fuzz's '71 510 Posted December 14, 2009 Report Share Posted December 14, 2009 What are the easiest and most durable motor to put into a 510? I've looked at all of the projects and see that everybody has there own flavor, just would like an all around motor. As of now there is nothing in my engine compartment, so let me know which way to go kinda like pro's and con's. Thanks. Fuzz Quote Link to comment
LeX Posted December 14, 2009 Report Share Posted December 14, 2009 i would say vg30e! parts are cheeap and it goes in pretty easy. Good bit of power N/A Quote Link to comment
datzenmike Posted December 14, 2009 Report Share Posted December 14, 2009 (edited) Just an opinion, but the L20B fits, is available, comes with up-graded ignition, 5 spd transmissions, rads, alternators, oil pumps, water pumps. Even looks stock. Internal parts form a Z series motor can be added to make a hybrid or 'stroker' motor. Up to 2X stock power levels. Next most common transplant would be a KA24 E or DE motor and tranny. Modifications are needed for engine and tranny fitment, rad, wiring and fuel delivery if EFI is kept, exhaust. Engine is about 100+ lbs heavier than stock. Gives about 2+ times the stock power output but there's aftermarket support for almost unlimited power. Next is the most talked about swap, SR20DET. Same as the KA swap but almost 3 X the power and potential for unlimited power. Parts are expensive and somewhat rare. Last a VG30E (possibly DE or DET but this is over kill for a 2,200 lb.510) Weighs almost as much as the KA motor. One of Nissans toughest everlasting trouble free motors needing only oil, water and gas. With the 3 liter size it would have monster low end torque. Edited December 14, 2009 by datzenmike Quote Link to comment
HRH Posted December 14, 2009 Report Share Posted December 14, 2009 Need to keep the parts availability around, go L!!!! :) Whose signature was that that says, "In lightweight valvetrains we trust"? So true. Quote Link to comment
72240z Posted December 14, 2009 Report Share Posted December 14, 2009 The L series is certainly the easiest since it bolts right in, also prob the cheapest as well when you take that into account. Very reliable motors. All that said, not as much fun as a vg lol. If your asking that question though I really vote you just drop in a L20b like Mike suggests. Quote Link to comment
ggzilla Posted December 14, 2009 Report Share Posted December 14, 2009 the easiest and most durable motor to put into a 510?Without a doubt, the L16. It's the easiest to fit and I would dare say the most durable too. Quote Link to comment
5dimer Posted December 14, 2009 Report Share Posted December 14, 2009 I have a KA24e in mine and love it!!!!!!!!!!!! Quote Link to comment
SRSANDS Posted December 14, 2009 Report Share Posted December 14, 2009 I SAY TORQUE MONSTER VG ALL THE WAY :cool: Quote Link to comment
DanielC Posted December 14, 2009 Report Share Posted December 14, 2009 You said easiest, and most durable. I would think everybody here would agree that the easiest would be a 4 cylinder L motor. Probably one of the more durable Datsun engines also. That would limit your power. It is your choice. Quote Link to comment
fuzz's '71 510 Posted December 18, 2009 Author Report Share Posted December 18, 2009 Well, let me try and go a different route. All of the yards around here suck when it comes to any L motors. During the time when they were building that damn dam over in China(Japan?) they crushed everything because the scrap prices skyrocketed. I have looked at the SR motors, but I really don't want to put in a turbo as this is not a race car but a cruiser. So what can I put in that can be found easy and cheap? I've looked at the jdm motors also and really don't know how reliable they are when they say they have between xx,xxx-xx,xxx miles on the motor and who would be a good vendor. So now which way should I go? Thanks. Fuzz Quote Link to comment
greybeard Posted December 18, 2009 Report Share Posted December 18, 2009 In that case, A Carb. type Z24 and a 5 sp. both can be found in a nissan truck (81 up to ? ) and will fit with some small mods and the right combo of parts. if a Z24 is not available then a KA, more work to swap. both should be reliable. if you go the Z24 route, later an L head can be swapped on, swap motor mounts, pan, and bellhousing, and you are back to stock looking, but lots more power. Quote Link to comment
