sliding_creep Posted February 12, 2009 Report Share Posted February 12, 2009 anybody out there make or have a line on a plain ol' water inlet or outlet for the L-series blocks? i am currently looking for water inlet and outlet for my l20b. here's the really important part, all the outlets i find have a buncha friggin' fittin' holes that i hafta' plug up. stupid smog manifold crap! i'm switching to the dual SU's and the dual manifold doesn't use the heat/water bypass and the car is no longer needing a heater bypass as there is no heater. in order to solve the problems inherent with the leaking plugs and the ugly look i need to find somewhere that sells those type if they're still available. is there a particular year i shold be looking for or is there an aftermarket performance style thermostat housing inlet and or outlet(chrome?):confused: thanks in advance! cheers Quote Link to comment
datsun510 Posted February 12, 2009 Report Share Posted February 12, 2009 Use 280ZX outlet. It has a threaded bung that the factory had installed a metal tube that would feed the heater. Then you just unscrew the metal tube out and screw in a pipe plug. I run one on my race car. I can post a picture when I get home from work. Seth Quote Link to comment
]2eDeYe Posted February 12, 2009 Report Share Posted February 12, 2009 Yep, and you can use one of the ports for a sensor to turn on your electric fan. If you have one... Quote Link to comment
slodat Posted February 12, 2009 Report Share Posted February 12, 2009 Creating two threads for the same thing doesn't get you more attention to your issue. Quote Link to comment
ppeters914 Posted February 12, 2009 Report Share Posted February 12, 2009 Creating two threads for the same thing doesn't get you more attention to your issue. It doesn't? Quote Link to comment
hang_510 Posted February 12, 2009 Report Share Posted February 12, 2009 It doesn't? not unless you discretely pay extra, so........... Quote Link to comment
datzenmike Posted February 12, 2009 Report Share Posted February 12, 2009 (edited) Creating two threads for the same thing doesn't get you more attention to your issue. Now there is only this one. The the gasket for the L series and Z series is the same number so a Z20/22/24 inlet pipe will also work and they only have the heater hose on it. The Z series inlet may be a bit longer and may not be bent facing backwards as much, but should work for what you want if you shorten it or the rad hose. 13049 U0100 : '75-'77 water inlet 13039 T5501 : '81-'86.5 water inlet Edited February 12, 2009 by datzenmike Quote Link to comment
hang_510 Posted February 12, 2009 Report Share Posted February 12, 2009 Now there is only this one. should it not be in the wanted section? :confused: Quote Link to comment
sliding_creep Posted February 14, 2009 Author Report Share Posted February 14, 2009 excellent, thanks for the info! i didn't mean to post dubbles, i just figgurd i'd try and get part #'s or info. then i guessed i may as well see if'n anyone had sum fer sell, no?:blink: sorry 'bout the unnecessary thread in the WTB. cheers Quote Link to comment
