted November 15, 2011 Kind of new to hid set ups. Been checking stuff out for months and I would like to do a projector hid set up on my 79 620. Will it work about the same as the 510 set up? What bmw head lights should I look for? If you search ebay for BMW projectors or 510 headlamps, 5 3/4 projectors they usually come up. Goki might have a set left, might want to send him a message. Once you get the lamps, you'll need to purchase a HID retrofit kit. Quote Link to comment
skyknight789990 Posted November 15, 2011 Report Share Posted November 15, 2011 If you search ebay for BMW projectors or 510 headlamps, 5 3/4 projectors they usually come up. Goki might have a set left, might want to send him a message. Once you get the lamps, you'll need to purchase a HID retrofit kit. was gonna go with projectors havent really seen a good retofit that didnt have light all over the place was up all night checking out all kinda of lights an stuff think these might be the the best an clean looking they have sharp cut off so the light is not in everyones face... thats if the E30 lights will fit right after modifications... what do you think http://www.stealthauto.com/Products/1985-1991-BMW-E30-3-Series-Quad-Angel-Eye-Projector-Headlights-Black-Housing-%28Pair%29__E30LHL-BLK.aspx Quote Link to comment
Shagy Posted November 15, 2011 Report Share Posted November 15, 2011 I wouldn't. I would go with these.... http://orangecounty.craigslist.org/pts/2666956786.html Quote Link to comment
gokiburix Posted November 18, 2011 Report Share Posted November 18, 2011 Yup...those are mine! :) I still have a couple of sets left...I think :P Quote Link to comment
javyz510 Posted December 6, 2011 Report Share Posted December 6, 2011 Thanks for the info!:) Quote Link to comment
