fisch Posted September 9, 2007 Report Share Posted September 9, 2007 Hey guys the owner doesn't know much about this carb and kit, and the 521 I bought is my first classic vehicle, so I don't know much. Can you tell me if this is the right carb for my L16 and is this everything I would need to hook it up in place of the stock unit? Thanks, Scott Quote Link to comment
fisch Posted September 9, 2007 Author Report Share Posted September 9, 2007 And are what other model Dats or Nissans would have a direct carb swap for the L16 w/o using an adapter kit? Thanks y'all! Scott Quote Link to comment
datzenmike Posted September 9, 2007 Report Share Posted September 9, 2007 All the 4 cylinder L series should bolt on, not too sure about the jetting, and the 'newer' ones (L20B) may have extra vacuum ports for emissions. I have bolted an L20B carb onto a Z22 intake, so it might be safe to say the Z20 and Z22 carbs will bolt to the L 16 BUT the linkage faces the wrong way on them and they are covered with emission hoses. The Z24 has a larger bolt pattern and more hoses.. Quote Link to comment
RacnJsn95 Posted September 9, 2007 Report Share Posted September 9, 2007 With keeping your stock manifold, the only carbs that is a direct swap without adaper plates, are stock carbs. I assume any carb from an L 4 engine would fit. That carb you pictured looks to be a Webber carb, and it wont fit without adapter plates, and I see they're not pictured. Quote Link to comment
kiznook Posted September 9, 2007 Report Share Posted September 9, 2007 go for it. Switching to a Weber is a good simple upgrade. And adapter plates are cheap. They're dead simple too, I think blind retard monkeys in caves deep in the jungle could rebuild them. Quote Link to comment
datsunfish Posted September 9, 2007 Report Share Posted September 9, 2007 That carb looks to be a holley 5200 or a weber dfav.Both great carbs but would need an adapter plate and the linkage is backwards.Which is ok but will eventually wear out the cable housing due to binding. Any Datsun hitachi carb will work.You can plug off the vacuum lines and be ok.Just so much more to go wrong.Springs,bb's diaphragms..yuck.Whatever you do get a weber or a holley.I wouldnt worry too much about jetting either.I run a holley jetted for a ford 2.3 on my L18 and it runs great. Quote Link to comment
datsunaholic Posted September 9, 2007 Report Share Posted September 9, 2007 You won't wear out the cable if you put the linkage on upside-down, BUT you need a tall adaptor. There IS a weber that fits the stock L-series intake with no adapter- but it's been out of production for 10-15 years. Weber 32/34 DFT. I stuck one on my '74, runs pretty good, but you have to install it backwards. It was Weber's smog-legal carb. Quote Link to comment
datsunfish Posted September 9, 2007 Report Share Posted September 9, 2007 I see the dft on ebay alot.I got that wierd 32/34 dgev and put it on my l16 and it is awesome.There is a lot less vacuum on a L16 so the smaller secondary is nice for a tad more torque. If you are a cheap ass,such as myself,you can find a ton of the holley 5200 and 5220 carbs on ebay.Search around for ford pinto,mustang2 chevy vega for the 5200 and dodge for the 5220.Often a pro reman goes for around $60.They are a hassle for the aircleaner though and you would need to modify the linkage to the ball type.I just weld on a stock cable style. Quote Link to comment
datsunaholic Posted September 9, 2007 Report Share Posted September 9, 2007 DFTs were very popular with Chevy LUVs. Which used the Hitachi DCH340 stock, just like the Datsun L20B. Quote Link to comment
datsunfreak Posted September 9, 2007 Report Share Posted September 9, 2007 There IS a weber that fits the stock L-series intake with no adapter- but it's been out of production for 10-15 years. Weber 32/34 DFT. I stuck one on my '74, runs pretty good, but you have to install it backwards. It was Weber's smog-legal carb. I have a new one if anybody wants it. I put it on my 510, but I'm switching to SUs very soon. Quote Link to comment
fisch Posted September 10, 2007 Author Report Share Posted September 10, 2007 I have a new one if anybody wants it. I put it on my 510, but I'm switching to SUs very soon. Rock on guys, great advise. This 521 hasn't run in ten years. I haven't really dug into it yet, but the last owner mentioned the carb was having problems before parking it, so I am trying to think ahead. How much were you wanting for your 32/34 Datsunfreak? I am hoping to get into the engine next weekend an will know more about the condition of what I have. PM me if you like! Scott Quote Link to comment
yello620 Posted September 10, 2007 Report Share Posted September 10, 2007 That weber dft that is pictured appears to me to be missing all the choke parts, The choke butterflies and the rod that holds them. However, i am not real familiar to that carb, just the DGV series carb. Holic would know better than me. Jason Quote Link to comment
banzai510(hainz) Posted September 10, 2007 Report Share Posted September 10, 2007 AVOID that carb!!!!!!!!! main barrel is on the wrong side. It will work but get the 32/36 DGV type model with the main barrel on the other side. The manifold is set up for the main barrel near the valve cover side. This carb you show is not set up for the L series setup. But it will work But Datsun NOOb bought the same one and the plate got stuck and blow the choke out!!!!!!!!!! webercarbsdirect has some photos of the correct carb 32/36 DGV 5a. DGEV 32/36DGV-IC(idle cutoff best with the L20 open heads) maybe try these guys http://www.allcarbs.com/shop.html also if you buy the correct DGV weber the stock datsun cable pull assemble fits on the weber!!!!!!!Remember this!!!!!!!!!! Quote Link to comment
datsunfreak Posted September 11, 2007 Report Share Posted September 11, 2007 How much were you wanting for your 32/34 Datsunfreak? Maybe $40? It has an electric choke and an idle cut-off solenoid to stop dieseling. It works great, I just want the better throttle response of the SUs. Let me know if you want it. Quote Link to comment
harshman_b Posted September 15, 2007 Report Share Posted September 15, 2007 Datsunfreak, Hainz refered me to this site from NWDE.org. It looks like I'm in need of a carb for my pickup. Do you still have yours for sale? How are the butterfly bushings? Can you send me a pictureif you still have it? Email -> abcharshman@yahoo.com. Brad Quote Link to comment
datsunfreak Posted September 15, 2007 Report Share Posted September 15, 2007 Do you still have yours for sale? Yeah, but it'll be a few weeks before it's ready to ship out. How are the butterfly bushings? Well, it's brand new... So I'll say they are "good"... :D Quote Link to comment
harshman_b Posted September 15, 2007 Report Share Posted September 15, 2007 Consider it sold as soon as you get it ready to be shipped. I would still like to get a picture of first. But if it is brand new then you can consider it sold. Would cash speed things up? PS what kind of adapters would I need? I'm already running a 32/36 dgv Quote Link to comment
banzai510(hainz) Posted September 17, 2007 Report Share Posted September 17, 2007 40$ is a good price. A Great price. I almost should send more money myself The Carb will fit if you already have a 32/36 already on there and reuse the gasket. Im hopeing its the carb. if not you have another carb as a spare Quote Link to comment
