slinginabullet Posted July 3, 2009 Report Share Posted July 3, 2009 (edited) Well it started out with a L20 we all know what that looks like so I posted pics. of the swap and befor I start the body work. So it has a ka24de out of a 92 s13 along with the trans it all went in with out to much fab work shortin the drive line, custom intake, electric fan rubbed on the firewall a little for the ka trans. to fit it only took really about two weeks to get the motor and trans. stuffed but another two weeks rebuilding the bottom end of the motor and getting parts ordered for the motor to work harness, fuel pump, header and of course new fluids too! Edited July 3, 2009 by slinginabullet Quote Link to comment
slinginabullet Posted July 3, 2009 Author Report Share Posted July 3, 2009 Well I geuss I will post pics. latter I'm having some trouble pulling them from my album Quote Link to comment
bonvo Posted July 3, 2009 Report Share Posted July 3, 2009 for pics use photobucket and welcome to ratsun Quote Link to comment
bagged_datsun Posted July 3, 2009 Report Share Posted July 3, 2009 wow looks good man Quote Link to comment
slinginabullet Posted July 3, 2009 Author Report Share Posted July 3, 2009 thanks hope to get the body work finished befor winter then start on the inside durring the cold season Quote Link to comment
bagged_datsun Posted July 3, 2009 Report Share Posted July 3, 2009 thanks hope to get the body work finished befor winter then start on the inside durring the cold season lol im hoping the same thing with mine, just money is spent other places then my truck : ( Quote Link to comment
yello620 Posted July 3, 2009 Report Share Posted July 3, 2009 Looks like you are still using the stock radiator? How is that working? Does it seem like it cool well enough or does it seem like the electric fan is on too often? Quote Link to comment
slinginabullet Posted July 3, 2009 Author Report Share Posted July 3, 2009 I just have the fan hard wired to a switch for now it is running from 170 to 190 on these hot days in medford and I just keep the switch on but I don't even hear the fan with the motor running at idle I mostly hear the fuel pump. Quote Link to comment
DISLEXICDIME Posted July 3, 2009 Report Share Posted July 3, 2009 man when do i get to drive it ! Quote Link to comment
slinginabullet Posted July 5, 2009 Author Report Share Posted July 5, 2009 man when do i get to drive it ! when i get up that way you can rip it around but i'm still having trouble getting the tach to work :mad: at idle it kinda bounces around a little then sits, might be the tach but it worked just fine with the L20 and it only sat ardond for about a month. the only wire that i changed was the green wire from the tach took off the old coil and ran it to the ylw/red wire and still nothin. Quote Link to comment
DISLEXICDIME Posted July 5, 2009 Report Share Posted July 5, 2009 (edited) my tack just did this. The spade that slides on the negative side of the coil had not ben crimped well and was moving in side the spade making the tack jump around and some times not work till 3 grand or so Plus that tack i gave you is from the 70's it was in a old 510 rally car from the 70's before i got it maybe its just old Edited July 5, 2009 by DISLEXICDIME Quote Link to comment
slinginabullet Posted July 6, 2009 Author Report Share Posted July 6, 2009 i fixed it :D just found the signal wire off the coil and ran that, out of the six wires on the coil :confused: Quote Link to comment
Farmer Posted July 6, 2009 Report Share Posted July 6, 2009 Going to have to stop by one of these days to check that thing OUT. Sweetness larry Quote Link to comment
slinginabullet Posted July 6, 2009 Author Report Share Posted July 6, 2009 anytime i'm thinking about going to GP real soon for the first freeway drive Quote Link to comment
slinginabullet Posted July 6, 2009 Author Report Share Posted July 6, 2009 a little close up old schoold vdo tach Quote Link to comment
DISLEXICDIME Posted July 6, 2009 Report Share Posted July 6, 2009 did you use the three core rad? Quote Link to comment
slinginabullet Posted July 7, 2009 Author Report Share Posted July 7, 2009 no just the two core for now i need to make the three core all flashy like this one:D Quote Link to comment
DISLEXICDIME Posted July 7, 2009 Report Share Posted July 7, 2009 that thing has to be running hot the 2 core wouldn't cool my l18 and we have the same 2 core Quote Link to comment
slinginabullet Posted July 7, 2009 Author Report Share Posted July 7, 2009 that thing has to be running hot the 2 core wouldn't cool my l18 and we have the same 2 core it was 102 the other day and i was mobin around town and it got to about 190. befor i put the radiator in i cleaned it out combed the fins flushed the heater core and the electric fan pulls well. i still would like to put in a aftermarket scirocco stile. but for now it works Quote Link to comment
slinginabullet Posted September 26, 2009 Author Report Share Posted September 26, 2009 Quote Link to comment
slinginabullet Posted September 26, 2009 Author Report Share Posted September 26, 2009 I wanted to roll it with out the bed so bad but I didn't want to take the time to temp. wire in lights it's my daily driver :D Quote Link to comment
DISLEXICDIME Posted September 26, 2009 Report Share Posted September 26, 2009 you need the extra weight in the back Quote Link to comment
slinginabullet Posted October 3, 2009 Author Report Share Posted October 3, 2009 ya I know but it would have been fun for a day :D Quote Link to comment
[Drift_Monk] Posted October 26, 2009 Report Share Posted October 26, 2009 hey im new to ratsun and i just got a 73' 620 and want to drop in a ka24de on it... i love the ka:p... i used to own a 240sx but fell in love with the 620 so i sold it and got the 620... i want to know if the ka drop right in or do i have to mod the mounts? as for the fuel pump wich one do i have to use? and also what other mods do i have to do to it to drop in the ka? can you guys help? Quote Link to comment
