620's with SU carbs
greybeard
I'm going through the carbs on my truck and want to change the aircleaner as I was never really happy
with what I had on there. (a foam type on a flat base)
My set up is a little different than a stock 620, but there is not much room between the rear carb
and the brake booster.
Anybody running SU's on a 620? what are you doing for an airfilter? I'm after some Pix of SU's on 620's!
  • Replies 12
I wouldn't mind a pic of yours.
There is a pic in my galery, just can't seem to get it to link, the shot was taken after I pulled them off the truck to refurbish, I'll post up a pic when I get them back on the truck.
The reason I asking is my truck has very little space between the face of the rear carb. and the brake booster,
I know my truck is not the same as most 620's, so I just wanted to see what a 620 on a stock frame with SU's looked like.
These are the filters that came on my SU's when i bought them. The PO said they were lawnmower filters.... :rolleyes: Just clears the steering shaft & booster.
PCD, Seeing these filters, I would be worried that the poor thing is struggling for air. There is just not a lot of area for the air to get through. But, if it runs...
