fisch Posted June 8, 2009 Report Share Posted June 8, 2009 As stated in my MA inspection sucks thread, I failed today because I have a rusty tailgate. I have another to put on, but what is the best way to get the old one off? No bolts and they crimped the end of the hinge tubes. Any tricks? Or just stick something like a punch in the hole and beat the shit out of it till the pin comes out the other side? I can't get the BFH in theere so it looks like a smaller hammer will have to do. Quote Link to comment
fisch Posted June 8, 2009 Author Report Share Posted June 8, 2009 Update- Once the pbBlaster set in it was pretty easy to hammer the pins out with a bolt stuck in the hole. NEw tailgate on! THough it needs paint! Quote Link to comment
fisch Posted June 9, 2009 Author Report Share Posted June 9, 2009 Not as simple as you'd think! The hinges did not line up with the new gate. I had to use a cut off wheel and remove a 1/4 inch of tubing from both the hinge halves on the gate in order to shift it to the right so it would close. Kinda weird they were not the same at all. But it is on there now so all is good! Quote Link to comment
Pacific coast Datsun Posted June 9, 2009 Report Share Posted June 9, 2009 I used a worn out phillips head screwdriver to swap mine out. Wierd how the other hinge had to be trimmed. Quote Link to comment
fisch Posted June 9, 2009 Author Report Share Posted June 9, 2009 I almost wonder it was a 520 gate? I not sure if would make a difference? Quote Link to comment
Pacific coast Datsun Posted June 9, 2009 Report Share Posted June 9, 2009 ^^^ good question & the one i swapped on was off a 520 w/ no fittment issues :D Quote Link to comment
jefe de jefes Posted June 9, 2009 Report Share Posted June 9, 2009 I also had to trim that part when I used the 520 tailgate on my 521. Quote Link to comment
Rocket Dog Posted December 22, 2011 Report Share Posted December 22, 2011 Anybody have photos of the actual tailgate hinge pin? I'm fabricating some out of drill rod. Quote Link to comment
Rocket Dog Posted June 4, 2012 Report Share Posted June 4, 2012 I just ordered some drill rod from McMaster Carr. The spec is, Tool Steel Rod, Letter Size O, .316" Diameter, 3 feet length. The stock pin diameter is .317 inches and the stock length is 4.543 inches. This drill rod comes in 3 foot lengths so if I make the pins 4.5 inches exactly, I should be able to make 8 pins from each drill rod. Then again this is RATSUN so...I can probably just spit on the drill rod and cut where the wet spot is. Seriously, these aren't particularly expensive. Depending how much it costs me to get them cut, I'll sell the extra pins in sets of two. Message me if you need a pair (of tailgate hinge pins). BAM! Quote Link to comment
thisismatt Posted June 4, 2012 Report Share Posted June 4, 2012 I, too, had to shave tailgate side hinge leaves to get a replacement tailgate to fit correctly on my 521. My guess is that the hinges are installed on the tailgates first and then lined up with the bed, and they're all a little different. Quote Link to comment
Figbuck Posted June 17, 2012 Report Share Posted June 17, 2012 I guess part of your question... you answered. That doesn't sound like the hot-set-up to me. Maybe it was the best way to get it off... but it that didn't seem to help out on the re-hang. Are you kiddin' me you cut the hinge knuckles off?? You also didn't know or think to drill the crimps out of the hinge, and hammer a drift pin on the side you can swing on? I have hung, built, remodeled, repaired and fucked with everything using a hinge that could be construed as a door or gate... from garage doors to fire doors, to 20' tall wooden bi-fold hanger doors. I thought I knew every trick to doctoring hinges and doors that there was, and invented a few of my own. Many, many expensive lessons, wasting time, energy, knuckle skin, materials and patience. But isn't that how we really learn anything. When I removed the hooks and handles off my 620 tailgate I had some of the same problems you encountered, but I needed this thing to be swinging in the same plane as the bed opening, touch the latch point at the same time and have the margins in the opening perfect. It was a bitch to get it dialed in. On the assembly line they must have had a complete tailgate assembly including the hinge installed on the gate. Then it would be too easy for a mindless worker bee to shoot six, hex head shouldered bolts into the bed. Next. I never would have tried to pull the pins, because I know better. When I re-hang expensive entry doors to existing jams, I set the hinges on the jamb, shim the door into the opening so that the margins are precise, then mark the location of the hinge mortises on the door. I never take the pin out of hinge sets until the door is hung. The odds that two different tailgates that have been sat on, and bent to shit, would line up are nil. I would have hosed PB Blast on there and let it cook for a day, then break the bolts off the bed, leaving the hinge with the gate. Maybe a dozen tailgates I have messed with, the only time I twisted a bolt of was on my 620. I didn't use any oil or anything after 35 years and it just sheared off with no effort. I drilled it and hit it with an easy-out no problem. The other five were rusty, dirty but came right out... it was the last bolt of course. After I got done fabricating my new tailgate. I cleaned all the hinge bolt holes with a tap, oiled, then finger tightened both sides of the hinge. I realized that even though the holes in the hinge are sloppy big, I still couldn't get it lined up right. I ended up reaming out ovals on both sides of the hinge, so I could slide the gate to where the margins lined up... then crank down on the bolts. I have had remodel situations where I had to locate the hinges on the door side first or the jamb side first, but I am so anal that I mark the pins so they go back into same hole if I have to split them to pop the door off. When I pulled my truck all apart for paint, my doors were rusted and dented. I found a cream-puff 620 and stripped the nice doors off it and restored them. When I went to hang them back on the cab, the passenger door was a snap, it lined right up and closes perfectly in ten minutes. The driver door was so out to lunch that it took me two solid days to doctor the hinge... actually bend the leafs to change location of the pins in relation to the latch... then bore out the hinge holes big time to get the door to line up, be in a plane and operate the latch right. What a bitch, and the whole time I knew exactly what was preventing it from closing and lining up... I just couldn't believer how much surgery I had to do and how long it look. There are so many times every day where jump to conclusions and in my haste to complete a task, I make more work for myself. My first thought was to bend the door as an easy way out... I had to take a deep breath, and leave... come back when I had patience and beat the shit outta the hinges! My EX used to say, " If there is and easy way or a hard way... I will always take the hard way." The trick is not figuring out how to solve a problem... it's when you do find a slick solution... you can actually remember it, so the next time you know what you are doing. On that. Quote Link to comment
DanielC Posted June 17, 2012 Report Share Posted June 17, 2012 On a 521, the hinges on the tailgate, and the body are welded on. I believe the 521 trucks were spot welded together by humans, and not pre programmed robots. If the assembly instructions called for five spot welds in two pieces of sheet metal, they got five spot welds, where ever the worker thought they should go. Quote Link to comment
Figbuck Posted June 18, 2012 Report Share Posted June 18, 2012 I had a camper on my 521 and I seem to remember unbolting it like the 620??? no? OICS Quote Link to comment
