Icehouse Posted September 10, 2007 Report Share Posted September 10, 2007 That looks great Fineline, your fab work is awsome. I'm glad you posted it here to :) the stance is very atractive :) your truck keeps getting better and better. I've been daily driving my 620 for some time, I really want to do that setup, my truck rides and handles like shit. I drove my 510 yesterday, when I got back in my 620 it felt like such a "truck" I gotta fix that :D seeing your truck is modivating me big time. Quote Link to comment
69FJWagon Posted September 11, 2007 Report Share Posted September 11, 2007 Looks good that low Brandon...looks like it sits about half an inch lower than before cant wait to go for a ride or drive it...hint hint :D I know a certain white truck that will be getting a set along with a brake kit. found a set of mikuni carbs for my LZ 2.2 so it may be a while Quote Link to comment
Icehouse Posted September 11, 2007 Report Share Posted September 11, 2007 They are QA1 p/n# 3855. Theres a company on E-bay that sells them for about $300 as set shipped. I got mine local but summit also has them. I am using 300 lbs. springs. I did a search with no luck on the exact set you have. Are all the kits the same "dampener"? With different height springs? Quote Link to comment
0.C. Posted September 11, 2007 Report Share Posted September 11, 2007 Looks fucking awesome. I was thinking about coilovers or airbags. but since I've had bad experience with airbags, I'll guess I'll trow some coilovers on my 521 eventually. Quote Link to comment
Fineline Posted September 11, 2007 Author Report Share Posted September 11, 2007 Thanks for the compliments guys. Here is the company that sells them on E-bay. http://cgi.ebay.com/ebaymotors/QA1-Proma-Star-Adjustable-Coilover-Shock_W0QQcmdZViewItemQQcategoryZ33590QQihZ009QQitemZ190150225416QQrdZ1QQsspagenameZWDVW You can also call them and they will help you out. When I set everything up I put the truck on stands and removed the torsion bars. I then jacked the wheels up to ride height and with the lower mount in place figured where the upper needed to go. The company reccommends 9.5" to 10" mounting height. Once the mounts were in and reinforced I just had to crank up on the springs to get them where I needed them. The great thing about these shocks is they have an adjustable dampening to them. I have them at 4 clicks for my commute as to not beat the crap out of myself (I save that for in front of the computer) But can stiffen them up fo a little "spirited" driving. The whole process takes about 30 seconds. I will try and find a source fotr the brackets I used. They really made it quite easy. At first I cut the top of the shock tower but in hindsight I really didnt even have to do that. I think total this whole mod with shocks, springs, and brackets cost just over $400. Quote Link to comment
Fineline Posted September 11, 2007 Author Report Share Posted September 11, 2007 Looks good that low Brandon...looks like it sits about half an inch lower than before cant wait to go for a ride or drive it...hint hint :D I know a certain white truck that will be getting a set along with a brake kit. found a set of mikuni carbs for my LZ 2.2 so it may be a while So do I have to start with the truck before I get to race the FJ? Next month baby! Quote Link to comment
]2eDeYe Posted September 11, 2007 Report Share Posted September 11, 2007 Thanks for the link...gonna have to start saving pennies again :D Quote Link to comment
69FJWagon Posted September 11, 2007 Report Share Posted September 11, 2007 So do I have to start with the truck before I get to race the FJ? Next month baby! Line emm up!!! :D :eek: Quote Link to comment
Fineline Posted September 13, 2007 Author Report Share Posted September 13, 2007 I'll so smoke your ass for like 20 feet!:P Quote Link to comment
Icehouse Posted September 13, 2007 Report Share Posted September 13, 2007 Fineline you also used "prefabbed" brackets? Dam this just keeps getting better and better :D Quote Link to comment
tnip Posted September 25, 2007 Report Share Posted September 25, 2007 fineline: i am curious about the brackets. were they prefabbed or did you make them? if you bought them is there a link you could throw my way? if you made them have you considered making them to sell? Quote Link to comment
]2eDeYe Posted September 25, 2007 Report Share Posted September 25, 2007 Which brackets? As I understand it the lower coilover bracket is purchased...everything else fineline made up out of thin air ;) If you mean his brake brackets he did have them for sale...I have a set of his rear brackets :D Quote Link to comment
tangent Posted September 25, 2007 Report Share Posted September 25, 2007 The build up was a bit easier to see in the pics I got :) Glad to hear it drives as nice as you were expecting!!! So about how far does it compress the springs as you let the weight off the jack and onto the tire? Yeah if you have some more pics that would be great.. Would this work on the 521?? Quote Link to comment
tnip Posted September 25, 2007 Report Share Posted September 25, 2007 the upper coilover brackets. and i didn't realize the lower bracket was different. so basically just interested to know what is necessary to do this conversion, aside from removing the torsion system and purchasing the correct coilovers. Quote Link to comment
Fineline Posted September 25, 2007 Author Report Share Posted September 25, 2007 You are correct. I used a pre-fabbed shock relocating bracket as a starting point. I got them from a local shop but i'll be dambed if I can find them anywhere online. When I have the time I am going to go back to the shop and see if I cant get a company name that manufactures them. They are really easy in design. Basically they are a piece of 3/8" x1.5"x 12" with ears welded to the top of them. This design allowed me to basically notch out the top of the shock mount and slide these in and pick how high I wanted the upper mount. This also strengthened the whole thing because the 3/8" steel is welded to the entire face of the frame. On top I welded a piece to the top of the ears and tied that down to the back side of the mount for strength. Maybe some of you guys that are into the airbag thing know more websites that have brackets. I have tried on the net looking for "shock relocating brackets" and such with no luck. Quote Link to comment
Fineline Posted September 25, 2007 Author Report Share Posted September 25, 2007 The lower mounts are just ears welded to the arm that kicked it out twords the kingpin giving it a betyter angle. They rest at about a 20 degree angle. This also gives it more travel. Quote Link to comment
tnip Posted September 25, 2007 Report Share Posted September 25, 2007 i was just curious because one) i know anything you make is gonna be trick and awesome and two) since i don't have a welder or any experience welding the ideas i come up with i think that must not work cause that sounds too easy, but basically i think i understand what you did with the upper mount. what's the deal with the lower control arm that redeye mentioned? edit: you answered my question as i was typing it, thanks :D Quote Link to comment
tnip Posted October 3, 2007 Report Share Posted October 3, 2007 fineline: gotten a chance to find out the manufacturer info on that upper mount? Quote Link to comment
Z-train Posted October 3, 2007 Report Share Posted October 3, 2007 Fineline-nice job.Coil-overs just got added to the list for the wifes KC.What year & application are those wheels:confused: Quote Link to comment
Fineline Posted October 16, 2007 Author Report Share Posted October 16, 2007 Ok guys sorry for the delay but i'm tracking down the brackets. I know I can get them local but I still dont know who manufactures them. I will keep you all posted. Quote Link to comment
]2eDeYe Posted October 17, 2007 Report Share Posted October 17, 2007 Those are titan/armada wheels ;) Quote Link to comment
tnip Posted October 17, 2007 Report Share Posted October 17, 2007 update on this fineline? very curious to see your rear setup when finished! :D Quote Link to comment
Fineline Posted October 17, 2007 Author Report Share Posted October 17, 2007 update on this fineline? very curious to see your rear setup when finished! :D Probably not much for now. Im getting the front end ready for next month. For now I found some pearches from an old Toyota truch that converts the bottom shock mount to an eyelet type instesd of the stud. They have the same inboard mounting direction so I should be able to bolt them on and run adjustable QA-1's. All this should be bolt on but well see. Right now the truck handles great with the leafs out back and I have plenty of other things that need attention. Quote Link to comment
Cruzn620 Posted October 23, 2007 Report Share Posted October 23, 2007 Check out http://www.suicidedoors.com for your bracketry...they make a little bit of everything. Their stuff is laser cut and their customer service can't be beat. Quote Link to comment
Cruzn620 Posted October 23, 2007 Report Share Posted October 23, 2007 suicide doors doesnt have as much bracketry as i thought any more...but they do have shock relocation stuff. check out: http://www.ubmachine.com Quote Link to comment
