nukeday Posted November 19, 2009 Report Share Posted November 19, 2009 I'm curious what ever happened to the SuperTrapp mufflers? Seems the invention of fart cans sort of ran them out of the import scene. I don't see much on here about them, but they have plates for adjusting backpressure/noise. I always liked the way they sounded... Quote Link to comment
Just Joel Posted November 20, 2009 Report Share Posted November 20, 2009 I was wondering the same thing while flipping through the Summit catalog the other day... Later Joel Quote Link to comment
a.d._510_n_ok Posted November 22, 2009 Report Share Posted November 22, 2009 how would one of these affect an exhaust system :lol:? Quote Link to comment
Braden Posted November 23, 2009 Report Share Posted November 23, 2009 got my exhaust buttoned up on my truck today, welding is shit but what do you expect for 60 bucks, i will get a more permanent setup on this pos later. anyways the thrush turbo is so damn quiet, its a ittle rumbly in the rear but in the cab its quiet, it feels like a tiny truck again!!!! Quote Link to comment
banzai510(hainz) Posted November 24, 2009 Report Share Posted November 24, 2009 next system i do is going to be a Thrush or Cherrybomb 2 turbo also. I like quiet. with slightly different than stock. If you have a REAL motor it wont matter anyways. just up size the pipe. Quote Link to comment
Braden Posted November 24, 2009 Report Share Posted November 24, 2009 yeah the trush is super quiet (to me) it is a tiny bit rumby behind the truck but inside the truck it is super quiet, when i really get into working on this thing i will buy several different mufflers and try them out and see which one i like the best (i work at a parts house so i can take damn near anything back!!! ha ha) but if you want quiet but a subtle rumble try a thrush turbo, as for sound i give it a 3 out of 5, as for durability, i guess we will see Quote Link to comment
Jorge chee Posted April 5, 2022 Report Share Posted April 5, 2022 I just got through putting my 71 510 back together. It has a L20b motor in it. The motor is kinda loud. It came with headers, 3 ft. length of 21/2 pipe, into a small muffler and ends right there. What do I need to make this motor quiet and sound good. All help will be greatly appreciated. Quote Link to comment
datzenmike Posted April 5, 2022 Report Share Posted April 5, 2022 Is it round and tapered at the ends? Datsun uses resonators to tone down the exhaust before running through a muffler. The resonator is see through with a tube within a tube with lots of holes in it. It allows the exhaust to expand and slow down but by itself does little to muffle the noise. Possibly your 'muffler' is a straight through 'glass pack' that will do little to deaden the sound. Definitely running a pipe back to the rear of the car will help move the noise behind you. Silencing the exhaust means slowing it down and spreading the pulses out but this adds resistance to flow which needs to be avoided. It's a balance between noise and good flow and quiet and bad flow at high engine speeds. Take this 'muffler off and see what you have. If it's a resonator you can add pipe to the rear and fit a low restriction turbo muffler and possibly a tail pipe over the rear axle. Or remove the present 'muffler' and pipe to the rear and a turbo style muffler. Turbo mufflers are low resistance to flow and contain baffles and fiberglass packing to absorb sound. Totally avoid any muffler that is 'see through'. I would look at a larger diameter pipe, say 1 3/4 or 2" but not larger. My 710 is an L20B with the earlier L16 'cast iron header' manifold. The twin down pipe is a modified 240sx from a KA24E that joins them into one into the original stock resonator then a 1 7/8" pipe back to an expantion to 2 1/8" to fit a 2" inlet $25 cheap generic (quiet) replacement muffler with a 2" outlet with a 45 degree down turn just forward of the rear axle. This is identical to the stock muffler but larger dimensions. It has a nice low rumble note when idling but quiets as it revs up. It's comfortably quiet at all part throttle and only gets loud at full. I think the exit under the car reflects the sound off the pavement and up into the body. It would be quieter with a tail pipe but no way, I like it the way it is. Quote Link to comment
banzai510(hainz) Posted April 6, 2022 Report Share Posted April 6, 2022 chee I say get a 2 to 3 chamber Turbo muffler in the smallest size. Stock case size with offset inlett out let like the stock one. This will be alot quieter. 2.1/2 is a bit big but neck it down to 2inch would be better Quote Link to comment
