BEEBANI Posted May 19, 2009 Report Share Posted May 19, 2009 So I redesigned my front brackets again, and had them laser cut from weapons grade 1/4" plate. I also sent them out and had them clear zinc plated so they'll stay protected. Jesusno2 does military contracts at his work and that's where they were cut, I'm not sure the difference in the plate, but it is blued like a gun. I'm also providing these with all the hardware in 10.9 grade. I have a few in stock! The fronts are now $150 pair plus freight, and the rears are $90 plus freight. Quote Link to comment
moparvwfreak Posted May 19, 2009 Report Share Posted May 19, 2009 very nice!!!!! Quote Link to comment
dat521kid Posted May 19, 2009 Report Share Posted May 19, 2009 are you including the hardware for the rears aswell? is there a better deal if bought at same time? i still need to know if these sets clear my stock steelies? p.s. great work man Quote Link to comment
slodat Posted May 19, 2009 Report Share Posted May 19, 2009 Those look good!! Want to give me a credit for the rears I bought with the holes that aren't round? Quote Link to comment
72 327 Posted May 19, 2009 Report Share Posted May 19, 2009 LOL I should have waited. I got fronts with holes not round. Quote Link to comment
BEEBANI Posted May 19, 2009 Author Report Share Posted May 19, 2009 are you including the hardware for the rears aswell?is there a better deal if bought at same time? i still need to know if these sets clear my stock steelies? I will be supplying the hardware to mount the calipers for the rear brackets. I'm pretty sure the fronts won't clear 14" stockers, but now that I have a set of wheels again I'm going to check for sure. Quote Link to comment
ariascarlos1990 Posted May 19, 2009 Report Share Posted May 19, 2009 So what all do you need to successfully have disk brakes in the rear? Quote Link to comment
LCDC Posted May 19, 2009 Report Share Posted May 19, 2009 Are you bringing those to sell at canby? Quote Link to comment
Weaver Posted May 19, 2009 Report Share Posted May 19, 2009 So what all do you need to successfully have disk brakes in the rear? According to this: Rotors, calipers, pads, and lines: 1989-1993 Isuzu amigo, 1988-1991 Isuzu Trooper, 1988-1995 Isuzu Pickup Quote Link to comment
ariascarlos1990 Posted May 19, 2009 Report Share Posted May 19, 2009 so either of the three models of vehicles will work? Quote Link to comment
impala_631 Posted May 19, 2009 Report Share Posted May 19, 2009 looks really nice!! do they push your wheels out at all, every disc brake kit ive done pushed the wheel out 1" Quote Link to comment
dat521kid Posted May 19, 2009 Report Share Posted May 19, 2009 I will be supplying the hardware to mount the calipers for the rear brackets. I'm pretty sure the fronts won't clear 14" stockers, but now that I have a set of wheels again I'm going to check for sure. sweet!! :D thank you.. keep me posted Quote Link to comment
djmoreron Posted May 19, 2009 Report Share Posted May 19, 2009 looks really nice!! do they push your wheels out at all, every disc brake kit ive done pushed the wheel out 1" i think the front kit does because of the hardbody rotor. i will have mine installed (the 2nd version) soon. not sure about the rear. god damn these look good though, wish i had waited. the steel you used has a reflection that makes it seem like you doubled up on washers when installing the bolts. Quote Link to comment
BEEBANI Posted May 19, 2009 Author Report Share Posted May 19, 2009 Waiting might not have done anyone any good. These kinda just came together at the last minute. I've been taking input from people over the years and trying to fix any little issues I saw with them. The laser cutting only happened because I got a sweet deal at the last minute. The plating was something I never thought about before either, but turned out great and was cheap. I have these for sale on egay right now. Won't be at Canby, sorry. Quote Link to comment
BEEBANI Posted May 19, 2009 Author Report Share Posted May 19, 2009 looks really nice!! do they push your wheels out at all, every disc brake kit ive done pushed the wheel out 1" only 1/4"....the thickness of the rotor. Quote Link to comment
impala_631 Posted May 20, 2009 Report Share Posted May 20, 2009 only 1/4"....the thickness of the rotor. is that for front and rear?or just the front?:) Quote Link to comment
BEEBANI Posted May 20, 2009 Author Report Share Posted May 20, 2009 is that for front and rear?or just the front?:) The rear also. Quote Link to comment
yello620 Posted May 20, 2009 Report Share Posted May 20, 2009 is that for front and rear?or just the front?:) Wouldn"t it be the thickness of the rotor minus the thickness of the drum that was removed? You are removing a drum that mounts on the outside of the hub just like the rotor does. Right? And the rotor hat is only slightly thicker than the drum. Quote Link to comment
BEEBANI Posted May 20, 2009 Author Report Share Posted May 20, 2009 Wouldn"t it be the thickness of the rotor minus the thickness of the drum that was removed? You are removing a drum that mounts on the outside of the hub just like the rotor does. Right? And the rotor hat is only slightly thicker than the drum. Good point J, thank you. Quote Link to comment
Farmer Posted May 20, 2009 Report Share Posted May 20, 2009 Looking at the rear plates, are the caliper mounts going to be welded more? Larry Quote Link to comment
BEEBANI Posted May 20, 2009 Author Report Share Posted May 20, 2009 it's just a spacer buddy, that's why it's just tacked on. Normally I just leave them loose, but for plating it worked out better to tack them on. Quote Link to comment
herculesinwyoming Posted May 20, 2009 Report Share Posted May 20, 2009 they do look really good, i cant afford any right now, but they sure are on my wish list now Quote Link to comment
Farmer Posted May 21, 2009 Report Share Posted May 21, 2009 it's just a spacer buddy, that's why it's just tacked on. Normally I just leave them loose, but for plating it worked out better to tack them on. Thanks i' figure something like that. Larry Quote Link to comment
SurgeL320 Posted May 22, 2009 Report Share Posted May 22, 2009 Hey beebani i sent you a message about a complete set of brackets for my 320 . Im also wondering if they'll clear 15" stock wheels. Do you know of any places that sell cheap parts for the swap Quote Link to comment
lynchfourtwenty Posted May 22, 2009 Report Share Posted May 22, 2009 that shit loooks AWESOME! ima need a set when i get some cash bee :) i want the rears hella bad but i cant offord front an rear hehe Quote Link to comment
