Datsunworks Posted November 25, 2023 Report Share Posted November 25, 2023 Hi I did some searching but kind of came up empty. My 79 KC has provisions on the steering column for a steering lock key switch. Was this an option on the 79? Any idea if one from another model will fit? Thanks Derek Quote Link to comment
Stoffregen Motorsports Posted November 25, 2023 Report Share Posted November 25, 2023 The 620 doesn't have a column lock? Really? Though not 620, here's a Datsun related tech writeup - http://datsun1200.com/modules/mediawiki/index.php?title=Steering_Lock Quote Link to comment
datzenmike Posted November 25, 2023 Report Share Posted November 25, 2023 4 hours ago, Datsunworks said: Hi I did some searching but kind of came up empty. My 79 KC has provisions on the steering column for a steering lock key switch. Was this an option on the 79? Any idea if one from another model will fit? Thanks Derek My '78 also had a slot in the column for the lock device to engage but the ignition switch didn't have it. 1 Quote Link to comment
Stoffregen Motorsports Posted November 26, 2023 Report Share Posted November 26, 2023 Weird. Maybe try using one from a 510 or Z car, or even 210. Quote Link to comment
Stoffregen Motorsports Posted November 26, 2023 Report Share Posted November 26, 2023 On second thought, why not try one from a 720? Quote Link to comment
Datsunworks Posted November 26, 2023 Author Report Share Posted November 26, 2023 6 minutes ago, Stoffregen Motorsports said: On second thought, why not try one from a 720? I was thinking that as well. I did find an Ebay listing for this 1972-1979 DATSUN 620 UTE PICKUP UTILITY TRUCK IGNITION SWITCH LOCK KEY FIT On the last picture they have a caliper showing a measurement that appears to be highly accurate 🙂 The column is out of something that used a lock since the hole is in the tube and the shaft has the slot for the pin. Quote Link to comment
Icehouse Posted November 26, 2023 Report Share Posted November 26, 2023 I put a Club on all my Datsuns plus a hidden kill switch. The Club is so the thief's maybe take the hint and live my rig alone. They tried to steal my daughter’s Subaru. Got it started but couldn’t get the Club off. Of coarse they left it running all night….. Quote Link to comment
datzenmike Posted November 26, 2023 Report Share Posted November 26, 2023 Rookies. Just take a hack saw with you and cut the steering wheel to get the club off. 1 Quote Link to comment
Datsunworks Posted November 26, 2023 Author Report Share Posted November 26, 2023 2 minutes ago, datzenmike said: Just take a hack saw with you and cut the steering wheel to get the club off. My thoughts as well. Although a determined thief will find a way. I'm looking at the steering lock as the least inconvenient way to get some added protection. That and the manual transmission should cover about 90 percent of the thieves who hotwire. A kill switch is not a bad idea either. Quote Link to comment
Icehouse Posted November 27, 2023 Report Share Posted November 27, 2023 I’m not sure how many theifs haul a hack saw in their back pack. Apparently not the one that attempted to steel my kids car. They did bust the steering lock and had that all sorted. They tried to drive it with the door open! Haha. It was crooked in the parking spot. Quote Link to comment
datzenmike Posted November 27, 2023 Report Share Posted November 27, 2023 Professionals aren't going to steal a POS Datsun so for kids looking for a lark it's a screwdriver to twist out the lock and the ignition and lets party. Just don't make it easy for them. If carrying a hacksaw then you know in advance that the car you want has a club. So definitely have an ignition and/or starter cut out. If they can't get it going in 60 seconds they move on. Quote Link to comment
thisismatt Posted November 27, 2023 Report Share Posted November 27, 2023 Works every time 1 Quote Link to comment
Stoffregen Motorsports Posted November 27, 2023 Report Share Posted November 27, 2023 On many of my classic vehicles, I have battery kill switches. Some are hidden (under the dash or seat), but most are easily accessible. It's a simple deterrent that most theives wouldn't even understand. Kinda like the millennial theft device known as a clutch. Quote Link to comment
datzenmike Posted November 27, 2023 Report Share Posted November 27, 2023 6 hours ago, thisismatt said: Works every time 1 Quote Link to comment
Datsunworks Posted November 28, 2023 Author Report Share Posted November 28, 2023 So I measured the tube and it's 38.25 mm which is 1.506". The one on eBay that I linked to is showing 1.485. I found a listing for a 720 that showed a measurement of 30.84mm so that's right out. So it's either a club or take a chance on a lock from Thailand actually fitting. I'll update the thread if I end up going that direction. 1 Quote Link to comment
datzenmike Posted November 28, 2023 Report Share Posted November 28, 2023 As long as the clamping part fits the column. If slightly larger it will still clamp. BTW slit the non tamper screws like this and they turn out with a screwdriver. Just reuse them. Quote Link to comment
EDM620 Posted December 2, 2023 Report Share Posted December 2, 2023 On 11/26/2023 at 9:46 PM, Icehouse said: I’m not sure how many theifs haul a hack saw in their back pack. There are too many cordless angle grinders out there being used to steal cat converters - a quick cut through a steering wheel is nothing. On 11/27/2023 at 8:27 AM, Stoffregen Motorsports said: Kinda like the millennial theft device known as a clutch. Anything you can do to make it a PITA and a lazy thief will quickly move on. Hidden kill switches are a good deterrent too. Skid mark shorts and a dirty sock on the gearshift - hell that'd keep me from wanting to drive my own wheels! 1 Quote Link to comment
