bucket Posted February 20, 2009 Report Share Posted February 20, 2009 (edited) i need the for sure years on 280zx rotors. my wagon has warped rotors and i need to order more but i have no idea what the (for sure) years are that wil work and i need to order asap. are any 79-83's gonna work?and im wonderin if even though the shoes still got a bunch of meet on em should i replace em also because they ve been possibly distorted by the warped rotor???????????? help me out fellas Edited February 20, 2009 by bucket Quote Link to comment
thisismatt Posted February 20, 2009 Report Share Posted February 20, 2009 Any year 280zx rotor should work/interchange. I would replace pads. Quote Link to comment
Bleach Posted February 20, 2009 Report Share Posted February 20, 2009 What's the backstory, you have front ZX struts? Or you did a rear disc swap to 280ZX brakes? You mention bake rotors and shoes in the same sentance... I'm confused Quote Link to comment
bucket Posted February 20, 2009 Author Report Share Posted February 20, 2009 well, i dont know much of the back story, i got the car 3 weeks ago, and got it running a few days ago. it came with the 280zx front breakes witch wobbel when i stop so off come the wheels and warped rotors i find. so the shoes are chunky but im gonna replace them any way so i know there flat. but when i go out a shoppin. im told i got to know what year the breakes were originally on, but how the hell do i know. either way i just sold my 620 so this is my now daily driver and i gotta get em takin care of. Quote Link to comment
72240z Posted February 20, 2009 Report Share Posted February 20, 2009 It could have the front calipers and dif rotors. I'd check to make sure. Quote Link to comment
datto510 Posted February 20, 2009 Report Share Posted February 20, 2009 What is the diameter of the 280ZX rotors? Quote Link to comment
Bleach Posted February 20, 2009 Report Share Posted February 20, 2009 ok. brake Shoes are the materials used inside drum brakes brake pads are the materials used in a caliper on disc brakes I think it was confusion on terminology as well. Quote Link to comment
72240z Posted February 20, 2009 Report Share Posted February 20, 2009 (edited) What is the diameter of the 280ZX rotors? Rears are 254mm (10in) I thought I had fronts but it can't be right. Edited February 20, 2009 by 72240z Quote Link to comment
bucket Posted February 20, 2009 Author Report Share Posted February 20, 2009 ok pads i mean. and the rotor on there are 9.25ish but i cant get a caliper on there right now. Quote Link to comment
datto510 Posted February 20, 2009 Report Share Posted February 20, 2009 I believe fronts are 314mm (12.28in) and the rears are 254mm (10in) Thank you kindly for that info. I searched in the FAQ, but found nothing. Quote Link to comment
72240z Posted February 20, 2009 Report Share Posted February 20, 2009 Thank you kindly for that info. I searched in the FAQ, but found nothing. I just broke out the factory manual so I don't screw anyone up. Fronts - 252mm or 9.92in Rears - 269mm or 10.59in I'm going to shoot you a pm to let you know Quote Link to comment
72240z Posted February 20, 2009 Report Share Posted February 20, 2009 ok pads i mean. and the rotor on there are 9.25ish but i cant get a caliper on there right now. 9.25in is not a rotor from any z 70-88 now that I have the chart sitting in front of me...... Quote Link to comment
bucket Posted February 20, 2009 Author Report Share Posted February 20, 2009 thats as close as i gather with the wheel on till i get off work. but just to know what is stock rotor diamiter in cace im wrong, wich is know to happen. they just look bigger than stock at a glance Quote Link to comment
72240z Posted February 20, 2009 Report Share Posted February 20, 2009 thats as close as i gather with the wheel on till i get off work. but just to know what is stock rotor diamiter in cace im wrong, wich is know to happen.they just look bigger than stock at a glance Stock diam for what car lol. Quote Link to comment
bucket Posted February 20, 2009 Author Report Share Posted February 20, 2009 72 510 wagon Quote Link to comment
datzenmike Posted February 20, 2009 Report Share Posted February 20, 2009 (edited) i need the for sure years on 280zx rotors. The rotors are probably not warped, they have been run hot and pad material has transferred onto them. Now when the wheel turns the pad rubs against the transferred material and there is increased friction, a sort of 'tight spot'. The steering wheel will tug from side to side as you pull to a stop. Brake shops make a lot of money selling new rotors and pads to people with this problem. If you have an electric sander just clean the rotors up nice and shiny on both sides. Don't worry you aren't going to remove anywhere near enough metal to have any effect. If the rotors are grooved have them re-surfaced at a shop and put new pads on. Depending on price new ones may be an option. 280zx were from '79 to '83. IF you have zx rotors those are the years. Ask the previous owner! If you don't know the year then we sure won't. Ask for '79 rotors and see if they were used on any other zx year like up to '81. If they don't fit take 'em back and try the next rotor after '81. Trial and error. Edited February 20, 2009 by datzenmike Quote Link to comment
Edz280zx Posted February 20, 2009 Report Share Posted February 20, 2009 I know ZX's have two different part #'s for rotors...79-81 and 82-83..this includes fr and r rotors and pads. Quote Link to comment
72240z Posted February 20, 2009 Report Share Posted February 20, 2009 I know ZX's have two different part #'s for rotors...79-81 and 82-83..this includes fr and r rotors and pads. Ya you know I noticed that too. The service manual lists one set of dimensions but brembo for example has 3, one for the front and 2 for the rear. The difference in the rear is .5mm thickness and 5mm diameter. But neither diameter matches the stock spec lol. I know for a fact they all work with one another so I wonder what the deal is. Quote Link to comment
bucket Posted February 21, 2009 Author Report Share Posted February 21, 2009 (edited) they are 9.92: x .71" the only # i found on the PADS was 9B369 BM1462 GF 867 and if i figure out how, all other info will show up in pics. what else do i have to know to not order the wrong breaks. Edited February 21, 2009 by bucket Quote Link to comment
72240z Posted February 21, 2009 Report Share Posted February 21, 2009 Brembo Front Brake Disc App: 1979-1983 Nissan 280ZX Brand: Brembo Part #: 25255 Notes: "BREMBO VENTED BRAKE DISC, SOLD INDIVIDUALLY -- 4 Lugs, 252 mm Diameter, 20 mm Thickness, 18 mm Minimum Thickness, 29 mm Overall Height, Made Of High Carbon Cast Iron, Machined To Exact OEM Specifications, With Better Damping Factor That Reduces Noises And Vibrations" http://www.racepages.com/parts/brake_rotors/nissan/280zx.html That's that...... Quote Link to comment
bucket Posted February 21, 2009 Author Report Share Posted February 21, 2009 so i can order that rotor noe and new pads and be set? pretty helpful what about how to post pics from PC Quote Link to comment
banzai510(hainz) Posted February 27, 2009 Report Share Posted February 27, 2009 (edited) see if you can get the rotors turned??????? at a automotive machine shop. They will mic them ,then could be good as new try this website brembo http://www.importrp.com/search.php?mode=search hit the brembo brakes avatar photo on the side and keep hitting nissan and 280zx it will pop up. its a hard website to navigate but has good prices on NGK wire sets and clutches ect......... forget it, I just saw what 72240z posted at a better price!!!!!!!!!! But you ck out L series Rocker arms they want 54$ apc!!!!!!!!!!!! from that website Too bad Mr-Auto-parts went defunct they had Rockers for 13$ apc!!!!!!!!!!! Edited February 27, 2009 by banzai510(hainz) Quote Link to comment
bucket Posted March 1, 2009 Author Report Share Posted March 1, 2009 i got the right rotors on but the pasenger side caliper goes on to tight to center the rotor and let it roll is the an ajustment im missing? Quote Link to comment
