davy Posted December 19, 2023 Report Share Posted December 19, 2023 like the titles says, i bought a weird but interesting intake that the seller said it fits 100% on a A12 to A15 engines but with round port holes. The intake is a Lynx m127 ; a single sidedraft intake. i trusted him, so we both made a deal. i later emailed a few Australian redline/dcoe set up stores on eBay to find a linkage kit for this interesting intake.... well one of those eBay Aussie performance store message me back and he said quote "Hello, This kit won't suit your current manifold as the threads/studs are different. We can custom-make a kit to suit, although you'll have to contact us directly. P.S. That manifold is to suit a Triumph Spitfire, please check fitment!!" End quote...... should i be worried, did i do a bad purchase? I had research through Google and couldn't find much on it ...... ** Quote Link to comment
datzenmike Posted December 19, 2023 Report Share Posted December 19, 2023 It's a good question, I can't answer other than to say that much of the Nissan A series engine parts will fit MG engines. Now, if the Triumph and MGs share engines or designed on the same engines it may still work. There are others here much more knowledgeable so hang in there. Welcome to Ratsun 1 Quote Link to comment
]2eDeYe Posted December 19, 2023 Report Share Posted December 19, 2023 Lynx list their A-Series Weber manifold as part #M041 https://www.lynxauto.com.au/datsun-1000-1200-1-x-weber-dcoe-manifold.html Your best bet would be to contact them directly to check compatibility. 1 Quote Link to comment
Crashtd420 Posted December 19, 2023 Report Share Posted December 19, 2023 You might get lucky.... It's definitely for the triumph but comparative measurements on the screen look promising.... but again this is 2 picture on a phone..... I used the weber end as reference, 1 picture needs to be zoomed slightly to match... Goodluck.... 1 1 Quote Link to comment
davy Posted December 19, 2023 Author Report Share Posted December 19, 2023 ok so i just email the company Lynx but i dont expect them to reply any time soon for the reason i asked them a question 3x on a vintage Mazda intake availability and fitment and haven't heard from them in over 2 months. These pictures are from the seller's listing and he told me that it would fit a datsun but hasn't tried it himself because he went with a SU setup on his car. Im not saying he's a liar, but I do have concerns now it being for a triumph model. I don't have an engine to try this on yet and the only car i can try it on is being used at the moment and can't dismantle it because of the winter weather. The last picture is my A15 engine, and it was dismantled 2 years ago. The port holes are round and would assume it would work BUT assuming is just that > guessing.... i haven't opened the package yet because I'm waiting on more replies Quote Link to comment
davy Posted December 19, 2023 Author Report Share Posted December 19, 2023 ok so Lynx responded to me and they said quote "Hello, I can't comment on this sorry. The M127 is made for the Triumph Spitfire engine. We dont have any A14 manifolds here to compare it to." So i guess the only option is to try it out on my car but again i can't yet because of weather dropping in temperature and that i need this car drivable. if this was summer days/weather, i don't mind dismantling it Quote Link to comment
Crashtd420 Posted December 20, 2023 Report Share Posted December 20, 2023 14 hours ago, davy said: The last picture is my A15 engine, and it was dismantled 2 years ago. The port holes are round and would assume it would work BUT assuming is just that > guessing.... i haven't opened the package yet because I'm waiting on more replies I don't think it will work if this is your engine.... I think it's ment for the a10/a12 .... Have a look at this picture of an a12 engine.... notice the stud pattern and shape where the intake would bolt. 1 Quote Link to comment
datzenmike Posted December 20, 2023 Report Share Posted December 20, 2023 Use the gasket as a template and drill and tap for a stud. Large washers might also work on the top studs. Quote Link to comment
banzai510(hainz) Posted December 20, 2023 Report Share Posted December 20, 2023 (edited) I would not risk it as mentioned the bolt holes dont line up Edited December 20, 2023 by banzai510(hainz) Quote Link to comment
KELMO Posted December 20, 2023 Report Share Posted December 20, 2023 I'll be out in the shop today and will see if I can find an A12 manifold, gasket, etc. Quote Link to comment
davy Posted December 26, 2023 Author Report Share Posted December 26, 2023 ok so today i did 2 things...well 3 things to is if this intake fits any one of my vehicles. 1) I took a tomei #14035R001 intake gasket, yes i know the gasket is for an oval port head but wanted to see if the head holes distance match the intake manifold holes and they don't match. Head holes are much farther in distance than the intake manifold holes; meaning in "layman terms" the intake is small for the a14 oval head 2) went to the spare parts a15 engine with round head ports and again same issue as the A14 gasket above. Intake manifold is small and WON'T fit our Datsun 3 I figured since they don't fit Datsun maybe it might fit a Mazda b2000 ; i took an intake gasket and try it onto the lynx intake and no it doesn't fit so i am going to contact the seller in seeing about a return on this intake since i cant use it . now i dont have a A12 to actual try this on, so this might fit an A12 engine as long as the head is smaller than the A14/A15 engines because of the intake holes distances Quote Link to comment
