kansascity1 Posted September 21, 2007 Report Share Posted September 21, 2007 word, can't wait for the frontend pics. I need to get mine down, but I'm still trying to figure out exactly how I wanna do it. Quote Link to comment
pugz Posted September 21, 2007 Author Report Share Posted September 21, 2007 i looked uner mine and it looks to be jsut a basic set up. firestore 2500 bags mounted to the lca and a bag bracket welded to the frame. i have 1 shock up front lol. need to either take out one or add another one Quote Link to comment
kansascity1 Posted September 22, 2007 Report Share Posted September 22, 2007 did they dish the frame to clear the bag? Quote Link to comment
pugz Posted September 22, 2007 Author Report Share Posted September 22, 2007 i dont think they did. though the front bags are slightly touching the spindle. i want to switch them to slam bags so they are thinner and wont touch Quote Link to comment
kansascity1 Posted September 23, 2007 Report Share Posted September 23, 2007 From what I've been told the only bag you can run without rubbing is a Contitech (w/out dishing the frame). Just what I've heard though. Quote Link to comment
pugz Posted September 23, 2007 Author Report Share Posted September 23, 2007 going from slam's specs the firestones have a max diameter of 6.4" for the 2500 bag but the slam max dia. is 5 Quote Link to comment
tnip Posted September 23, 2007 Report Share Posted September 23, 2007 what about the inflated and deflated heights? the same? Quote Link to comment
pugz Posted September 23, 2007 Author Report Share Posted September 23, 2007 according to slam their width stays constant Quote Link to comment
tnip Posted September 23, 2007 Report Share Posted September 23, 2007 no the height of the bag. also there's no way the width could be consistant from delated to inflated, that would only work if it was a cylinder, not a bag. Quote Link to comment
pugz Posted September 23, 2007 Author Report Share Posted September 23, 2007 the slam stay constant and the max dia inflated on a slam is 5 inches for a slam re 5 bag. the deflated height is the same as a firestone. go to www.slamspecialties.com and look at the compare section. Quote Link to comment
tangent Posted September 25, 2007 Report Share Posted September 25, 2007 Im in Oklahoma and have never seen that truck running around.. Did you pick it up in the City??? When you start digging into the front end.. be very carefull to save the front wheel bearings.. Finding replacements will be most probably impossible. Quote Link to comment
datsunfreak Posted September 25, 2007 Report Share Posted September 25, 2007 Im in Oklahoma and have never seen that truck running around.. Know of any for sale? :D Quote Link to comment
pugz Posted September 25, 2007 Author Report Share Posted September 25, 2007 Im in Oklahoma and have never seen that truck running around.. Did you pick it up in the City??? When you start digging into the front end.. be very carefull to save the front wheel bearings.. Finding replacements will be most probably impossible. i met the guy in okc he came from ponca city but the guy who had it before him i dont know where he was. as for the front bearings. im not too worried about them. im gonna build custom upper and lower control arms and convert it all to 5 lug and disk brakes. but thats coming a lil later Quote Link to comment
pugz Posted September 27, 2007 Author Report Share Posted September 27, 2007 ok here are the best pics i could get for now Quote Link to comment
kansascity1 Posted September 27, 2007 Report Share Posted September 27, 2007 And that is why the frame needs to be dished. It allows the bag plate to be mounted closer to the frame and gives relief for the bag, which in turn keeps the bag from rubbing. Thanks for the pics, by the way. Quote Link to comment
kansascity1 Posted September 27, 2007 Report Share Posted September 27, 2007 Steven, check out those tie rod ends, they don't look factory to me. You think we ought to look into something like that or just notch the frame? Quote Link to comment
yello620 Posted September 27, 2007 Report Share Posted September 27, 2007 Those tie rods are a kit that is made by TRW (federal mogul) or MOOG. Cant remember at the moment. I would be curious to know if there are any part numbers on the parts at all. The number would be stamped into it in the flat spot around the grease zerk. And how long is the adjusting sleeve, thread size? Jason Quote Link to comment
]2eDeYe Posted September 27, 2007 Report Share Posted September 27, 2007 Yep, those are moog parts. I sourced them through rockauto.com and then picked them up at the local Action Auto...didn't have time to wait for shipping. MOOG Part # ES2340A {Complete Tie Rod Assembly} Frt Strg; LH; At Steering Arm; 2WD MOOG Part # ES2339A {Complete Tie Rod Assembly} Frt Strg; RH; At Steering Arm; 2WD I got the entire steering setup for about $200 Quote Link to comment
pugz Posted September 27, 2007 Author Report Share Posted September 27, 2007 ya i wasnt thinking the steering was all factory. im gonna get he slam bags and see if that helps with the rubbing. ill keep yall informed on that. the bags barely touch the spindle at full lift. not sure about jsut at regular ride height. im gettin the brakes fixed and my viair compressors installed should have it back tomorrow. also installing new rocker switches for the airride and a viair gauge Quote Link to comment
kansascity1 Posted September 28, 2007 Report Share Posted September 28, 2007 cool man, keep the updates coming. Let me know how those slams work in there. Quote Link to comment
thor Posted October 1, 2007 Report Share Posted October 1, 2007 Hey Pugz I just came over from NC and am looking around. I know I've said it already but the truck is looking great! (I changed my name cause no one can remember iN1554Nt lol) Anyway I'm going to keep looking around. Les Quote Link to comment
Pacific coast Datsun Posted October 1, 2007 Report Share Posted October 1, 2007 Les welcome to Ratsun. Post some pics of the NL see we can see it :cool: Quote Link to comment
pugz Posted October 1, 2007 Author Report Share Posted October 1, 2007 cool good to see u made it here les. and ya post up some pics of the nl Quote Link to comment
fisch Posted November 13, 2007 Report Share Posted November 13, 2007 Pugz, I caught that your sweet 521 is up for sale on the web. I hope it goes to a worthy home. That thing is freaking AWESOME! Quote Link to comment
