Icehouse Posted April 25, 2023 Report Share Posted April 25, 2023 If everyone could keep their eye out of a 1980-82 4x4 long bed 720 front diff for a me that would be great. We need the gearset for our racecar. I did the car-part.com search. couldn't find one. I will keep searching, but with your help maybe I could find one faster. Thanks guys! 1 Quote Link to comment
RetroRocket Posted April 25, 2023 Report Share Posted April 25, 2023 I have a 4:38 R180 front in case that could be an option. Quote Link to comment
datzenmike Posted April 25, 2023 Report Share Posted April 25, 2023 2 hours ago, Icehouse said: If everyone could keep their eye out of a 1980-82 4x4 long bed 720 front diff for a me that would be great. We need the gearset for our racecar. I did the car-part.com search. couldn't find one. I will keep searching, but with your help maybe I could find one faster. Thanks guys! Jeff... the '86-'89 Z24i powered WD21 were all 4.625 and had the same R-180 front differential. Quote Link to comment
bottomwatcher Posted April 25, 2023 Report Share Posted April 25, 2023 I guess that means he already has one. Just needs to rob his 4cylinder hardbody. Quote Link to comment
datzenmike Posted April 26, 2023 Report Share Posted April 26, 2023 No it's only in the early Z24i powered WD21 Pathfinder. The D21 is the Hardbody. I should have said so. Nissan discontinued the four cylinder Z24i for '90 and continued with their VG30E engines after. I've never seen a 4 cylinder Pathfinder. Even with 4.625s it must be slow. Quote Link to comment
Stoffregen Motorsports Posted April 26, 2023 Report Share Posted April 26, 2023 Found this - Quote Link to comment
Icehouse Posted April 26, 2023 Author Report Share Posted April 26, 2023 23 hours ago, datzenmike said: Jeff... the '86-'89 Z24i powered WD21 were all 4.625 and had the same R-180 front differential. Remember the D21 R180 is a shorty. Won't work with the 510 suspension. We need the long guy. Similar to the Subi diff. Quote Link to comment
Icehouse Posted April 26, 2023 Author Report Share Posted April 26, 2023 3 hours ago, Stoffregen Motorsports said: Found this - I think it's only 1980 long bed that has the 4.6 gears. So an 82 will most likely have the 4.11 or 4.37 1 Quote Link to comment
datzenmike Posted April 26, 2023 Report Share Posted April 26, 2023 My bad. The ring gear on the Pathfinder is 11 bolts, the 720 R-180 is 10 bolt so even the R&P can't be swapped. The WD21 also looks shorter so the pinion is different length also. Crap. Quote Link to comment
Wildcat Walker Posted April 26, 2023 Report Share Posted April 26, 2023 Local yard has several 4x4 720's, what ratio you want? What's in it for me? 1 Quote Link to comment
Icehouse Posted April 26, 2023 Author Report Share Posted April 26, 2023 1 hour ago, Wildcat Walker said: Local yard has several 4x4 720's, what ratio you want? What's in it for me? I could kick you some cash for getting it. I need the 4.6 gear ratio, which is only 1980 long bed 4x4. If you get me the vin I could look it up for you. I can also change where it says "member" under your name to "king Diff finder" 1 Quote Link to comment
thisismatt Posted April 27, 2023 Report Share Posted April 27, 2023 4 hours ago, Icehouse said: I could kick you some cash for getting it. I need the 4.6 gear ratio, which is only 1980 long bed 4x4. If you get me the vin I could look it up for you. I can also change where it says "member" under your name to "king Diff finder" "Got my D" more appropriately Quote Link to comment
Wildcat Walker Posted April 27, 2023 Report Share Posted April 27, 2023 15 hours ago, Icehouse said: I could kick you some cash for getting it. I need the 4.6 gear ratio, which is only 1980 long bed 4x4. If you get me the vin I could look it up for you. I can also change where it says "member" under your name to "king Diff finder" It will be at least a week before I can get to the yard. I pulled a windshield from a 4x4 720 King Cab a few months ago that may have been a 80'. There are several other 4x4 720's at that yard. 80's are uncommon here, I think I have seen one L20b in the various yards in the past 15 years, and that was in a 710 goon. Quote Link to comment
Stoffregen Motorsports Posted April 27, 2023 Report Share Posted April 27, 2023 21 hours ago, Icehouse said: I think it's only 1980 long bed that has the 4.6 gears. So an 82 will most likely have the 4.11 or 4.37 Might be worth a call at least. Quote Link to comment
datzenmike Posted April 27, 2023 Report Share Posted April 27, 2023 There is a tag inner right fender that will say what engine and differential. Only the '80 had the L20B L20B 1951cc Bottom right HF46 for the 4.625 ratio. The '80 hood is unique with louvers at back of the hood near the plenum where the wiper linkages are. Quote Link to comment
Icehouse Posted April 27, 2023 Author Report Share Posted April 27, 2023 6 hours ago, Stoffregen Motorsports said: Might be worth a call at least. Good point. Honestly I need to open up the R180 we got. If it's 4.11 the 4.37 might be good enough. 1 Quote Link to comment
