'65 320 brake drum stuck
i cant get the drum off my truck i have concluded that it is rusted on in the middle it is circled where it it rusted on in the picture below. i dont want to buy a drum puller anyone have a suggestion
the image is not mine just on off the internet btw
-thanks, crusty
  • Replies 8
Heat around the center and the lugs. Don't worry drums are used to getting hot. Use a 4 pound maul or hammer and smack round and round outside the lug circle. Heat will expand the holes and loosen.... unless the shoes are the cause.
Yes, the drum rusts to the axle flange. Heat, and maybe lots of it, are going to be the cure.
This is assuming that you A- have the screws removed, and B- that the shoes are loosened to help with removal.
On the 320, there is a dust shield on the back of the brake backing plate that makes hitting the drum with a hammer difficult, There are two slots in the dust shield that make it possible to use a small drift, but it is close and precarious work. Wear gloves so you still have knuckles when your done.
there's a technique I use in this vid that might help.  I've also had to cut them off with a cut off wheel. I was doing a disc upgrade, so I didn't care about the drum.
