JDM510 Posted November 28, 2009 Report Share Posted November 28, 2009 (edited) i found this on zilvia thought some might get a kick out of it... http://zilvia.net/f/off-topic-chat/292173-electric-turbo-fail.html#post3156388 http://cgi.ebay.com/ebaymotors/garrett-electric-custom-turbo-charger-project-LOOK_W0QQcmdZViewItemQQhashZitem20ae3eaa77QQitemZ140362295927QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Incase you cant read the discription this is a project of mine, its a garrett turbo charger with an electric blower motor connected to it so it eliminates the pain of running all the exaust piping and other pains of turbo charging your ride, plus not to mention the money you will be saving and still get the power you desire. right now it has a wall plug on the motor so you will need a cross over from that to your battery( they have them at walmart for around 20 bucks and what that does is you plug it into your cigurette lighter and it has plug in ports for the two prong wall plug. this electric turbo is all silled up with silicone so no air leakes. you may want to add another layer of sealeant though just to be safe. im not sure exactly how much boost it pushes but i do know it blows enough to use it as a leafe blower. it has alot of power that would make a big difference in you ride.i dont have any of the air tubes or filter for it. what ya see in the pictures is what ya get. like i said this is a project of mine that i built my self. i was gonna put onto my eclipse but the computer went out of it so im selling the parts i have for it. this this pushs alot more air than those plastic electric super chargers. if you have any questions feel free to ask. i only except paypal and only ship inside the usa thank you Edited November 28, 2009 by JDM510 Quote Link to comment
lynchfourtwenty Posted November 28, 2009 Report Share Posted November 28, 2009 hahahahahahhaha :lol::lol::lol::lol: Quote Link to comment
72240z Posted November 28, 2009 Report Share Posted November 28, 2009 I thought at 1st he would at least use the turbo compressor wheel run by the motor but damn he even failed there lol. Quote Link to comment
lynchfourtwenty Posted November 28, 2009 Report Share Posted November 28, 2009 thats what i pictured in my head also, then i was like wtf? Quote Link to comment
ariascarlos1990 Posted November 28, 2009 Report Share Posted November 28, 2009 how much shipped to 97236? LMAO! Quote Link to comment
nismo dr Posted November 28, 2009 Report Share Posted November 28, 2009 winning bid $39.99 their were 2 bids!!!!! Quote Link to comment
JDM510 Posted November 28, 2009 Author Report Share Posted November 28, 2009 yeah i thought he would of used the impeller shaft or whatever too... but to my dismay i seen plastic wheel in their was like WTF FAIL FORSURE!!! Quote Link to comment
Skib Posted November 29, 2009 Report Share Posted November 29, 2009 fucking WOW :rolleyes: Quote Link to comment
Jayden71 Posted November 29, 2009 Report Share Posted November 29, 2009 :lol::lol: The silicone adds 5psi of boost right?? If you add another layer does that meak it 10psi?? :lol::lol: Quote Link to comment
FoxyRoadster Posted November 29, 2009 Report Share Posted November 29, 2009 It is a doable idea.. just not enough power from that tiny electric motor.. I know BMW was researching a hybrid turbo to reduce lag at one point. I will admit, I bought the gatorsupercharger book.. Dont goto their site right now through as it seems to have been infected with some kinda trojan but they suggest making a supercharger using the metal impeller off a toro leaf vaccum for the complete DIY supercharger.. They also suggest just using the turbo and welding a bearing and pulley onto the turbo to make it a supercharger. :lol: You wont get much boost from either but lol 5-8psi for below 200 bucks isn't too bad.. But I'd not want any of those jury rigged contraptions on anything but a junkyard motor. Quote Link to comment
72240z Posted November 29, 2009 Report Share Posted November 29, 2009 (edited) Most turbos run 150-250 THOUSAND rpms to run even low boost. I highly doubt either with a pulley as a sc or any cost effective electric motor would yield anything close to 5-7psi. Idk the math thats just what I think when I apply the logic lol. I think the sc conversion is the most legit but you couldn't just weld a bearing/pulley on there you'd have to add a gear(s) to up the rpms to optimum levels. Edited November 29, 2009 by 72240z Quote Link to comment
FoxyRoadster Posted November 29, 2009 Report Share Posted November 29, 2009 Most turbos run 150-250 THOUSAND rpms to run even low boost. I highly doubt either with a pulley as a sc or any cost effective electric motor would yield anything close to 5-7psi. Idk the math thats just what I think when I apply the logic lol. I think the sc conversion is the most legit but you couldn't just weld a bearing/pulley on there you'd have to add a gear(s) to up the rpms to optimum levels. think laaaaarge pulley lol and well psi isn't the issue its CFM and I dont know how much it would make.. I dont wana spend the time or money on something iffy so I bought myself an SC14 off a toyota. Quote Link to comment
72240z Posted November 29, 2009 Report Share Posted November 29, 2009 (edited) think laaaaarge pulley lol and well psi isn't the issue its CFM and I dont know how much it would make.. I dont wana spend the time or money on something iffy so I bought myself an SC14 off a toyota. Large isn't the word, if you have a T28 turbine wheel of 60mm that needs to spin at 180k rpm hooked up to a engine spinning 4000rpm you would need a pulley 1890mm in diameter lol. It wouldn't even fit under the hood. You HAVE to have gears, thats why all centrifugal sc's (that I know of anyway) do. I still say psi, a head will only flow some much cfm naturally. Then you have to compress the air in order to gain more. no? Edited November 29, 2009 by 72240z Quote Link to comment
FoxyRoadster Posted November 29, 2009 Report Share Posted November 29, 2009 anyone have a junky turbo? I've got the book, I'll send the designs on doing the pulley setup :P just don't be disappointed in it :lol: I'm actually curious to see if it would work now. Quote Link to comment
hughdogz Posted November 29, 2009 Report Share Posted November 29, 2009 It's do-able with a slighty different kind of setup: http://forums.hybridz.org/showpost.php?p=1095645&postcount=1 Quote Link to comment
datzenmike Posted November 29, 2009 Report Share Posted November 29, 2009 (edited) Red rising sun hood stripes FAIL Why not mount that leaf blower in the trunk out of sight? No worries about turbo lag. Edited November 29, 2009 by datzenmike Quote Link to comment
Skib Posted November 29, 2009 Report Share Posted November 29, 2009 lol that looks like someones lemons car :lol: Quote Link to comment
hughdogz Posted November 29, 2009 Report Share Posted November 29, 2009 That's RoostMonkey's Lemons car (the guy that makes the RTz mounts and LS1 coil brackets, etc.) I'm not sure if he was going for a rising sun hood, but he did say he has plans to sawzall the hood for the blower. I don't see any advantage to mounting the blower in the back, unless you like 2-stroke exhaust and noise... Quote Link to comment
datzenmike Posted November 29, 2009 Report Share Posted November 29, 2009 Wouldn't have to cut the hood and the embarrassment level is lower. Quote Link to comment
Madness Posted November 29, 2009 Report Share Posted November 29, 2009 "Wanna race?!" "Yeah! Let me just pull start my charger!" :lol: Damn pull start 2 strokes. Can never get them on the fist pull... Quote Link to comment
