Distributor rehab
Okay Ratsun-migos, I broke my own rules and bought a used car part on eBay. Now I pay the price.
I got an I think D4f electronic distributor, remote ignitior, hei compatible style one if that clarifies which type.
Thing is, it’s in shit condition. I can only be mad at me, it was in “used” “as-is” condition and I’m the idiot who bought it. Ok pity party over.
I took it apart already. It’s real crusty and rusty. My question is about all these plates. How freely do they need to move relative to one another?
First there’s this piece indicated by my red straw which slides freely:
BA1-D9-BC2-5-C9-B-4-A7-E-91-BD-57-D82-CB
Moving downwards which is pretty gritty but will rotate:
CE8-E3124-D8-E0-4-FEC-A618-503-AFE86-E00
Next, this one below that holds the bearings is hard to budge but I’m guessing the other stuff slides on that one and it stays stationary??:
722-E7-CEB-CD38-40-A9-831-C-FD758-CEB36-
Assumption here is that I’m holding onto this one below and trying to spin the rest:
C7-D10390-C43-C-4-B5-D-B859-CE6986-CB149
Looking at the underside, this one will slide along the slot, but not easily:
39472951-8-C74-433-B-8-FF0-D3-D4-B22-C03
SO, are all these plates supposed to glide like butter over the top of one another or is some resistance ok?
(I do have the missing ball bearings, eagle eyes).
Thanks for any advice.
  • Replies 27
I wouldnt pay more that 20bucks if that then dont worry about it.
I know Amazon has those Chinese point convertion distributors.I was hoping more people try them(give a review) out maybe I get a spare. Only thing is I think the timing plate that come with them is for a L20 not the L16 is it might have to be moded.
https://www.ebay.com/itm/165635189996
this would use the stock ballast and stock point coil
Edited by banzai510(hainz)
4 hours ago, banzai510(hainz) said:
i think I throw that away
soembody has a stack of distributors soemwhere.  I got L16 ones Ill throw away soon enough. Nobody wants them.(I wont send them!!!)
I’m in too deep! I got robbed on eBay like I knew I would now I’m committed! Unless you really think that’s hopeless.
I put up a want ad…no one wanted to sell me an electronic distributor…I looked at the junkyards…nothing. I called my parts hoarder…nothing.
I mean I’m fine with points for now. Oh well. Maybe I’ll try the cheap-o Boursin one.
You're joking, right? The stock L16 distributor is what the vintage races run. Someone would surely buy them all.
I'm going to be getting into this with the distributor on my L28 soon.
Those sliding plates are supposed to move. I believe one is for vacuum advance and the other should be for mechanical advance.
The plate with the bearings sometimes breaks or the bearings fall out. It is good that you have it all. I would suggest disassembling it all (carefully), clean it well, and assemble with just very minor amount of grease. Hainz is more familiar with these than I am.
Even for the six cylinder L-series, distributors are getting hard to find. Many were thrown away instead of being repaired.
Hainz probably is referring to the 70-73 510 L16 dizzy's, which are dual point?  Yes, the 68-69 single point dizzy's are getting hard to find & valuable!
OP get me the part # stamped on that nasty old dizzy you got............I have a big box FULL of L series dizzy's & parts (sorry, no Matchbox & only a couple of the mag pick up ones, but LOTS of others!).  FYI I will NOT be able to look until Saturday, as my new job has taken me away from my Datsun stuff during the week! 😝
8 hours ago, Stoffregen Motorsports said:
Just throwing out options. What you do with them is up to you.
Embracing them. That’s what I’m doing. Now if only Hainz would realize you are trying to make him a few bucks selling all those dizzys to vintage racers. Do I smell a finder’s fee in your future?
@yenpit ok it says:
D4F6-05 (8301 real small)
22100 B9800
Much appreciate your help rummaging through your box of parts whenever you get to it.
I can’t seem to get the plates apart, but assuming I do and grease them up, my big remaining issue would be that seized chunk of vac advance stuck in there. I will try to dremel that thing out but this may end badly for this dizzy body.
  • 2 months later...
Alright got the plates apart and greased and now they slide like butter. The plastic cage for the bearings has seen better days but it seems to be hanging in there with the glue.
Nice and greasy…I think I got all the slots lined up. Seems like it doesn’t fit if you don’t:
However…I forgot over the last two months that the screw holding all this stuff onto the spindle(?) that sets it into the body broke in half:
So I guess in the name of this thread which is “stubbornly and idiotically putting a piece of trash distributor back into service” I will keep going.
Next I’ll try the blowtorch on that stupid vacuum advance fitting and see if that gets it out of there. No progress on that front.
22100-B9800 is a '78 620 L20B federal emissions truck distributor. Making it an EI (electronic ignition) distributor of which this is the remote igniter style, so it needs the igniter box to go with it...
Do you have this? won't work without it. There is a way around this problem, let me know.
My EI distributor was in my truck for 15 years then put it in my 710 for another 13 years. The button that rides on the top of the rotor wore through so I just pulled one from another distributor so it's over 20 years old and about 10 years ago I got a used set of L28 blue NGK wires. They were longer so I could run them around the front of the valve cover instead of over. Once a year I clean and check the cap and I wipe the wires down individually with a rag soaked in WD-40. Don't remember changing the rotor either. They just run and run and run.
