MicroMachinery Posted December 11, 2009 Report Share Posted December 11, 2009 Hey, I'm about to buy a rear sway bar for my 510. Anybody have anything against Suspension Techniques? If so, how come? And what would you go with if not them? Thanks Quote Link to comment
ichorid Posted December 11, 2009 Report Share Posted December 11, 2009 Is it adjustable? Dgr has an adjustable one. 1 Quote Link to comment
MicroMachinery Posted December 11, 2009 Author Report Share Posted December 11, 2009 Yeah, 3 way Quote Link to comment
ichorid Posted December 11, 2009 Report Share Posted December 11, 2009 It's probably the same as dgr'. I have never heard anything bad about st. Quote Link to comment
BJW's FiveTen's Posted December 11, 2009 Report Share Posted December 11, 2009 I am using a z31 rear bar on my dime. 19mm dia, $10 at PAP. Just had to make mounts for the rear control arms (just used some angle Iron). The crossmember already had holes to mount the bar. :D Quote Link to comment
5dimer Posted December 14, 2009 Report Share Posted December 14, 2009 I am using a z31 rear bar on my dime. 19mm dia, $10 at PAP. Just had to make mounts for the rear control arms (just used some angle Iron). The crossmember already had holes to mount the bar. :D Do you have any pix? Quote Link to comment
Yakuza Posted December 17, 2009 Report Share Posted December 17, 2009 ST is the way to go bro... Quote Link to comment
SubwayGUY4 Posted December 25, 2009 Report Share Posted December 25, 2009 well for my 2 cents dont get tokico. its bent under my car >_> Quote Link to comment
The Dat-side Posted November 27, 2010 Report Share Posted November 27, 2010 Gonna bump this thread. Anyone have anything so say about Top End Performance? Bigger front bar than ST I think. Less $ but doesn't look adjustable. Is the adjustability that great? http://www.racetep.com/datsunsusp.html Edit: Looks like the rear bar is adjustable. Quote Link to comment
69FJWagon Posted December 1, 2010 Report Share Posted December 1, 2010 no need for a rear bar, If you are running rear coilovers just go up in rear spring rate with the added spring rate it will eliminate the roll but still allow for articulation in the rear suspension and tire contact with the ground 2 Quote Link to comment
Chris#51EPGraham Posted December 3, 2010 Report Share Posted December 3, 2010 I've been pleased with the ST 3 way adjustable, and the quality is really nice. It's got disadvantages over the Quickor design on ground clearance. Quote Link to comment
The Dat-side Posted December 3, 2010 Report Share Posted December 3, 2010 no need for a rear bar, If you are running rear coilovers just go up in rear spring rate with the added spring rate it will eliminate the roll but still allow for articulation in the rear suspension and tire contact with the ground Right now I'm running stock springs, before I can afford coilovers I'm going to get the D50 or roadster springs and cut them. Ive heard lots of people say a rear bar isnt needed. I figure if I'm going to get a bigger front bar why not order a rear at the same time. Quote Link to comment
hang_510 Posted December 4, 2010 Report Share Posted December 4, 2010 if I'm going to get a bigger front bar why not order a rear at the same time. why not spend the $$ on stiffer springs or save for CO??? i dont run one Quote Link to comment
69FJWagon Posted December 4, 2010 Report Share Posted December 4, 2010 why not spend the $$ on stiffer springs or save for CO??? i dont run one I agree...What are your plans with the car? Like Hang I drive my 510s hard and autocross them I am lucky enough to have friends with an assortment of coilover springs so for me setting up a car is a constant thing depending on the track and surface so I am always messing with the car with a adjustable rear bar your stuck with 3 changes with rear coilovers the changes are open to a quick spring change, it takes me about 15 minutes to do a spring change and it totally changes the feel of a car and can get the car balanced with the front pretty easy. with that said I am struggling for a balanced set up at the moment mainly because im lasy and dont feel like making a spring change LOL Quote Link to comment
datzenmike Posted December 4, 2010 Report Share Posted December 4, 2010 I wouldn't spend too much money on one at first. Maybe try one and see where it goes. A rear sway bar will increase oversteer. Increasing the stiffness will increase oversteer. It's possible the car could use/need a rear sway bar and will accept it First, why do you think you need a rear sway bar? What does your car do now that you think a rear sway bar will help and not make worse? On hard cornering which end breaks loose first? Does the back end 'come loose' first and try to come around? this would be oversteer. Does the car tend to resist turning into a corner and follow a wider turn that you want? This would be understeer. Or is it equal and when pushed hard in a turn does it brake loose evenly or with very slight predictable oversteer? If you want to reduce oversteer and increase understeer you can reduce this by: Move weight to the front or reduce rear weight Decreasing slightly, the front tire pressure Increase slightly, the rear tire pressure Run stiffer front shocks or replace worn front shocks Run softer rear shocks Run less front camber or have front aligned. Increase rear camber if IRS equipped. Increase front sway bar diameter/stiffness Decrease rear sway bar diameter/stiffness If you want to reduce understeer and increase oversteer you can by: Move weight to the rear like relocating the battery or reduce front weight. Increase slightly, the front tire pressure Decreasing slightly, the rear tire pressure Run softer front shocks Run stiffer rear shocks or replace worn shocks Run more front camber or have front aligned. Decrease rear camber if IRS equipped. Decrease front sway bar diameter/stiffness Increase rear sway bar diameter/stiffness So as you can see there are lots of thing you can do to tune your ride for handling. Just adding a rear sway bar can easily add to your oversteer if you have it now. Changing even just one thing will affect everything else. 2 Quote Link to comment
Creepy Cruiser Posted December 4, 2010 Report Share Posted December 4, 2010 That is a great explanation Mike! Educating people on all the different factors is usually difficult for them to grasp, but that is very simple and to the point. I love it. Quote Link to comment
The Dat-side Posted December 5, 2010 Report Share Posted December 5, 2010 Wow, so much info, thanks. This was just to kinda add to my list for the future. This car is a daily first and foremost. When I corner the car feels like it's on it's side, so much body roll. It's stock in the rear. I want to lower it, I'll find some springs that bring it down and stiffen it up for now. CO are down the road but looks like I'll keep the sway bar on the back burner. I've heard 510s handle best with soft springs and large sway bars. But I've heard most people with rear bars have them disconnected. I'm going to need new shocks soon, so I'll just save up more and get CO. Quote Link to comment
datzenmike Posted December 5, 2010 Report Share Posted December 5, 2010 Well if you add a rear sway bar it may not affect the oversteer that much. If it does, you could add some stiffness to the front bar to balance this or alter anything in the top column to reduce understeer. Lowering the car will lower the center of gravity and cancel some of that 'top heavy' feeling too. Beware lowering too much to the point where the rear camber is badly affected and the tires tilt inward at the top. Hard cornering can add toe to the rear tires and the car will begin to steer from the back. This should obviously be avoided. This is an IRS problem not present in a solid axle. Quote Link to comment
Creepy Cruiser Posted December 5, 2010 Report Share Posted December 5, 2010 Wow, so much info, thanks. This was just to kinda add to my list for the future. This car is a daily first and foremost. When I corner the car feels like it's on it's side, so much body roll. It's stock in the rear. I want to lower it, I'll find some springs that bring it down and stiffen it up for now. CO are down the road but looks like I'll keep the sway bar on the back burner. I've heard 510s handle best with soft springs and large sway bars. But I've heard most people with rear bars have them disconnected. I'm going to need new shocks soon, so I'll just save up more and get CO. One thing is, everybody drives different and likes their car to fit there style and feel, so there is no magic setup. Just do the research, and then play with it till it fits you the best. Everybody likes different setups. I run an adjustable rear bar in mine, and I love it, I'd never give it up. However, I've run many many different setups till I found what I liked the best. It took many years of tweaking to get it dialed just the way I like it (different spring rates, dampening, sway bars, bushings, tires, etc... ). Right now I'm doing a KA swap in my buddies dime, and he loves his setup, and says it's the greatest setup there is. I personally think it's way too tall and way too soft. Mine is much lower and much stiffer, and feels good to me that way with my driving style, so everybody is different. Also, anybody who does a lot of racing will tell you, you have to change stuff up for every different track, and this if mostly true. If it's a street car mostly though, then you should be able to get it set up nice for every day driving and still have fun at the local autocross and such with no issues. Quote Link to comment
HRH Posted December 5, 2010 Report Share Posted December 5, 2010 No rear bar in mine, springs are stiff enough. Took out the rear bar in the Miata. Would reinstall for high speed track driving, but not for autocross. Not enough articulation to make it around cones without making the ass end super loose. Quote Link to comment
banzai510(hainz) Posted December 5, 2010 Report Share Posted December 5, 2010 I gave a rear bar to Icehouse As I dont run one either.(I just dialed the Koni's up harder for retraction and seems good) well anyway I gave Ichouse a rear bar. I think he traded it to a kid for a pack of cigarettes. Quote Link to comment
The Dat-side Posted December 5, 2010 Report Share Posted December 5, 2010 Damn, I should start smoking. Quote Link to comment
